[blockMesh] How to define an volScalarField in part of the Mesh?
Like Tree1Likes
  • 1 Post By devlaam
Old   October 15, 2013, 12:54
Default How to define an volScalarField in part of the Mesh?
Ruud Vlaming
devlaam is on a distinguished road
I cannot find an example or solution for this probably very simple newbie problem. I work with electrostatics, but i do not think this is relevant, it is an general issue.
I defined two cubes of size 1 next to each other, called left and right. If can define a uniform charge density in both cubes. With
internalField   uniform 1e-3;
and that works well, but how do define it in just one cube? I tried adding an "internal plane" in the blockMeshDict, but that is not acceptable it seems. And even if it were, how do i designate that space, it seems only the faces can have names. Somehow i am missing something quite obvious here.
I really appreciate any help.
These are my test files:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
(   (1 0 0) //0
    (1 1 0) //1
    (0 1 0) //2
    (0 0 0) //3
    (1 0 1) //4
    (1 1 1) //5
    (0 1 1) //6
    (0 0 1) //7
    (1 2 0) //8
    (0 2 0) //9
    (1 2 1) //10
    (0 2 1) //11
blocks
(   hex (0 1 2 3 4 5 6 7)   (5 5 5) simpleGrading (1 1 1)
    hex (1 8 9 2 5 10 11 6) (5 5 5) simpleGrading (1 1 1) );
boundary
  topleft
  { type patch;
    faces ( (4 5 6 7) ); }
  topright
  { type patch;
    faces ( (5 10 11 6) ); }
  bottomleft
  { type patch;
    faces ( (3 2 1 0) ); }
  bottomright
  { type patch;
    faces ( (2 9 8 1) ); }
  frontleft
  { type patch;
    faces ( (4 5 1 0) ); }
  frontright
  { type patch;
    faces ( (5 10 8 1) ); }
  backleft
  { type patch;
    faces ( (2 6 7 3) ); }
  backright
  { type patch;
    faces ( (9 11 6 2) ); }
  leftleft
  { type patch;
    faces ( (0 4 7 3) ); }
  rightright
  { type patch;
    faces ( (9 11 10 8) ); }
// This does not work?
//  middle
//  { type internal;
//    faces ( (1 2 6 5) ); }
mergePatchPairs
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      rho;
dimensions      [0 -3 1 0 0 1 0];
// how to define this only for the left cube???
boundaryField
  topleft
  { type fixedValue;
    value uniform 0; }
  topright
  { type fixedValue;
    value uniform 0; }
  bottomleft
  { type fixedValue;
    value uniform 0; }
  bottomright
  { type fixedValue;
    value uniform 0; }
  frontleft
  { type fixedValue;
    value uniform 0; }
  frontright
  { type fixedValue;
    value uniform 0; }
  backleft
  { type fixedValue;
    value uniform 0; }
  backright
  { type fixedValue;
    value uniform 0; }
  leftleft
  { type fixedValue;
    value uniform 0; }
  rightright
  { type fixedValue;
    value uniform 0; }
devlaam is offline   Reply With Quote
Old   October 17, 2013, 16:53
Retired Super Moderator
Bruno Santos
Hi devlaam,
I'm guessing that you read the User Guide waaaay too fast
This is explained here: http://www.openfoam.org/docs/user/da...#x7-530002.3.3 (section "2.3.3 Setting initial field")
Best regards,
Bruno
Old   October 22, 2013, 11:14
Post
Ruud Vlaming
Yep, guess you where right.
Works like a charm now.
The biggest problem for the newbies is, i think, that we all have a idea how this should work, but that is not the way it works ...
Thanks for your support!
wyldckat likes this.
internalfield, volscalarfield
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Define total mesh diclpacement in theta Direction omidiut CFX 1 November 10, 2013 05:28
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
