[blockMesh] Getting error message: "Fatal error Symmetry plane 'sides' is not planar"
Like Tree7Likes
  • 7 Post By alexB
Old   June 16, 2015, 09:02
Default Getting error message: "Fatal error Symmetry plane 'sides' is not planar"
Ron de Vos
Ron de Vos is on a distinguished road
I work on the tutorial WigleyHull. I use OpenFoam 2.3 In there is he tutorial DTSHull so I imported wigleyHull from openfoam 2.0.
In BlockMesh i get Fatal error Symmetry plane 'sides' is not planar.etc. Wht can I do
Ron
Ron de Vos is offline   Reply With Quote
Old   June 16, 2015, 18:42
Alexander Bartel
alexB is on a distinguished road
I hope its just as simple as by me... change from "symmetry plane" to "symmetry"
regards
Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
alexB is offline   Reply With Quote
Old   June 17, 2015, 04:18
Ron de Vos
Thank you Alex. It works
Ron
Old   May 17, 2016, 13:31
Nguyen Quoc Bao
cheljin1320 is on a distinguished road
Hi alexB,
I work on the tutorial WigleyHull also, I have same problem with Ron and see your comment above I change from "symmetry plane" to "symmetry". It works!
But continue, when I type snappyHexMesh and view paraFoam it warns: --> FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
patch type symmetry and patchField type symmetryPlane
and I change also "symmetry plane" to "symmetry". It works!
But the lastone, when I type LTSInterFoam it error: --> FOAM FATAL IO ERROR:
Unknown patchField type buoyantPressure for patch type patch.
Could you tell me how to solve this? And what happen when I change "symmetry plane" to "symmetry"?
cheljin1320 is offline   Reply With Quote
Old   May 18, 2016, 10:26
Antimony is on a distinguished road
I assume that you took the tutorial from one version of OF and are using it on another.
If I remember correctly, from OF2.3, buoyantPressure has been replaced by fixedFluxPressure.
Managed to find one that corroborates this statement: http://www.cfd-online.com/Forums/ope...tml#post478508
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   December 21, 2019, 12:07
County Londonderry
photon_ed is on a distinguished road
replacing to "symmetry" worked! thanks
Originally Posted by cheljin1320 View Post
Hi alexB,
photon_ed is offline   Reply With Quote
mixing plane causes fatal error amin.z FLUENT 1 October 27, 2023 08:14
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Plane stress and plane strain cases for stress analysis Sargam05 OpenFOAM 0 May 3, 2013 19:16
[Gmsh] Patches in GmshToFoam hannes OpenFOAM Meshing & Mesh Conversion 11 March 8, 2013 09:01
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
