[CAD formats] change dimensions and Position in .stl file
Like Tree1Likes
  • 1 Post By fumiya
Old   March 28, 2014, 15:59
Default change dimensions and Position in .stl file
sajad
seju is on a distinguished road
dear foamer
I have two stl file. and I wanna put one stl into other stl file but when I see two stl file in paraview two stl file changed position.
you can see two stl file in attached.
2-and also I draw stl file with SolidWorks
I draw those file in mm scale and now in paraview they are in m.
I wanna mesh those file with snappy. but I cant do that. please help me
best regard
Sajad
seju is offline   Reply With Quote
Old   April 12, 2014, 01:01
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You can use the surfaceTransformPoints utility included in OpenFOAM.
Sample usage(To convert mm to m):
surfaceTransformPoints input_file.stl output_file.stl -scale "(0.001 0.001 0.001)"
Hope this helps,
Fumiya
ddcampayo likes this.
[Personal]
fumiya is offline   Reply With Quote
[mesh manipulation] EngineMesh utilitities greg_karp OpenFOAM Meshing & Mesh Conversion 15 March 18, 2017 21:47
