[mesh manipulation] StitchMesh and Interfaces problem |
June 25, 2014, 19:15 |
Luca
Rep Power: 15 |
Dear All,
after running fluentMeshToFoam and stitchMesh I get the following output from checkMesh: Code:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 21680 internal points: 0 faces: 42248 internal faces: 20572 cells: 10470 faces per cell: 6 boundary patches: 9 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 10470 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 5235 cells to cellSet region0 <<Writing region 1 with 5235 cells to cellSet region1 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology WALL-RIB-up 60 122 ok (non-closed singly connected) WALL-up 95 194 ok (non-closed singly connected) WALL-RIB-down 60 122 ok (non-closed singly connected) WALL-down 95 194 ok (non-closed singly connected) OUTLET 98 200 ok (non-closed singly connected) INLET 98 200 ok (non-closed singly connected) INTERFACE-up 115 232 ok (non-closed singly connected) INTERFACE-down 115 232 ok (non-closed singly connected) frontAndBackPlanes 20940 21680 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 -0.2506) (22 12 0.2506) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (-5.82137e-19 -2.01201e-17 8.24694e-19) OK. Max cell openness = 1.56737e-16 OK. Max aspect ratio = 4.64471 OK. Minimum face area = 0.0100249. Maximum face area = 0.232792. Face area magnitudes OK. Min volume = 0.0050245. Max volume = 0.0415455. Total volume = 128.307. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 5.28606e-13 OK. Coupled point location match (average 0) OK. Mesh OK. Time = 1 Mesh stats points: 21664 internal points: 0 faces: 42241 internal faces: 20795 cells: 10470 faces per cell: 6.02063 boundary patches: 9 point zones: 1 face zones: 3 cell zones: 0 Overall number of cells of each type: hexahedra: 10346 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 124 Breakdown of polyhedra by number of faces: faces number of cells 7 72 8 20 9 24 10 8 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology WALL-RIB-up 60 122 ok (non-closed singly connected) WALL-up 95 194 ok (non-closed singly connected) WALL-RIB-down 60 122 ok (non-closed singly connected) WALL-down 95 194 ok (non-closed singly connected) OUTLET 98 198 ok (non-closed singly connected) INLET 98 198 ok (non-closed singly connected) INTERFACE-up 0 0 ok (empty) INTERFACE-down 0 0 ok (empty) frontAndBackPlanes 20940 21664 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 -0.2506) (22 12 0.2506) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (-6.05475e-19 1.44683e-17 8.57756e-19) OK. Max cell openness = 1.56737e-16 OK. Max aspect ratio = 4.64471 OK. Minimum face area = 0.00353238. Maximum face area = 0.232792. Face area magnitudes OK. Min volume = 0.0050245. Max volume = 0.0415455. Total volume = 128.307. Cell volumes OK. Mesh non-orthogonality Max: 57.2336 average: 3.50758 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.52343 OK. Coupled point location match (average 0) OK. Mesh OK. End Do I have to delete them from this file (and accordingly change the number of patches at the top of the file? And should i then always use ciclicAMI BC for them in the IO field files in the /0 directory? Actually I have changed the word interface to wall in the .msh file before running fluentMeshToFoam otherwise the interfaces wouldn't have been written to the boundary file and I would have not been able to run stitchMesh (no interfaces were found). Is this correct? Thank you in advance for your help. Regards, Luca |
June 25, 2014, 20:46 |
#2 | |||
Hi Luca,
Bye! |
June 26, 2014, 07:33 |
Luca
Rep Power: 15 |
Dear All,
I found the solution to my problem. The mesh generated with Gambit contained two overlapping interfaces which has been defined as type interface. Before using stitchMesh I edited the .msh file and changed at the bottom of it interface to wall. Then I ran fluentMeshToFoam. Then with checkMesh I verified that I had two distinct regions, i.e. two separate volumes (*Number of regions: 2). Now I have modified the field files in the 0 directory (p, U etc.) according to the patches listed in the file ./constant/polymesh/boundary. I have assigned a boundary conditions to the patches INTERFACE-up and INTERFACE-down as well. After that I made the following steps (note that the directory is named 1 because of the deltaT in the controlDict. You can change it of course to obtain another directory name): Code:
stitchMesh INTERFACE-up INTERFACE-down rm -r ./constant/polymesh mv ./1/polymesh ./constant rm -r 1/ I didn't remove the INTERFACE patches neither from the boundary file (even if their face number is zero (nfaces 0)) nor from the field files (p, U, etc.). ...and I could run my case with a non-conformal mesh. Hope it helps. Regards, Luca |
June 27, 2014, 08:50 |
#4 | |
Eloïse
Rep Power: 14 |
If you want to remove the patches with 0 faces, you can run the command "createPatch" with this createPatchDict in your system/ directory: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync false; // Patches to create. patches ( ); // ************************************************************************* // As you noticed, it is not absolutely needed for the simulation to run, but it makes it cleaner I hope that helps! Regards, Eloïse |
June 27, 2014, 16:43 |
Luca
Rep Power: 15 |
Dear Eloïse,
nice tip...I didn't know it but it works perfectly! Thanks a lot! Regards, Luca |
August 8, 2015, 18:29 |
J.-H. Wang
Rep Power: 16 |
Thanks. I followed the instruction and the interface is stitched as advertised. I am curious though: this process creates several more severly nonorthogonal faces (>70 degrees). Because I am running DES, I am worried that this would have adverse effects on the accuracy. Have you tried to compare this approach (which obviously works topologically), and the AMI approach by directly assigning BC to interfaces? Which one is more appropriate in terms of accuracy? |
interfaces, stitchmesh |
[mesh manipulation] Problem with mesh quality after using mergeMesh and stitchMesh | julianschl | OpenFOAM Meshing & Mesh Conversion | 7 | May 23, 2015 13:42 |
stitchMesh problem | dogan | OpenFOAM Pre-Processing | 18 | October 11, 2014 14:40 |
[mesh manipulation] stitchMesh problems along patch edges | ribe | OpenFOAM Meshing & Mesh Conversion | 2 | March 5, 2013 16:25 |
[mesh manipulation] startFace problem using stitchMesh | Attesz | OpenFOAM Meshing & Mesh Conversion | 2 | April 12, 2012 09:15 |
[mesh manipulation] stitchMesh and mergeMeshes removal of interfaces | flowris | OpenFOAM Meshing & Mesh Conversion | 6 | July 16, 2010 13:06 |
