[snappyHexMesh] Stop flow going under hill
Like Tree1Likes
  • 1 Post By linnemann
Old   March 28, 2014, 12:40
Default Stop flow going under hill
Andrew Mortimer
AndrewMortimer is on a distinguished road
Hi all,
I'm essentially running the turbine_siting tutorial but with different geometry. There are 2 different types of output from the setup:
- The flow only goes over the hill as desired. This is shown in pic 1. This was achieved with a surface refinement of 2
- The flow goes under and beneath the hill as shown in pic 2. This occurred with a surface refinement level of 3.
In both cases the blockMeshDict was the same:
vertices
        ( -3000.0 -3000.0 -400.0)
        ( 5000.0 -3000.0 -400.0)
        ( 5000.0 5000.0 -400.0)
        ( -3000.0 5000.0 -400.0)
        ( -3000.0 -3000.0 600.0)
        ( 5000.0 -3000.0 600.0)
        ( 5000.0 5000.0 600.0)
        ( -3000.0 5000.0 600.0)
blocks
    hex (0 1 2 3 4 5 6 7) (40 50 20) simpleGrading (1 1 1)
although I have found that varying the number of blocks in the z sometimes changes the output.
The model I have for the hill is an stl and is essentially just a single sheet, i.e it is not a closed model.
Does anyone know why sometimes the flow doesn't go under the hill and sometimes it does? These are the only settings I've been playing around with.
Thanks in advance.
AndrewMortimer is offline   Reply With Quote
Old   March 28, 2014, 15:17
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
You probably have a crack/hole somewhere on your stl file that is larger than refinement level 3.
That will let the mesh "flow" through the crack and also mesh the volume below the surface.
So make sure your STL extends a little beyond the blockMesh mesh.
After that make sure there are no leaks in your stl.
AndrewMortimer likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   April 3, 2014, 12:48
Andrew Mortimer
That was indeed the problem. Thanks for the help!
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 17:10
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 06:57
