[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing |
April 27, 2015, 16:30 |
Regis
Rep Power: 14 |
I'm creating a simple mesh on a Cartesian domain through blockMesh and then I'm trying to do local refinements in sub-regions of the domain using refineMesh (w/ dictionary). The refinements are being done in parallel.
Below is part of the script I set up to create the mesh: Code:
refineMeshLocal() { i=1 while [ $i -le $1 ] do cp system/topoSetDict.local.$i system/topoSetDict mpirun -np $cores topoSet -parallel > log.topoSet.local.$i 2>&1 cp system/refineMeshDict.local system/refineMeshDict mpirun -np $cores refineMesh -parallel -dict -overwrite > log.refineMesh.local.$i 2>&1 mpirun -np $cores checkMesh -parallel > log.checkMesh.local.$i 2>&1 let i=i+1 done } blockMesh > log.blockMesh 2>&1 checkMesh > log.checkMesh.background 2>&1 # Decomposing the mesh cp system/decomposeParDict.$cores system/decomposeParDict decomposePar -cellDist -force > log.decomposePar 2>&1 # Perform local ref (parallel) refineMeshLocal 2 - the refinement region is being specified thought cellSet using topoSet - the region specified in topoSet is within the domain; So If do just one refinement, everything works fine. However, whenever I try to do more than a single refinement, I get either warnings or fatal errors on second/third/etc refineMesh' logfiles. This is a typical error (using 64 processors, but same happens with more processors): Code:
[35] processorPolyPatch::order : Dumping neighbour faceCentres to "/home/rus284/OpenFOAM_Run-2.0.1/DemoCases_Jan15/ST0g2l64c/processor35/procBoundary35to34_nbrFaceCentres.obj" [61] processorPolyPatch::order : Dumping neighbour faceCentres to "/home/rus284/OpenFOAM_Run-2.0.1/DemoCases_Jan15/ST0g2l64c/processor61/procBoundary61to60_nbrFaceCentres.obj" [35] [35] [61] [61] [61] --> FOAM FATAL ERROR: [61] in patch:procBoundary61to60 : Local size of patch is 48 (faces). Received from neighbour 47 faceCentres! [61] [61] From function processorPolyPatch::order(const primitivePatch&, labelList&, labelList&) const [61] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 574. [61] FOAM parallel run aborting [61] [35] --> FOAM FATAL ERROR: [35] in patch:procBoundary35to34 : Local size of patch is 47 (faces). Received from neighbour 45 faceCentres! [35] [35] From function processorPolyPatch::order(const primitivePatch&, labelList&, labelList&) const [35] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 574. [35] FOAM parallel run aborting [35] [61] #0 Foam::error::printStack(Foam::Ostream&)-------------------------------------------------------------------------- An MPI process has executed an operation involving a call to the "fork()" system call to create a child process. Open MPI is currently operating in a condition that could result in memory corruption or other system errors; your MPI job may hang, crash, or produce silent data corruption. The use of fork() (or system() or other calls that create child processes) is strongly discouraged. The process that invoked fork was: Local host: node41.cocoa5 (PID 9388) MPI_COMM_WORLD rank: 61 If you are *absolutely sure* that your application will successfully and correctly survive a call to fork(), you may disable this warning by setting the mpi_warn_on_fork MCA parameter to 0. -------------------------------------------------------------------------- [35] #0 Foam::error::printStack(Foam::Ostream&) in "/home/rus284/OpenFOAM/OpenFOAM- in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" 2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [61] #1 [35] #1 Foam::error::abort()Foam::error::abort() in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [35] #2 in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [61] #2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>)Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/refineMesh" [35] #3 Foam::processorPolyPatch::order(Foam::PstreamBuffers&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&) const in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/refineMesh" [61] #3 Foam::processorPolyPatch::order(Foam::PstreamBuffers&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&) const in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [35] #4 Foam::polyTopoChange::reorderCoupledFaces(bool, Foam::polyBoundaryMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [61] #4 Foam::polyTopoChange::reorderCoupledFaces(bool, Foam::polyBoundaryMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [35] #5 Foam::polyTopoChange::compactAndReorder(Foam::polyMesh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [61] #5 Foam::polyTopoChange::compactAndReorder(Foam::polyMesh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [61] #6 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [35] #6 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/li in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [35] #7 Foam::refinementIterator::setRefinement(Foam::List<Foam::refineCell> const&)nux64GccDPOpt/lib/libdynamicMesh.so" [61] #7 