[mesh manipulation] why splitMeshRegions creates extra domains? |
June 4, 2014, 12:55 |
Sergey
Rep Power: 13 |
Hello!
I'm trying to setup a conjugate heat transfer case. I've solid and fluid domain and have STL surfaces for them. surfaceCheck says that my STL are OK Code:
surfaceCheck solid.stl /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x-37940e0cd1ae Exec : surfaceCheck solid.stl Date : Jun 04 2014 Time : 11:50:09 Host : "ubuntu" PID : 10414 Case : /media/ubuntu/run/UCcases/UCsideOptShortNE_run/constant/triSurface nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Reading surface from "solid.stl" ... Statistics: Triangles : 5250 Vertices : 2475 Bounding Box : (0 -0.00201 -0.000606) (0.002424 0.001414 0.003838) Region Size ------ ---- solid_to_fluid 4586 minX 154 maxX 154 minY 2 maxY 174 minZ 90 maxZ 90 Surface has no illegal triangles. Triangle quality (equilateral=1, collapsed=0): 0 .. 0.05 : 0.219238 0.05 .. 0.1 : 0.063619 0.1 .. 0.15 : 0.0548571 0.15 .. 0.2 : 0.0758095 0.2 .. 0.25 : 0.104762 0.25 .. 0.3 : 0.0190476 0.3 .. 0.35 : 0.0624762 0.35 .. 0.4 : 0.0647619 0.4 .. 0.45 : 0.0175238 0.45 .. 0.5 : 0.0247619 0.5 .. 0.55 : 0.0613333 0.55 .. 0.6 : 0.0409524 0.6 .. 0.65 : 0.0281905 0.65 .. 0.7 : 0.0148571 0.7 .. 0.75 : 0.0186667 0.75 .. 0.8 : 0.0144762 0.8 .. 0.85 : 0.00152381 0.85 .. 0.9 : 0.035619 0.9 .. 0.95 : 0.0373333 0.95 .. 1 : 0.0401905 min 3.65063e-05 for triangle 2652 max 0.997319 for triangle 654 Edges: min 5.32471e-05 for edge 1270 points (0.00159507 -0.00101 0.00272163)(0.001616 -0.00101 0.00277059) max 0.00506211 for edge 7513 points (0 -0.00201 -0.000606)(0.002424 -0.00201 0.003838) Checking for points less than 1e-6 of bounding box ((0.002424 0.003424 0.004444) meter) apart. Found 0 nearby points. Surface is closed. All edges connected to two faces. Number of unconnected parts : 1 Number of zones (connected area with consistent normal) : 1 End additionally to solid and fluid domains it creates a number of spurious domains named domain1, domain2, domain3... each consisting of few cells. Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x-37940e0cd1ae Exec : splitMeshRegions -cellZones -overwrite Date : Jun 04 2014 Time : 11:35:20 Host : "ubuntu" PID : 10295 Case : /media/ubuntu/run/UCcases/UCsideOptShortNE_run nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Creating single patch per inter-region interface. Trying to match regions to existing cell zones. Number of regions:88 Writing region per cell file (for manual decomposition) to "/media/ubuntu/run/UCcases/UCsideOptShortNE_run/constant/cellToRegion" Writing region per cell as volScalarField to "/media/ubuntu/run/UCcases/UCsideOptShortNE_run/0/cellToRegion" Region Cells ------ ----- 0 82068 1 306355 2 233478 3 2 4 1 5 1 6 2 7 1 8 2 9 1 10 1 11 17 12 10 13 1 14 8 15 1 16 1 17 3 18 1 19 13 20 8 21 1 22 1 23 1 24 1 25 1 26 1 27 1 28 2 29 2 30 1 31 1 32 1 33 1 34 1 35 1 36 1 37 1 38 2 39 1 40 1 41 1 42 2 43 1 44 1 45 1 46 1 47 1 48 1 49 1 50 1 51 13 52 1 53 8 54 1 55 1 56 2 57 1 58 2 59 1 60 2 61 1 62 1 63 1 64 1 65 1 66 1 67 1 68 2 69 1 70 1 71 1 72 1 73 1 74 1 75 1 76 2 77 2 78 1 79 1 80 2 81 1 82 2 83 1 84 1 85 1 86 1 87 1 Region Zone Name ------ ---- ---- 0 -1 domain0 1 1 solid 2 0 fluid 3 -1 domain3 4 -1 domain4 5 -1 domain5 6 -1 domain6 7 -1 domain7 8 -1 domain8 9 -1 domain9 10 -1 domain10 11 -1 domain11 12 -1 domain12 13 -1 domain13 14 -1 domain14 15 -1 domain15 16 -1 domain16 17 -1 domain17 18 -1 domain18 19 -1 domain19 20 -1 domain20 21 -1 domain21 22 -1 domain22 23 -1 domain23 24 -1 domain24 25 -1 domain25 26 -1 domain26 27 -1 domain27 28 -1 domain28 29 -1 domain29 30 -1 domain30 31 -1 domain31 32 -1 domain32 33 -1 domain33 34 -1 domain34 35 -1 domain35 36 -1 domain36 37 -1 domain37 38 -1 domain38 39 -1 domain39 40 -1 domain40 41 -1 domain41 42 -1 domain42 43 -1 domain43 44 -1 domain44 45 -1 domain45 46 -1 domain46 47 -1 domain47 48 -1 domain48 49 -1 domain49 50 -1 domain50 51 -1 domain51 52 -1 domain52 53 -1 domain53 54 -1 domain54 55 -1 domain55 56 -1 domain56 57 -1 domain57 58 -1 domain58 59 -1 domain59 60 -1 domain60 61 -1 domain61 62 -1 domain62 63 -1 domain63 64 -1 domain64 65 -1 domain65 66 -1 domain66 67 -1 domain67 68 -1 domain68 69 -1 domain69 70 -1 domain70 71 -1 domain71 72 -1 domain72 73 -1 domain73 74 -1 domain74 75 -1 domain75 76 -1 domain76 77 -1 domain77 78 -1 domain78 79 -1 domain79 80 -1 domain80 81 -1 domain81 82 -1 domain82 83 -1 domain83 84 -1 domain84 85 -1 domain85 86 -1 domain86 87 -1 domain87 Thank you! |
