[snappyHexMesh] snappyHexMesh problem with eMesh file |
July 26, 2014, 19:36 |
Rep Power: 12 |
I'm trying to create a mesh around a NACA 0015 airfoil using foam-extend-3.1 with snappyHexMesh. I have already run the surfaceFeatureExtract command to create an eMesh file for the airfoil. I'm getting the following error message when I run the snappyHexMesh command: Code:
Reading external feature lines --> FOAM FATAL IO ERROR: Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 19 the word 'externalStart' file: /Volumes/foam-extend-3.1/tutorials/multiphase/interFoam/ras/NACA0015Test/constant/triSurface/NACA0015.eMesh at line 19. From function Istream::readBegin(const char*) in file db/IOstreams/IOstreams/Istream.C at line 86. FOAM exiting https://www.dropbox.com/s/45nv9u8le7...015%20Test.zip snappyHexMesh runs without any errors when I comment out the featureEdgeMesh in snappyHexMeshDict. But it seems to ignore my stl file because I cannot see the NACA airfoil in the mesh. I really appreciate any help you can provide. Ingöö |
September 17, 2014, 19:29 |
Expected a '(' while reading VectorSpace<Form Have a look at your emesh file go to line 19 and check for the missing (, maybe you edited it with no intentions. |
October 22, 2014, 14:44 |
Seroga
Rep Power: 15 |
Is it possible to use snappyHexMesh without emesh-files?
June 12, 2015, 05:28 |
Stephanie
Rep Power: 11 |
Hello everyone,
I am trying to use SnappyHexMesh to snap a foil geometry out of an rectangular (small box). I use the foam extend 3.1 version. Unfortunately I am not able to produce an emesh. Could anyone help me or send me the correct command? I would be very grateful. These are the commands I used: ideasUnvToFoam cad/name.unv surfaceFeatureExtract -includedAngle 150 constant/triSurface/name.stl name (here the eMesh normaly is produced..but the command just produce the .obj files) snappyHexMesh -overwirte --> here I gut this message because of the missing emesh file --> FOAM FATAL IO ERROR: problem while reading header for object foil_mesh.eMesh file: /home/stephanie/Schreibtisch/SnappyHexMesh_NACA4518_150611/adaptiveMesh/constant/triSurface/foil_mesh.eMesh at line 2. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 69. FOAM exiting best regards, Stephie |
June 12, 2015, 06:08 |
Stephanie
Rep Power: 11 |
Yes that is correct and what I do.
My background box is an .unv file which I convert to OpenFoam first. The geometry of the foil is a stl file, which I would like to snap out of the box. How I wrote, I use the following command surfaceFeatureExtract -includedAngle 150 constant/triSurface name.stl name My current problem is, that this command does not produce any eMesh file. So I guess, the command is not correct? |
June 12, 2015, 06:21 |
#7 | ||
Ok, now I get it, I think the command is right.
Maybe a trivial error, you have to set the name of the stl file, not the name of your background mesh Quote:
In any case I generally use a surfaceFeatureExctractDict in the system directory like: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object surfaceFeatureExtractDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // amiRot1.stl { extractionMethod extractFromSurface; // extractFromFile or extractFromSurface extractFromSurfaceCoeffs {includedAngle 135;} writeObj yes; // Write options } |
June 12, 2015, 06:36 |
Stephanie
Rep Power: 11 |
Hey,
thank you for your support. But the stl name is okay and here is my surfaceFeatureExtractDict /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object surfaceFeatureExtractDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // foil_mesh.stl { // How to obtain raw features (extractFromFile || extractFromSurface) extractionMethod extractFromSurface; extractFromSurfaceCoeffs { // Mark edges whose adjacent surface normals are at an angle less // than includedAngle as features // - 0 : selects no edges // - 180: selects all edges includedAngle 150; } // Write options // Write features to obj format for postprocessing writeObj yes; } // ************************************************** *********************** // May I send you a dropbox link with my case? |
June 12, 2015, 06:45 |
#9 |
ok. I'll wait for it. I'll give it a try. You can post it here, or send to e-keneso@libero.it
June 12, 2015, 17:56 |
#10 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
(edit: Moved my post for the answer I gave for the repeated question that was made on another thread.) Last edited by wyldckat; June 13, 2015 at 14:35. Reason: see "edit:" |
June 13, 2015, 14:20 |
#11 |
i performed some tests, but verify yourself what I'm writing: Foam extended 3.1 can't perform the command surfaceFestureExctract with a dictionary in the system folder, f I type the command surface feature extract in Foam ext. I got this error message: Code:
Usage: surfaceFeatureExtract <surface> <output set> [-minElem number of edges in feature] [-minLen cumulative length of feature] [-deleteBox ((x0 y0 z0)(x1 y1 z1))] [-subsetBox ((x0 y0 z0)(x1 y1 z1))] [-set input feature set] [-includedAngle included angle [0..180]] [-case dir] [-noFunctionObjects] [-help] [-doc] [-srcDoc] I wasn't able to open neither the stl file and the edges file with paraview, It crashes all the time, only blender gave me support; I suggest you to export the stl in other ways, cause it seems that your cad program is not performing it so good. Hope this can help. Ciao Michele |
June 15, 2015, 05:58 |
#12 |
Stephanie
Rep Power: 11 |
Hallo Michele, hello Bruno,
thank you for your support. Finally I used your hint and create the emesh with OpenFOAM 2.4 and put it into foam-extend. Now it works...today I was able to snap the foil geometry into the backgroundmesh. best regards, Stephie |
March 24, 2019, 03:40 |
#13 |
Raj Kiran
Rep Power: 8 |
Hello Foamers,
I know this is very old post but I am facing few issues with eMesh. When I run the command surfaceFeatureExtract it is giving .eMesh files with zero points and zero edges . Couldn't figure out the reason. Regards, Raj Kiran. |
March 24, 2019, 14:46 |
#14 | |
Bruno Santos
Rep Power: 128 |
surfaceCheck constant/triSurface/yourFileName.stl
emesh, naca 0015, snappyhexmesh, surfacefeatureextract |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 15:30 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 18:25 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
