[mesh manipulation] Defining regions with topoSet
Like Tree9Likes
  • 9 Post By alexeym
Old   May 10, 2014, 00:15
Default Defining regions with topoSet
the.drizzle is on a distinguished road
Hi there,
I'm having trouble figuring out how to get topoSet to do what I want...
Basically, I want to create a compound mesh where each region has different material properties. Making single simple shapes such as rectangles, cylinders and an annulus is straightforward enough, but making more complicated shapes such as the quarter-cirle annulus I've (poorly) illustrated below are eluding me.
In particular, it seems to me that it should be possible to make something like the below image by using some boolean operations--create an annulus and remove some of it by removing the portion that intersects a box. I don't know if this is actually possible via topoSetDict though.
So, any suggestions? If boolean operations are not possible via topoSetDict, how else might I be able to accomplish something like this?
Thanks in advance for any help.
the.drizzle is offline   Reply With Quote
Old   May 11, 2014, 21:52
OK, how about this then...
Let's say I want to define a fairly generic closed polygon (no crossing boundaries) in terms of vertex coordinates, and then select the cells internal to the polygon. What seems the most intuitive solution to me would be to define said polygon as a patch in my blockMeshDict file and use that patch in topoSetDict to do the selection. This of course won't work, as defining a patch in this manner is invalid.
Thus, I guess what I'm asking is how I might go about doing this sort of patch selection? Perhaps as some sort of slave relative to the grid patch shown in my previous post? And if that's correct, how?
Old   May 12, 2014, 13:57
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Depending on your version of OpenFOAM, you can select cells inside a surface geomnetry by using the surfaceToCell source. If you define your shape as an STL file you should be able to get what you want.
mturcios777 is offline   Reply With Quote
Old   May 13, 2014, 06:22
Thanks mturcios777, my problem has (and still remains) doing boolean operations with topoSet. However, I have (sort of) taken your advice and simply did things in gmsh, and used the gmshToFoam utility to convert the mesh. Once that was done, simply selecting the regions via topoSetDict was easy, and splitMeshRegions works like a charm as well.
If anyone can provide some insight as to how to do this via blockMesh + topoSet, I'd still like to know...
Old   May 13, 2014, 06:38
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
I'll assume you'd like to have cellSet. To create quarter of cylinder, you'll need to create outer cylinder, delete from it inner cylinder, delete half with box, and delete half of the acquired half with another box. So it should be something like (I'll create quarter of a cylinder in the center, correct coordinates for your case):
        name c0;
        type cellSet;
        action new;
        source cylinderToCell;
        sourceInfo
            p1 (0 0 0);
            p2 (0 0 1);
            radius 1;
        name c0;
        type cellSet;
        action delete;
        sourceInfo
            p1 (0 0 0);
            p2 (0 0 1);
            radius 0.8;
        name c0;
        type cellSet;
        action delete;
        source boxToCell;
        sourceInfo
            box (-1 -1 0) (1 0 1);
        name c0;
        type cellSet;
        action delete;
        source boxToCell;
        sourceInfo
            box (-1 -1 0) (0 1 1);
After these operations in c0 there will be just a quarter of the cylinder.
Or you'd like to do something else?
alexeym is offline   Reply With Quote
Old   May 13, 2014, 06:47
Thanks, that's just the kind of tip I have been looking for! I think I now see where I was going wrong, and get on using this tool instead of just swearing at it :-)
Old   July 5, 2016, 06:56
ArielJ
arieljeds is on a distinguished road
hi there, I know this is an old thread but it is exactly on the topic I need to ask about.. I am trying to use topoSet and refineMesh for the first time on a basic cylinder in multiphase flow mesh. What I would like to do is refine the mesh just around the cylinder and in the wake area and leave the rest quite coarse but I'm having trouble with topoSetDict and refineMeshDict understanding the dictionaries and getting the right entries. I'm attaching the blockMeshDict.txt file as it's too long to include here as well as my (barely edited) refineMeshDict and topoSetDict. If anyone can offer some advice on editing these files to refine the cells in the area around the cylinder and wake, I would be very grateful..
arieljeds is offline   Reply With Quote
Old   July 5, 2016, 07:34
Good ol' email notifications!
I'm no longer working in CFD these days (stupid economy!) and my solution is likely outdated in terms of the current OF release. That said though, I have a whole demo script around here somewhere that at least sets up the geometry / meshing consistently, so just pm me an address and I'll be happy to dig it up and send it to you.
Cheers!
toposet, toposetdict
[snappyHexMesh] defining porous zone in toposet mvee OpenFOAM Meshing & Mesh Conversion 5 July 13, 2020 13:28
Defining regions with topoSet BarCFD OpenFOAM Pre-Processing 2 February 4, 2018 12:18
Defining multiple regions in MRFsimpleFoam ameen@cfd OpenFOAM Running, Solving & CFD 7 May 9, 2014 06:29
splitting regions and defining BC in conjugate heat transfer skuznet OpenFOAM Pre-Processing 3 December 9, 2013 05:42
defining regions Harriet Pearson Main CFD Forum 0 February 19, 2004 13:44