June 5, 2014, 20:02 |
Hello Sergey,
me too I am facing exactly the same problem and I have no idea why those extra domains are created. I just have two clean STL, two regions one fluid, one solid, like you no errors, snappyHexMesh OK, checkMesh OK, yet splitMeshRegion sees 5 regions Code:
Number of regions:5 Region Cells ------ ----- 0 6406 1 7097 2 390 3 5 4 4 Region Zone Name ------ ---- ---- 0 -1 domain0 1 1 boxAround 2 0 channel 3 -1 domain3 4 -1 domain4 One thing that I noticed is that if I increase in snappyHexMesh the refinement level, splitMeshRegions will create even more unwanted domains: Code:
Region Cells ------ ----- 0 3207344 1 3505266 2 306361 3 1 4 1 5 1 6 1 7 1 8 1 9 1 10 1 11 1 12 1 13 1 14 1 15 1 Region Zone Name ------ ---- ---- 0 1 boxAround 1 -1 domain1 2 0 channel 3 -1 domain3 4 -1 domain4 5 -1 domain5 6 -1 domain6 7 -1 domain7 8 -1 domain8 9 -1 domain9 10 -1 domain10 11 -1 domain11 12 -1 domain12 13 -1 domain13 14 -1 domain14 15 -1 domain15 Last edited by donQi; June 5, 2014 at 21:32. |
June 6, 2014, 12:44 |
Sergey
Rep Power: 13 |
Hi donQi!
I found this discussion http://www.cfd-online.com/Forums/ope...meshing-3.html but didn't find solution to my problem. One possible way to circumvent this issue is to mesh your domains separataly (which of course will the meshes at the boundary inconsisten) and to create a coupled case manually using thouse meshes. Please let me know if you find the way to fix the problem with extra domains. Sergey |
June 7, 2014, 12:43 |
Dan Nielsen
Rep Power: 12 |
Hey you two
I just had the same problem my extra domains cam from voids in my sti file. so if you hav a hole in your CAD file it will give you an extra domain Dan. |
June 7, 2014, 17:50 |
Sergey
Rep Power: 13 |
Dear Dan,
thank you for your reply. I thought of this, but can't imagine where the void may come from. I created stl in salome by separating surfaces of a solid domain created in a CAD. Initial geometry consisted of a two solid domains and there were no holes between them. |
June 7, 2014, 19:35 |
Derek Mitchell
Rep Power: 13 |
i ve seen it when the cells at the joining between regions are poor match with each other
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET |
June 7, 2014, 21:49 |
Sergey
Rep Power: 13 |
Hi Derek!
Can you suggest any cure for this? |
June 8, 2014, 05:41 |
Derek Mitchell
Rep Power: 13 |
It's all about mesh design: making the mesh from one region to the next, one block to the next, have matching cell faces... and making the split along cell boundaries.
Also make sure you delete the file structures created from the phantom regions properly, otherwise you will keep seeing them even when you have fixed the problem.
April 28, 2016, 09:49 |
have the same problem even with blockMesh
#9 |
Rep Power: 14 |
I also have the same problem even with blockMesh. I designed a simple cube using blockMesh with coarse and fine mesh, just to diagnose where the problem is, but I keep seeing extra {domain**} hanging around. I couldn't really find a logical reasoning to at least convince myself where and why this is happening. Let me know if you could come up with a solution.
Best, Smran |
December 22, 2020, 05:14 |
#10 |
Jerry
Is this problem solved?
May 31, 2022, 06:54 |
You must have made some errors in creating regions
#11 |
Dasarathan Sampath
Rep Power: 4 |
Please verify the regions. You must have missed some volumes in any of the regions.
[mesh manipulation] Regroup multiple domains (splitMeshRegions) | alexvaleije | OpenFOAM Meshing & Mesh Conversion | 0 | February 14, 2019 10:31 |
[snappyHexMesh] MultiRegions: Snappy creates extra domains between Regions | Cartuns11 | OpenFOAM Meshing & Mesh Conversion | 3 | January 22, 2018 09:39 |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 10:26 |
[snappyHexMesh] Multi region meshing with SHM creates extra regions | Dav3dum | OpenFOAM Meshing & Mesh Conversion | 0 | August 8, 2016 09:54 |
[snappyHexMesh] snappyHexMesh: extra domains domain1 domain2 ... appear | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | November 29, 2015 07:43 |
