[snappyHexMesh] Crash with snappyHexMesh in Foam::triSurface::readSTLASCII
Like Tree1Likes
  • 1 Post By Nucleophobe
Old   August 13, 2014, 10:38
Question Crash with snappyHexMesh in Foam::triSurface::readSTLASCII
H25E
H25E is on a distinguished road
Hi, I'm introducing into the world of CFD, I'll finish my engineering in January and I will make my final work of an introduction in CFD. Now I'm practicing and testing some things and when I tried to mesh a model with snappyHexMesh using a snappyHexMeshdict file which we worked in class as a template I got the following error:
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 yyFlexLexer::yy_try_NUL_trans(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libtriSurface.so"
#4 STLLexer::lex() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libtriSurface.so"
#5 Foam::triSurface::readSTLASCII(Foam::fileName const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libtriSurface.so"
#6 Foam::triSurface::readSTL(Foam::fileName const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libtriSurface.so"
#7 Foam::triSurface::read(Foam::fileName const&, Foam::word const&, bool) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libtriSurface.so"
#8 Foam::triSurface::triSurface(Foam::fileName const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libtriSurface.so"
#9 Foam::triSurfaceMesh::triSurfaceMesh(Foam::IOobjec t const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#10 Foam::searchableSurface::adddictConstructorToTable <Foam::triSurfaceMesh>::New(Foam::IOobject const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#11 Foam::searchableSurface::New(Foam::word const&, Foam::IOobject const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#12 Foam::searchableSurfaces::searchableSurfaces(Foam: :IOobject const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#13
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/snappyHexMesh"
#14 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#15
Segmentation fault (core dumped)
Could someone give me some help here? thank you all.
H25E is offline   Reply With Quote
Old   August 13, 2014, 14:04
Nucleophobe is on a distinguished road
H25E,
Could you post your snappyHexMeshDict file? These kinds of errors can be a little tricky to track down, anything from a missing semicolon to a misspelled word...
Nucleophobe is offline   Reply With Quote
Old   August 13, 2014, 15:04
H25E
Sure Nucleophobe, thanks for your time.
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
PTri.stl
type triSurfaceMesh;
name PTri;
refinementBox
type searchableBox;
min (-0.5 -0.2 -0.5);
max (2.5 0.5 2.5);
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// If local number of cells is >= maxLocalCells on any processor
// switches from from refinement followed by balancing
// (current method) to (weighted) balancing before refinement.
maxLocalCells 100000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 2000000;
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 10;
// Allow a certain level of imbalance during refining
// (since balancing is quite expensive)
// Expressed as fraction of perfect balance (= overall number of cells /
// nProcs). 0=balance always.
maxLoadUnbalance 0.10;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 3;
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
// file "someLine.eMesh";
// level 2;
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
PTri
// Surface-wise min and max refinement level
level (7 7);
// Resolve sharp angles
resolveFeatureAngle 30;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
refinementBox
mode inside;
levels ((1E15 4));
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the locationInMesh is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
locationInMesh (0.0001232 0.232432 0.005424321);
// Whether any faceZones (as specified in the refinementSurfaces)
// are only on the boundary of corresponding cellZones or also allow
// free-standing zone faces. Not used if there are no faceZones.
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 3;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 4.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 0;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 5;
//- Highly experimental and wip: number of feature edge snapping
// iterations. Leave out altogether to disable.
// Do not use here since mesh resolution too low and baffles present
//nFeatureSnapIter 10;
// Settings for the layer addition.
addLayersControls
// Are the thickness parameters below relative to the undistorted
// size of the refined cell outside layer (true) or absolute sizes (false).
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
"(PTri).*"
nSurfaceLayers 1;
// Expansion factor for layer mesh
expansionRatio 1.0;
//- Wanted thickness of final added cell layer. If multiple layers
// is the
// thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
// is the thickness of the layer furthest away from the wall.
// See relativeSizes parameter.
finalLayerThickness 0.3;
//- Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.1;
//- If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
// Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
nGrow 0;
// Advanced settings
//- When not to extrude surface. 0 is flat surface, 90 is when two faces
// make straight angle.
featureAngle 30;
nRelaxIter 3;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 1;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
nSmoothThickness 10;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 0.3;
// Angle used to pick up medial axis points
// Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
minMedianAxisAngle 90;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations. The mesher will exit
// if it reaches this number of iterations; possibly with an illegal
// mesh.
nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 65;
//- Max skewness allowed. Set to <0 to disable.
maxBoundarySkewness 20;
maxInternalSkewness 4;
//- Max concaveness allowed. Is angle (in degrees) below which concavity
// is allowed. 0 is straight face, <0 would be convex face.
