[snappyHexMesh] snappyHexMesh: extra domains domain1 domain2 ... appear
Like Tree1Likes
  • 1 Post By Quin404
Old   May 27, 2014, 14:42
Default snappyHexMesh: extra domains domain1 domain2 ... appear
Sergey
skuznet is on a distinguished road
Hello!
I'm trying to generate a mesh for conjugate heat transfer using snappyHexMesh utility.
I have two stl files for fluid and solid geometries where various patches including fluid_to_solid and solid_to_fluid are defined.
When I run snappyHexMesh I get a number of domains called
domain1
domain2
etc
instead of just two domain solid and fluid.
Does anyone have an idea what is going wrong?
Thank you!
it looks like there are some problems with the surface, the surfaceCheck utility says that
sergkuznet@ubuntu:/media/ubuntu/run/UCcases/UCsideOptShort_run/constant/triSurface$ surfaceCheck fluid.stl
|  \\    /   O peration     | Version:  2.2.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.x-37940e0cd1ae
Exec   : surfaceCheck fluid.stl
Date   : May 27 2014
Time   : 23:30:17
Host   : "ubuntu"
PID    : 5557
Case   : /media/ubuntu/run/UCcases/UCsideOptShort_run/constant/triSurface
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Reading surface from "fluid.stl" ...
Statistics:
Triangles    : 5270
Vertices     : 2491
Bounding Box : (-0.002424 -0.00101 -0.000606) (0.004848 0.001414 0.003838)
Region	Size
fluid_to_solid	4878
maxX	2
minX	2
maxY	168
minY	12
maxZ	96
minZ	112
Surface has no illegal triangles.
Triangle quality (equilateral=1, collapsed=0):
    0 .. 0.05  : 0.232827
    0.05 .. 0.1  : 0.0757116
    0.1 .. 0.15  : 0.0538899
    0.15 .. 0.2  : 0.0724858
    0.2 .. 0.25  : 0.103226
    0.25 .. 0.3  : 0.0242884
    0.3 .. 0.35  : 0.0616698
    0.35 .. 0.4  : 0.0390892
    0.4 .. 0.45  : 0.0180266
    0.45 .. 0.5  : 0.0242884
    0.5 .. 0.55  : 0.059203
    0.55 .. 0.6  : 0.0440228
    0.6 .. 0.65  : 0.027704
    0.65 .. 0.7  : 0.0163188
    0.7 .. 0.75  : 0.0129032
    0.75 .. 0.8  : 0.0178368
    0.8 .. 0.85  : 0.00227704
    0.85 .. 0.9  : 0.0366224
    0.9 .. 0.95  : 0.0377609
    0.95 .. 1  : 0.0398482
    min 3.65063e-05 for triangle 3175
    max 0.999997 for triangle 1354
Edges:
    min 5.32471e-05 for edge 192 points (0.001616 -0.00101 0.00277059)(0.00159507 -0.00101 0.00272163)
    max 0.00506211 for edge 7488 points (0.004848 0.001414 0.003838)(0.004848 -0.00101 -0.000606)
Checking for points less than 1e-6 of bounding box ((0.007272 0.002424 0.004444) meter) apart.
Found 0 nearby points.
Surface is not closed since not all edges connected to two faces:
    connected to one face : 18
    connected to >2 faces : 0
Conflicting face labels:18
Dumping conflicting face labels to "problemFaces"
Paste this into the input for surfaceSubset
Number of unconnected parts : 1
Number of zones (connected area with consistent normal) : 1
End
I prepared parts of this surface in salome and then named them and joined together manually and they looked ok visually. I did open surface in HelyxOS and surface looked ok, but when I open it in meshlab i can see several large holes in my surface (if I open separate parts, before they were joined, there are no holes).
I guess it might be due to intersecting surfaces?
What do I do with this? Any suggestions?
I tried to run surfaceClean but it didn't help and I'm not sure which parameters to use - minlength, min quality/
I used
https://netfabb.azurewebsites.net/
to fix my surfaces.
no surfaceCheck says
sergkuznet@ubuntu:/media/ubuntu/run/UCcases/UCsideOptShort_run/constant/triSurface$ surfaceCheck solid.stl
Exec   : surfaceCheck solid.stl
Date   : May 28 2014
Time   : 10:52:13
Host   : "ubuntu"
PID    : 9647
nProcs : 1
Reading surface from "solid.stl" ...
