[Commercial meshers] Illegal cell label -1, error in mesh-conversion, icem
Like Tree3Likes
  • 1 Post By Tobias Adam
  • 1 Post By olesen
  • 1 Post By Isaiah_HZ
Old   June 2, 2014, 06:43
Default Illegal cell label -1, error in mesh-conversion, icem
Tobias Adam
Tobias Adam is on a distinguished road
Zone: 19 name: INLET type: velocity-inlet. Reading zone data...done.
Zone: 20 name: TRAILING-EDGE type: wall. Reading zone data...done.
FINISHED LEXING
Creating patch 0 for zone: 15 name: OUTLET type: outlet-vent
Creating patch 1 for zone: 16 name: SHROUD type: wall
Creating patch 2 for zone: 17 name: NABE type: wall
Creating patch 3 for zone: 18 name: BLADE type: wall
Creating patch 4 for zone: 19 name: INLET type: velocity-inlet
Creating patch 5 for zone: 20 name: TRAILING-EDGE type: wall
patch 0 from Fluent indices: 0 to: 21355 type: outlet-vent
patch 1 from Fluent indices: 21356 to: 24308 type: wall
patch 2 from Fluent indices: 24309 to: 26339 type: wall
patch 3 from Fluent indices: 26340 to: 212537 type: wall
patch 4 from Fluent indices: 212538 to: 214840 type: velocity-inlet
patch 5 from Fluent indices: 214841 to: 223233 type: wall
--> FOAM FATAL ERROR:
Illegal cell label -1 in neighbour addressing for face 0
From function polyMesh::initMesh()
in file meshes/polyMesh/polyMeshInitMesh.C at line 65.
[/CODE]
Does anybody have some experience with this?
I didnīt find this error in google, so I hope here is someone who can help me.
Otherwise I just to do a new mesh with Icem.
Thank you so far.
Best regards
Tobi
Tobias Adam is offline   Reply With Quote
Old   June 2, 2014, 07:07
Tobias Adam
got it...
I simply forgot the volume mesh...
Shame on me for this thread....
vijy likes this.
Old   May 6, 2015, 03:59
Default i have the same problem
behrouz
behrouz is on a distinguished road
Originally Posted by Tobias Adam View Post
got it...
hi i have the same problem and i cant understand it,what exactly you do to fix your thread??
behrouz is offline   Reply With Quote
Old   May 6, 2015, 07:44
Cool
behrouz
oh oh,i forgot volum mesh to...
shame on me too
Old   January 3, 2017, 09:11
bart3000
bart3000 is on a distinguished road
Dear,
Is it possible to give a bit more explanation on how you solved this problem? I'm facing the exact same one. What do you exactly mean with the volume mesh?
Thanks in advance,
Bart
bart3000 is offline   Reply With Quote
Old   May 11, 2018, 08:59
ashfaque
ashfaque is on a distinguished road
Originally Posted by bart3000 View Post
Dear,
Thanks in advance,
Bart
Dear Bart
I am also stuck at the exact problem with my mesh and completely lost
Did you manage to solve the problem and if yes how? It would be very kind if you could share the solution.
Best regards
Ashfaque
ashfaque is offline   Reply With Quote
Old   January 12, 2021, 16:21
Default my solution
Hui Zhang
Isaiah_HZ is on a distinguished road
In case of someone having same problem, I post my solution. When I copied and rotated the mesh, and output, this problem happened when I used fluent3DMeshToFoam. And I realized that I did not rotate and copy all substances of mesh. After selecting subsets, points, lines, shells and volumes, copied and rotated again, it was converted successfully. Thus, for this problem, I think that there are some missing lines, points or volumes causing this problem when you convert the mesh.
Best,
Hui
Isaiah_HZ is offline   Reply With Quote
Old   July 31, 2021, 06:36
CFD_Lovers
sinatahmooresi is on a distinguished road
got it...
Can you just leave u some hints on how you solve it?
Thank you
sinatahmooresi is offline   Reply With Quote
Old   October 19, 2021, 16:45
Balaji
Nealcaffrey is on a distinguished road
Hi guys,
I am using commercial software to create mesh for openfoam (Ansa HeXtreme)
I am getting the same error, I have made sure to include the Volume region.
What might be the issue, how did you guys solve the issue?
My mesh size is around 144M elements, external aerodynamics
Any inputs/methods will be appreciated
[0]
[0]
[0] --> FOAM FATAL ERROR: (openfoam-2012)
[0] Illegal cell label -1 in neighbour addressing for face 411208890
[0]
[0]     From void Foam::polyMesh::initMesh()
[0]     in file meshes/polyMesh/polyMeshInitMesh.C at line 77.
[0]
FOAM parallel run exiting
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
Nealcaffrey is offline   Reply With Quote
Old   October 20, 2021, 04:12
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by Nealcaffrey View Post
Hi guys,
[0]
[0]
[0]
[0]
[0]
with errorcode 1.
Making some guesses here.
The OpenFOAM meshes are assembled from faces, not primitive cell shapes. This means that the mesh connectivity is given by the face owner/neighbour relationship. Each face will have a "owner" cell, all internal mesh faces have a "neighbour" cell, but the faces on the domain boundary do not have a "neighbour". Thus the number of neighbours will be less than the number of owners. In very versions (old even as "FOAM" before it became "OpenFOAM") the neighbour list was padded to the same length with -1 values. It could be that your commercial mesher is generating these old formats and they are triggering a problem?
Things to check. Do the list sizes mentioned in polyMesh/{owner,neighbour} files make sense? Is the owner < neighbour, any -1 values to be seen?
What does checkMesh tell you? Run in serial to rule out problems there.
Nealcaffrey likes this.
olesen is offline   Reply With Quote
Old   October 20, 2021, 12:09
Hui Zhang
Hi guys,
[0]
[0]
[0]
[0]
[0]
with errorcode 1.
just one suggestion that i used to get the same issue done
Check two lines cross the vertice that you want them to cross. I used ICEM to generate mesh, and sometimes can not make the nearby lines cross same points or vertices automatically. this kind of mistakes can be ignored easily, because only zoom in, to some extent, this error can be seen. So please check carefully your basic elements.
Old   October 21, 2021, 05:41
Talking Solution Found
  #12
Balaji
Hi Guys,
So I found out the solution to the issue which I was facing. For anyone who is interested, the below method maybe helpful.
The commercial software programs (ANSA) sometimes create huge mesh 144M elements, but sometimes the volumes meshes are penetrating with some shell meshes. In my case the HeXtreme mesh was getting penetrated with 2 Trias surfaces, which should normally not happen after auto quality improvement.
Luckily there is an option in ANSA, where one can find out the penetrated regions. I then manually deleted the two unreferenced Trias surfaces and then re-exported the Volume mesh in openFoam format.
So basically, there should not be any hanging unreferenced surfaces other than the main mesh and boundaries.
The checkMesh unfortunately didn't capture this detail. Hence the confusion
So the solution is to re-verify the mesh on commercial software packages for intersection or penetration, then either Auto-fix or remove them manually.
Cheers
Neal
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 10:14
[Commercial meshers] ansys icem tetra mesh to fluent_v6 conversion problems milleniumrider OpenFOAM Meshing & Mesh Conversion 3 May 13, 2010 15:54
