[snappyHexMesh] MultiRegions: Snappy creates extra domains between Regions
Like Tree3Likes
  • 3 Post By Cartuns11
Old   May 29, 2015, 10:40
Default MultiRegions: Snappy creates extra domains between Regions
Cartuns11's Avatar
Cartuns11 is on a distinguished road
I have been working on a multiRegion model using snappyHexMesh. I created complex surfaces in stl format, these were closed and had good contacts, but after the snappyHexMesh process, between regions and even on faces-region to outside volume, there were extra domains with 1 or 3 cells......
I have seen some posts in the forum, which talk about this, but I haven't found the solution or the problem cause. May be, for complex geometries, the snappy has problems to approach on surface, I don't know......
Does anyone know some solution?
Thanks. Greetings.
Cartuns11 is offline   Reply With Quote
Old   January 14, 2018, 14:31
Çağatay Emre Ayhan
Cagatayemre is on a distinguished road
Hello, Did you find a solution ?
Cagatayemre is offline   Reply With Quote
Old   January 17, 2018, 09:12
Cartuns11's Avatar
(using OF+1606)
Yes! I solved this problem last month! ( coincidence)
The solution is how you name the control volume (==blockMesh volume) and the commands of "splitMeshRegion" application.
First step is to name the blockMesh. I threw blockMesh and snappyHexMesh without a name for the control volume/blockMesh and as consequence, splitMeshRegion named controlVolume as "domain0".....for default. So, blockMesh has to have a name and following codes show where you have to write name in the blockMeshDict ( in this case the name is "air":
Old:
vertices
    (2.7 -0.8 0.57)
    (2.95 -0.8 0.57)
    (2.95 -0.5 0.57)
    (2.7 -0.5 0.57)
    (2.7 -0.8 0.85)
    (2.95 -0.8 0.85)
    (2.95 -0.5 0.85)
    (2.7 -0.5 0.85)
blocks
    hex (0 1 2 3 4 5 6 7) (60 60 60) simpleGrading (1 1 1)
Solution:
vertices
    (2.7 -0.8 0.57)
    (2.95 -0.8 0.57)
    (2.95 -0.5 0.57)
    (2.7 -0.5 0.57)
    (2.7 -0.8 0.85)
    (2.95 -0.8 0.85)
    (2.95 -0.5 0.85)
    (2.7 -0.5 0.85)
blocks
    hex (0 1 2 3 4 5 6 7) air (60 60 60) simpleGrading (1 1 1)
And the last step consists in which commands are introduced in the splitMeshRegion line:
Old:
 splitMeshRegions -cellZones
This command splits all regions = all cellZones, incluiding domain0, domain1, ......domain2345
Solution:
 splitMeshRegions -cellZonesOnly
This command only splits the cellZones which are named by the user.
Using these steps, I haven seen the extra domains anymore.
I hope this explanation is useful for you.
phantomsws, aferraro and Liangyuan like this.
Old   January 22, 2018, 09:39
Çağatay Emre Ayhan
Thank you my friend. I also have found a solution to this problem. I have changed the location in mesh coordianates.
There were more than one locations in mesh and. I think that was the problem.
Solution was to put just one location inside the small geometry
Originally Posted by Cartuns11 View Post
(using OF+1606)
Old:
vertices
    (2.7 -0.8 0.57)
    (2.95 -0.8 0.57)
    (2.95 -0.5 0.57)
    (2.7 -0.5 0.57)
    (2.7 -0.8 0.85)
    (2.95 -0.8 0.85)
    (2.95 -0.5 0.85)
    (2.7 -0.5 0.85)
blocks
Solution:
vertices
    (2.7 -0.8 0.57)
    (2.95 -0.8 0.57)
    (2.95 -0.5 0.57)
    (2.7 -0.5 0.57)
    (2.7 -0.8 0.85)
    (2.95 -0.8 0.85)
    (2.95 -0.5 0.85)
    (2.7 -0.5 0.85)
blocks
Old:
Solution:
openfoam, snappyhexmesh
[mesh manipulation] why splitMeshRegions creates extra domains? skuznet OpenFOAM Meshing & Mesh Conversion 10 May 31, 2022 06:54
[Gmsh] gmshToFoam - Hybrid mesh conversion creates 2 regions bhanu2204 OpenFOAM Meshing & Mesh Conversion 5 February 18, 2018 08:04
[snappyHexMesh] Multi region meshing with SHM creates extra regions Dav3dum OpenFOAM Meshing & Mesh Conversion 0 August 8, 2016 09:54
MultiRegions: How are neighbouring domains coupled? Ivooo OpenFOAM Programming & Development 2 May 24, 2016 09:58
[snappyHexMesh] snappyHexMesh: extra domains domain1 domain2 ... appear skuznet OpenFOAM Meshing & Mesh Conversion 3 November 29, 2015 07:43
