Ron de Vos
Rep Power: 11 ![]() |
I work on DTCHull but by snappyhexmesh I get
FOAM FATAL IO ERROR: Could not open "C:/OpenFOAM/cygwin64/home/Windschip/OpenFOAM/Windschip-2.3.x/run/DTCHull/constant/triSurface/DTC-scaled.eMesh" I dont know how I get . eMesh in the triSurface Ron ![]() |
Ron de Vos
I am looking for the the commandline of surfaceFeatureExtract.
![]() Ron |
Ron de Vos
I try but i can't find the solution to change DTC-scaled.stl in DTC-scaled .emesh
I haven seen some solutions but it looks like that in OpenFoam 2.3.x something is changed. Which commandoline is needed to change the .stl in . eMesh |
Alexander Bartel
Hi Ron,
you just need to use the command "surfaceFeatureExtract" in your case folder. To use the command you need to store your .stl -files in /constant/triSurface and make sure you have a surfaceFeatureExtractDict" -file in /system . A surfaceFeatureExtractDict should look like : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object surfaceFeatureExtractDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // main.stl { // How to obtain raw features (extractFromFile || extractFromSurface) extractionMethod extractFromSurface; extractFromSurfaceCoeffs { // Mark edges whose adjacent surface normals are at an angle less // than includedAngle as features // - 0 : selects no edges // - 180: selects all edges includedAngle 150; } // Write options // Write features to obj format for postprocessing writeObj yes; } orifice.stl { extractionMethod extractFromSurface; extractFromSurfaceCoeffs { includedAngle 150; } writeObj yes; } // ************************************************************************* // regards Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
Ron de Vos
Hi Alex
The surfaceFeatureExtractdict file is in the system of DTCHull and also the dtc-scaled stil is in it when I type in the DTCHull case folder: surfaceFeatureExtract/constant/triSurface/DTC-scaled.stl DTC-scaled I get bash: surfaceFeatureExtract/constant/triSurface/DTC-scaled.stl: No such file or directory Windschip@Asus ~/OpenFOAM/Windschip-2.3.x/run/DTCHull/system $ Usage: C:\OpenFOAM\cygwin64\opt\OpenFOAM\OpenFOAM-2.3.x\platforms\cygwin64mingw-w64DPOpt\bin\surfaceFeatureExtract.exe [OPTIONS] bash: Usage:: opdracht niet gevonden What is it I do wrong? Ron |
Alexander Bartel
Hi Ron,
no need to use this big font ![]() The stl files have to be in /constant/triSurface folder if it not exists... create it. When you are in your DTCHull case folder just type "surfaceFeatureExtract" regards Alex
Ron de Vos
Thank You Alex. The eMesh has succeed.
Ron |
surfacefeatureextract |
