January 28, 2014, 15:26 |
best mesh generator
Tommy Sp
Rep Power: 12 |
what's the best mesh generation software for OpenFOAM?!
I have Ubuntu. My computer is 32 bits. I tried install salome, but it is 64 bits. |
January 28, 2014, 15:35 |
#2 | |
Daniel P. Combest
There is also some official explanation located here and then a few GUIs to do some setup for you: If you aren't keen on snappyHexmesh, there are also a few other mesh generation tools that I suggest Other than that, OpenFOAM can import many formats and you can use pretty much any tool to generate meshes. |
January 29, 2014, 04:25 |
Gerhard Holzinger
Rep Power: 28 |
Depending on your ability to enjoy a good days pain in the brain, it can also be blockMesh in conjunction with m4 or Python.
This is the parametric mesh of a stirred tank with a Rushton impeller. The features are
February 14, 2014, 14:24 |
BlockMesh
Thomas Walsh
Rep Power: 16 |
Gerhard,
Very nice tank model you have created. Curious if you could post an example of how to implement an m4 or python script to generate the blockmesh and baffle files? Thanks, Tom Walsh |
February 17, 2014, 13:52 |
Gerhard Holzinger
Rep Power: 28 |
I stopped using m4 for my meshes because Python is much better to read and it is also much more flexible. However, the attached image of a small pipe joining a larger cylinder was created with m4. I won't post my mesh creation script - sorry for that, but I can elaborate on the workflow.
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Help with UDF to change mesh by external mesh generator | zou_mo | Fluent UDF and Scheme Programming | 1 | July 1, 2009 05:57 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
