[Gmsh] Save mesh from command line in gmsh
Like Tree4Likes
  • 4 Post By Jefferson_dhv
Old   August 4, 2014, 20:58
Default Save mesh from command line in gmsh
Jefferson Vieira
Jefferson_dhv is on a distinguished road
Hi all,
I need to read a stl file and save it as geo from the command line. Does anyone know how to do it?
Thanks in advance,
Jefferson
Jefferson_dhv is offline   Reply With Quote
Old   August 5, 2014, 11:24
Jefferson Vieira
I just solved it.
Actually the output file didn't need to be .geo, it could be .msh, so I just used th following code:
gmsh <input file> -1 -o <output file>.msh
I've put the -1 so gmsh has a mesh to output, but in my case it does not make any changes.
geo, gmsh, mesh, save, stl
GMSH extrude a boundary layer from an unstructured Mesh Hillie Mesh Generation & Pre-Processing 2 July 7, 2017 04:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[Gmsh] STL on Gmsh + Mesh on Snappy adrieno OpenFOAM Meshing & Mesh Conversion 3 May 20, 2016 13:22
[Gmsh] background mesh in gmsh Nick_J OpenFOAM Meshing & Mesh Conversion 1 March 20, 2013 05:20