Foam::refinementIterator::setRefinement(Foam::List<Foam::refineCell> const&) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [35] #8 Foam::multiDirRefinement::refineAllDirs(Foam::polyMesh&, Foam::List<Foam::Field<Foam::Vector<double> > >&, Foam::cellLooper const&, Foam::undoableMeshCutter&, bool) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [61] #8 Foam::multiDirRefinement::refineAllDirs(Foam::polyMesh&, Foam::List<Foam::Field<Foam::Vector<double> > >&, Foam::cellLooper const&, Foam::undoableMeshCutter&, bool) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [61] #9 Foam::multiDirRefinement::refineFromDict(Foam::polyMesh&, Foam::List<Foam::Field<Foam::Vector<double> > >&, Foam::dictionary const&, bool) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [35] #9 Foam::multiDirRefinement::refineFromDict(Foam::polyMesh&, Foam::List<Foam::Field<Foam::Vector<double> > >&, Foam::dictionary const&, bool) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [61] #10 Foam::multiDirRefinement::multiDirRefinement(Foam::polyMesh&, Foam::List<int> const&, Foam::dictionary const&) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [35] #10 Foam::multiDirRefinement::multiDirRefinement(Foam::polyMesh&, Foam::List<int> const&, Foam::dictionary const&) in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/li in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [35] #11 bdynamicMesh.so" [61] #11 [35] in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/refineMesh" [35] #12 __libc_start_main[61] in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/refineMesh" [61] #12 __libc_start_main in "/lib64/libc.so.6" [35] #13 in "/lib64/libc.so.6" [61] #13 [61] in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/refineMesh" -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 35 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [35] in "/home/rus284/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/refineMesh" -------------------------------------------------------------------------- mpirun has exited due to process rank 61 with PID 9388 on node node41.cocoa5 exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [node42.cocoa5:05595] 1 more process has sent help message help-mpi-runtime.txt / mpi_init:warn-fork [node42.cocoa5:05595] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages [node42.cocoa5:05595] 1 more process has sent help message help-mpi-api.txt / mpi-abort Code:
--> FOAM Warning : From function refinementIterator in file meshCut/meshModifiers/refinementIterator/refinementIterator.C at line 272 stopped refining.Did not manage to refine a single cell Wanted :0 Code:
[5] Global Coordinate system: [5] normal : (0 0 1) [5] tan1 : (1 0 0) [5] tan2 : (0 1 0) Also, everything goes fine if a do global refinements instead, that is, leaving only refineMesh (without -dict) and checkMesh in the function I'm calling in the last line. Bottom line is that I wasn't able to consistently get just errors or get just warnings. I'm kinda clueless now. Any thoughts? Let me know if you want to see any dictionary. Regis Last edited by Regis_; April 27, 2015 at 19:33. Reason: typos |
April 30, 2015, 14:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: According to the output, it seems that you're using OpenFOAM 2.0.1. This is a considerably old version of OpenFOAM and this is probably a bug that has already been fixed in 2.0.x, 2.1.x, 2.2.x or even in 2.3.x, I don't know in which one. If you had provided a test case, I or anyone else could test it with any of these versions of OpenFOAM.
June 4, 2015, 14:44 |
Regis
Rep Power: 14 |
Thanks Bruno for you reply and sorry for taking long to get back. I understand that the version I'm using is old. I'm using some other libraries written for this version and I will "port" them to a more recent version as soon as I have time.
So I figured out part of my problem. For the sake of future reference, here it is: I had a very coarse background mesh generated via blockMesh. Then using refineMesh several times with slightly larger regions of refinement was causing the issue, because I had less than one cell between these regions. This bug report is totally related to my problem and the solution I just described came from there: http://www.openfoam.org/mantisbt/view.php?id=465. Cheers! |
mesh, parallel, refinemesh |
[mesh manipulation] Unstructured tetrahedral mesh Refinement using REFINEMESH DICT UTILITY.???? POSSIBLE? | saddy | OpenFOAM Meshing & Mesh Conversion | 4 | February 1, 2019 06:58 |
[mesh manipulation] refineMesh Dict | challenger | OpenFOAM Meshing & Mesh Conversion | 2 | January 14, 2011 00:18 |
Meshing support parallel multiple computers! | Kevin | Siemens | 1 | July 26, 2007 20:27 |
running multiple Fluent parallel jobs | Michael Bo Hansen | FLUENT | 8 | June 7, 2006 09:52 |
Fluent cases in parallel across multiple machines | Riaan | FLUENT | 3 | April 11, 2005 12:51 |
