February 3, 2015, 09:21 |
Problems with snappyHexMesh
Samuele Z
Rep Power: 19 |
Dear All,
I am attaching my case. I am just trying to mesh a very simple stl file. But something goes wrong: Code:
szampini@archimede:~/Documenti/Afros/CFDSimulations/testRTM$ snappyHexMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.1-262087cdf8db Exec : snappyHexMesh Date : Feb 03 2015 Time : 14:00:49 Host : "archimede" PID : 5434 Case : /home/szampini/Documenti/Afros/CFDSimulations/testRTM nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 0.36 s Overall mesh bounding box : (-249.5 -159.5 -180) (249.5 159.5 -120) Relative tolerance : 1e-06 Absolute matching distance : 0.000595283 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 STLLexer::lex() at ??:? #4 Foam::triSurface::readSTLASCII(Foam::fileName const&) at ??:? #5 Foam::triSurface::readSTL(Foam::fileName const&) at ??:? #6 Foam::triSurface::read(Foam::fileName const&, Foam::word const&, bool) at ??:? #7 Foam::triSurface::triSurface(Foam::fileName const&) at ??:? #8 Foam::triSurfaceMesh::triSurfaceMesh(Foam::IOobject const&, Foam::dictionary const&) at ??:? #9 Foam::searchableSurface::adddictConstructorToTable<Foam::triSurfaceMesh>::New(Foam::IOobject const&, Foam::dictionary const&) at ??:? #10 Foam::searchableSurface::New(Foam::word const&, Foam::IOobject const&, Foam::dictionary const&) at ??:? #11 Foam::searchableSurfaces::searchableSurfaces(Foam::IOobject const&, Foam::dictionary const&, bool) at ??:? #12 at ??:? #13 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #14 at ??:? Errore di segmentazione (core dump creato) szampini@archimede:~/Documenti/Afros/CFDSimulations/testRTM$ Could anyone help, please? Thanks a lot, Samuele |
February 3, 2015, 09:28 |
AFAIK STL file should be in ASCII format. |
February 3, 2015, 09:31 |
Samuele Z
Rep Power: 19 |
You're right, thanks a lot,
Samuele |
[snappyHexMesh] Problems with coarse/unsnapped cells in snappyHexMesh | scareneb | OpenFOAM Meshing & Mesh Conversion | 2 | August 13, 2014 08:13 |
[snappyHexMesh] snappyHexMesh problems 1.5->1.6 | grtabor | OpenFOAM Meshing & Mesh Conversion | 5 | May 18, 2012 04:00 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 03:09 |
[snappyHexMesh] SnappyhexMesh and Symmetryplane | bastil | OpenFOAM Meshing & Mesh Conversion | 10 | October 7, 2008 18:07 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 08:08 |