// Set to 180 to disable.
maxConcave 80;
//- Minimum pyramid volume. Is absolute volume of cell pyramid.
// Set to a sensible fraction of the smallest cell volume expected.
// Set to very negative number (e.g. -1E30) to disable.
minVol 1e-13;
//- Minimum quality of the tet formed by the face-centre
// and variable base point minimum decomposition triangles and
// the cell centre. This has to be a positive number for tracking
// to work. Set to very negative number (e.g. -1E30) to
// disable.
// <0 = inside out tet,
// 0 = flat tet
// 1 = regular tet
minTetQuality 1e-30;
//- Minimum face area. Set to <0 to disable.
minArea -1;
//- Minimum face twist. Set to <-1 to disable. dot product of face normal
//- and face centre triangles normal
minTwist 0.02;
//- minimum normalised cell determinant
//- 1 = hex, <= 0 = folded or flattened illegal cell
minDeterminant 0.001;
//- minFaceWeight (0 -> 0.5)
minFaceWeight 0.02;
//- minVolRatio (0 -> 1)
minVolRatio 0.01;
//must be >0 for Fluent compatibility
minTriangleTwist -1;
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- amount to scale back displacement at error points
errorReduction 0.75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
Old   August 13, 2014, 15:18
Okay, I don't see anything alarming there.
Is "PTri.stl" an ASCII file, or binary? If it's binary, try converting it to an ASCII file and see if that changes your error output (you can do this with the surfaceConvert utility).
Old   August 13, 2014, 15:36
H25E
I haven't understood the question I modeled it in solidworks and then I saved it in .stl format.
Old   August 13, 2014, 15:41
Okay, open the STL file in a text editor (notepad on Windows, vim/emacs/nano/gedit on Linux...). Do you see lines of code like this:
solid
facet normal ni nj nk
outer loop
vertex v1x v1y v1z
vertex v2x v2y v2z
vertex v3x v3y v3z
endloop endfacet
or do you see gibberish? If you see plain text as in the above, the file is ASCII, but I'm guessing it's binary.
So, try running:
mv PTri.stl PTri.binary.stl
surfaceConvert -scale 1 PTri.binary.stl PTri.stl
from the triSurface directory, and then re-run snappyHexMesh. I'm not sure this is even the problem, as I think sHM supports binary STL files in the newer versions, but this is something you should at least be aware of for the future.
-Nuc
yuan_neu likes this.
Old   August 13, 2014, 16:06
H25E
The file its binary, whats the difference between binary and ascii file?
Executing the second command i get this error:
Reading : "PTri.binary.stl"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/surfaceConvert"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
PD: I'm running openfoam from an ubuntu pendrive, I don't know if that could be the problem.
Old   August 13, 2014, 16:13
Okay, maybe try renaming the file extension to .stlb? See thread below:
http://www.cfd-online.com/Forums/ope...ascii-stl.html
Otherwise consider posting the STL file. OpenFOAM seems to crash upon trying to read it.
Old   August 13, 2014, 18:20
H25E
Good, it worked, I changed the name to PTri.stlb and that way openfoam has been able to work with that file. The first think i have done is change the format to ascii with your previous command surfaceconverter. Once I had the model in ascii format i have tried to mesh again and now i get that new error:
--> FOAM FATAL ERROR:
Multiple outside loops:
0
From function combineFaces::getOutsideFace(const indirectPrimitivePatch&)
in file polyTopoChange/polyTopoChange/combineFaces.C at line 420.
FOAM aborting
#1 Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::combineFaces::getOutsideFace(Foam::Primitive Patch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libautoMesh.so"
#6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, Foam::snapParameters const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libautoMesh.so"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted (core dumped)
I have found that thread http://www.cfd-online.com/Forums/ope...ide-loops.html but i think that I don't really understand what i have to modify.
Thanks for your time again
PD: One question, the numbers introduced into the blockMeshdict or snappyHexMeshdict are in meters or millimeters?
Old   August 13, 2014, 18:30
Can you post a screenshot of your case geometry? Are you doing external flow, or internal flow? You may need to refine your blockMesh...
Also, did sHM (snappyHexMesh) write out any data to folders? You should see a folder for each step in the process: 1 - castellated mesh, 2 - snapped mesh, and 3 - mesh with layers. If you got any of these folders to output, try loading the results in ParaView to see if that gives any clues.
Also, for your earlier question:
http://www.cs.umd.edu/class/sum2003/.../asciiBin.html
Old   August 13, 2014, 18:49
H25E
External flow, here you have a screenshot of my model, a silly example for practice:
And that's the background mesh that I use:
sHM has created one folder, the castellated mesh one (1). When I try to represent it on paraFoam appears an empty prism.