Statistics:
Triangles    : 4776
Vertices     : 2234
Bounding Box : (-2e-06 -0.00201 -0.000606) (0.002424 0.001414 0.003836)
Region	Size
patch0	4776
    0 .. 0.05  : 0.210008
    0.05 .. 0.1  : 0.0822864
    0.1 .. 0.15  : 0.0527638
    0.15 .. 0.2  : 0.0728643
    0.2 .. 0.25  : 0.0768425
    0.25 .. 0.3  : 0.0249162
    0.3 .. 0.35  : 0.0464824
    0.35 .. 0.4  : 0.0456449
    0.4 .. 0.45  : 0.0303601
    0.45 .. 0.5  : 0.0276382
    0.5 .. 0.55  : 0.0406198
    0.55 .. 0.6  : 0.0406198
    0.6 .. 0.65  : 0.0372697
    0.65 .. 0.7  : 0.00942211
    0.7 .. 0.75  : 0.0247069
    0.75 .. 0.8  : 0.0500419
    0.8 .. 0.85  : 0.00439698
    0.85 .. 0.9  : 0.0316164
    0.9 .. 0.95  : 0.0450168
    0.95 .. 1  : 0.0464824
    min 4.18994e-06 for triangle 2236
    max 0.99973 for triangle 4741
Edges:
    min 1.99996e-06 for edge 3492 points (0.000404 0.000808 -0.000534)(0.000404 0.000806 -0.000534)
    max 0.00185613 for edge 3582 points (0.002114 -0.00101 0.000222)(0.000258 -0.00101 0.0002)
Checking for points less than 1e-6 of bounding box ((0.002426 0.003424 0.004442) meter) apart.
Surface is closed. All edges connected to two faces.
End
so looks that my surface is ok now, however, I lost all my surface definitions, so can't apply BC, and
when I run snappyHexMesh it still creates a number of spurious domains
domain1
domain2
skuznet is offline   Reply With Quote
Old   September 29, 2015, 10:08
Thomas
Quin404 is on a distinguished road
Hello!
Sorry I understand this thread is a little old now, however did you manage to find a solution to the problem, as I have been having the same issue?
Thank you
Quin404 is offline   Reply With Quote
Old   November 27, 2015, 09:07
Thomas
Thought it would best to let people know that I did find the issue to my problem some time ago...
I had multiple components under the same part name in the same ".stl" file.
For example, I had 10 Heat pads all in different locations, essentially having 10 different solid domains, but had defined them under the same part - "HeatPads".
So I had to rename them as individual parts, e.g. HeatPad1, HeatPad2 etc and export them as individual ".stl" files.
This then removed the random domain names
(Sorry, I do understand this was a very basic mistake!)
wyldckat likes this.
Old   November 29, 2015, 07:43
Retired Super Moderator
Bruno Santos
To add to Quin404's answer, I'll quote from openfoamwiki.net: http://openfoamwiki.net/index.php/Sn...-region_meshes
Instructions on how to remove an external unwanted region: Background Mesh in snappy with multi domain (CHT) post #3
  • Note: this happens whenever the base mesh doesn't coincide with the outer limits of the target surface geometry. The tutorial heatTransfer/chtMultiRegionFoam/snappyMultiRegionHeater is such an example where the outside of the original STL files coincides with the base mesh.
[mesh manipulation] why splitMeshRegions creates extra domains? skuznet OpenFOAM Meshing & Mesh Conversion 10 May 31, 2022 06:54
[snappyHexMesh] snappyHexMesh .stl generate extra boundary gsq OpenFOAM Meshing & Mesh Conversion 0 April 21, 2018 07:03
[snappyHexMesh] MultiRegions: Snappy creates extra domains between Regions Cartuns11 OpenFOAM Meshing & Mesh Conversion 3 January 22, 2018 09:39
[snappyHexMesh] Small domains in multi-region SnappyHexMesh nusivares OpenFOAM Meshing & Mesh Conversion 3 August 22, 2017 11:14
chtMultiRegionSimpleFoam: crash on parallel run student666 OpenFOAM Running, Solving & CFD 3 April 20, 2017 12:05
