[mesh manipulation] mergeMeshes and stitchMesh in parallel? |
June 6, 2014, 04:16 |
Samuele Z
Rep Power: 18 |
Dear all,
are the 2 commands mergeMeshes and stitchMesh usable in parallel? Thanks a lot, Samuele |
June 6, 2014, 10:21 |
Rep Power: 16 |
as far as I know both programs are not able to run in parallel. When entering Code:
mergeMeshes -help Code:
stitchMesh -help Both operations intuitively seem to be pretty hard to do in parallel. Think of two threads altering a mesh within the same region at the same time. This is going to be a mess unless at lot of synchronization is done... Cutter |
[mesh manipulation] stitchMesh perfect vs partial | Eloise | OpenFOAM Meshing & Mesh Conversion | 2 | October 25, 2017 10:47 |
[mesh manipulation] StitchMesh sigFpe / bad point | liquidspoon | OpenFOAM Meshing & Mesh Conversion | 2 | November 29, 2015 14:19 |
[mesh manipulation] using mergeMeshes and stitchMesh | Lada | OpenFOAM Meshing & Mesh Conversion | 2 | October 13, 2011 15:04 |
[mesh manipulation] stitchMesh and mergeMeshes removal of interfaces | flowris | OpenFOAM Meshing & Mesh Conversion | 6 | July 16, 2010 12:06 |
[mesh manipulation] MergeMeshes and stitchMesh problem | flo | OpenFOAM Meshing & Mesh Conversion | 6 | May 10, 2010 10:40 |