Otherwise, the numbers that are introduced into blockMeshdict or sHM are in meters or millimeters? And thanks for the link
Old   August 20, 2014, 11:51
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
The numbers are always in meters: http://www.openfoam.org/docs/user/bl...#x25-1420005.3
Blog: sourceflux.de/blog
"The OpenFOAM Technology Primer": sourceflux.de/book
Twitter: @sourceflux_de
Interested in courses on OpenFOAM?
jhoepken is offline   Reply With Quote
Old   August 20, 2014, 12:17
H25E,
I think you block mesh may be a *little* too coarse for your case. Try increasing you refinement, or decreasing the size of your domain (since this is just a test case).
Also, make sure that your "locationInMesh" is set correctly. If this point is outside of the main domain or inside of your prism, you will run into problems.
Good luck, keep us posted on your progress.
Old   August 23, 2014, 05:22
H25E
Thanks you all,
Solidworks allows to work with meters and millimeters and for some reason, I suppose that an error in the conversion to stl, my model had 2 km length instead of 2 m. Solving that, correcting blockMeshdict and sHMdict to the new geometry of 2 m, and creating a denser mesh I get the following error when I launch sHM:
Create mesh for time = 0
Read mesh in = 1.55 s
Overall mesh bounding box : (-1 -0.5 -0.5) (3 1 4)
Relative tolerance : 1e-06
Absolute matching distance : 6.20484e-06
Reading refinement surfaces.
Read refinement surfaces in = 0 s
Reading refinement shells.
Refinement level 3 for all cells inside refinementBox
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0 s
Reading features.
Read features in = 0 s
Determining initial surface intersections
Number of cells in mesh:250000 does not equal size of cellLevel:1
This might be because of a restart with inconsistent cellLevel.
From function hexRef8::getLevel0EdgeLength() const
in file polyTopoChange/polyTopoChange/hexRef8.C at line 357.
FOAM aborting
#2 Foam::hexRef8::getLevel0EdgeLength() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#3 Foam::hexRef8::hexRef8(Foam:olyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::refinementHistory const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#4 Foam::meshRefinement::meshRefinement(Foam::fvMesh& , double, bool, Foam::refinementSurfaces const&, Foam::refinementFeatures const&, Foam::shellSurfaces const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libautoMesh.so"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Old   August 25, 2014, 22:38
Smile
  #15
H25E,
It sounds like you need to clean up your case directory. You shouldn't have any directories with numbers as names (remove 0, 1,2,3, etc. ). After removing all the extra directories, run blockMesh, and then try snappyHexMesh again.
More information here: http://www.cfd-online.com/Forums/ope...celllevel.html
If you run into anymore trouble, I recommend you do a quick forum search with keywords from your error message, as you might get answers faster that way.
Good luck again! The first time is the hardest, once you get the hang of sHM it's not so bad - a great tool in fact.
-Nuc
Old   August 26, 2014, 09:54
H25E
Well, after five more error messages I'm stagnant again. When sHM was writing mesh on folder 2 it crashed with a fatal IO error, then I erased the sHM folders and I run it again. It crashed again with the same kind of error but now writing mesh in the folder 1. Then I erased also the blockMesh files and when i tried to blocKmesh again it crashed with the same error too, exactly this:
--> FOAM FATAL IO ERROR:
error in IOstream "/home/caelinux/Desktop/Test/constant/polyMesh/points" for operation Ostream& operator<<(Ostream&, const Scalar&)
file: /home/caelinux/Desktop/Test/constant/polyMesh/points at line 5621.
From function IOstream::check(const char*) const
in file db/IOstreams/IOstreams/IOstream.C at line 99.
FOAM exiting
I don't know why it happens, I modified the refinement box and the max local and global cells due to I was running out of memory but I guess this is not the reason, it seems like a type variable error. I searched in the forum but some post weren't answered and others I didn't understand it.
Thanks for your time.
Old   October 4, 2014, 14:22
Retired Super Moderator
Bruno Santos
Greetings to all!
@H25E: I've arrived a late to the discussion, but from your latest description, I would say that you're running out of disk space, which is why it's stopping earlier and earlier in the meshing process.
Run the following command, to check if you have enough disk space in the folder you're working on:
df -h $PWD
Best regards,
Bruno
Old   October 7, 2014, 17:16
H25E
Finally I reinstalled linux some weeks ago, so maybe it was the reason. Thanks anyway for your answer.
mesh error, openfoam, snappyhexmesh
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] snappyHexMesh large parallel case crash C-L OpenFOAM Meshing & Mesh Conversion 0 August 15, 2017 10:40
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
[snappyHexMesh] SnappyHexMesh crash (floating point exception while snappying) Frank_uk OpenFOAM Meshing & Mesh Conversion 1 January 9, 2016 07:19
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
