[Other] converting mesh data from tetgen to Openfoam!!!
Like Tree3Likes
  • 1 Post By opedrofunk
  • 1 Post By alexeym
Old   February 15, 2015, 09:43
Default converting mesh data from tetgen to Openfoam!!!
Abhinay
soankerabhinay is on a distinguished road
I am completely new to Openfoam! I did generate tetramesh using TETGEN and trying to convert that mesh into openfoam for heat transfer analysis.
I used tetgenTOFoam but it returns error as shown in the pic!
Does anyone help me with the step by step procedure to convert tetgen to openfoam? I dont see any information about tetgen to openFoam!
Also, can we generate tetramesh in the openfoam without importing it externally? if so, please share the information. Thank you!
soankerabhinay is offline   Reply With Quote
Old   February 16, 2015, 00:48
Peter
opedrofunk is on a distinguished road
You need to have the basic structure of an OpenFOAM case set up to run tetgenToFoam, one which at a minimum contains:
$ tree
├── constant
│** └── polyMesh
└── system
    └── controlDict
Then it will work fine. FYI: If you're looking for a good free preprocessor for tetgen, check this:
http://www.cfd-online.com/Forums/ope...up-tetgen.html
Cheers,
Peter
soankerabhinay likes this.
opedrofunk is offline   Reply With Quote
Old   February 16, 2015, 02:24
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
@opedrofunk As you can see, soankerabhinay tried to convert mesh in one of tutorial cases, so there was basic file structure.
@soankerabhinay I think it is a space in the folder name that mess up the conversion. Try renaming "New folder" into "new-folder".
alexeym is offline   Reply With Quote
Old   February 16, 2015, 14:37
Peter
@alexym Assuming that he correctly copied the complete case to the run directory, I would be inclined to agree with you - spaces in path/file names will throw an error (at least on linux/unix systems). However, this normally yields a different error than the one posted by soankerabhinay. For example:
$ cd New\ Folder/
$ tree
├── constant
│** └── polyMesh
└── system
    └── controlDict
$ tetgenToFoam ~/Desktop/test.1
|  \\    /   O peration     | Version:  2.3.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.x-cf370883644e
Exec   : tetgenToFoam /Users/peter/Desktop/test.1
Date   : Feb 16 2015
Time   : 10:16:09
Host   : "peter"
PID    : 25646
fileName::stripInvalid() called for invalid fileName /Users/peter/OpenFOAM/peter-2.3.x/run/NewFolder
    For debug level (= 2) > 1 this is considered fatal
Abort trap: 6
It may be that windows behaves differently in this case (I don't have access to a windows box to test). Which is why I still suspect the case structure might be off.
Anyway, alexym is right - don't use spaces in file/directory names.
Regards,
Peter
Old   February 16, 2015, 21:01
Abhinay
@Alexeym, Thank you so much! As you said, space was the culprit! It worked when that was fixed. Thanks again.
@opedrofunk, Thank you for the swift response and also for the info about sketchup-tetgen interface, it is such an easy tetgen per-processor to work with
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM nsf OpenFOAM Meshing & Mesh Conversion 86 February 8, 2023 11:30
[Salome] Converting Salome wedge mesh to OpenFOAM anon_q OpenFOAM Meshing & Mesh Conversion 4 March 13, 2019 16:13
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
