[snappyHexMesh] snappyhexmesh
Like Tree2Likes
  • 1 Post By Hiroshiman
Old   August 9, 2013, 08:40
Default snappyhexmesh
Sasan Ghomi
sasanghomi is on a distinguished road
Hi everybody ,
These days I am trying to use snappyhexmesh and I have a question about specifying names for each boundary in the geometry.How can I specify a name for a boundary in the geometry? I know that I can use snappyhexmeshDict for surfaces those have regular shapes (e.g. sphere & cylinder & cubic ) But when there are some complicated surfaces How can I specify a name for a boundary in the geometry?? Is it possible to specify names for boundaries in STL file? ( I know CATIA and Solidworks can't do this action )
Any idea? Any software?
I appreciate any help from you.
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   August 9, 2013, 08:59
Hiroshiman is on a distinguished road
You can spit your .stl by angle before meshing using
surfaceAutoPatch in.stl out.stl angle
SnappyHexMesh will then consider the different patchs. It can be coupled with
surfaceFeatureExtract
a meshing taking account of the angle.
Florian
elvis likes this.
Hiroshiman is offline   Reply With Quote
Old   August 10, 2013, 06:23
Sasan Ghomi
Thank you very much for your reply ,
Can you explain more? I think there is one .STL file So what are in.stl and out.stl ?? and what is the angle exactly ? Can you say me what do the first commend do exactly ?
Thank you very much
Sasan.
Old   August 10, 2013, 16:57
I mean in.stl is your original file and out.stl is the newly generated one. The angle is the angle which will be used to separate surface ; it's similar to the autoPatch function but on the stl, not the mesh.
After running surfaceAutoPatch, look at your stl in paraview and you'll see the different areas.
The surface tools are listed here :
http://www.openfoam.org/docs/user/st...-utilities.php
Old   August 11, 2013, 15:25
Sasan Ghomi
Hi Dear Hiroshiman,
Thank you very much .
I tried to generate the mesh for a simple geometry and I used your advice (surfaceAutoPatch)...But unfortunately the mesh didn't create..I attached case file. Please take a look at this case . Can you help me for finding the origin of this problem ?
Sasan.
Old   August 12, 2013, 05:29
Elvis
elvis will become famous soon enough
if you look at
Catia to snappyHexMesh
http://www.cfd-online.com/Forums/ope...tml#post344263
there seems to be a catia-script that supports writing STLīs with named surfaces
http://www.cfd-online.com/Forums/att...-stlexport.txt
feedback if that works would be great
elvis is offline   Reply With Quote
Old   August 12, 2013, 10:23
sasanghomi :
An few things : if you look at the STLSolidLabeling in paraview of your out.stl you'll see the separated surface, it worked fine.
Concerning the mesh generation, your blockMeshDict wasn't correct. Use s
urfaceCheck -blockMesh constant/triSurface/out.stl
to know the bounding box size. I used :
vertices
    (0.499997 0.071262 0.499997)
    (100.5 0.071262 0.499997)
    (100.5 7.19745 0.499997)
    (0.499997 7.19745 0.499997)
    (0.499997 0.071262 50.5)
    (100.5 0.071262 50.5)
    (100.5 7.19745 50.5)
    (0.499997 7.19745 50.5)
blocks
    hex ( 0 1 2 3 4 5 6 7) (50 50 20) simpleGrading (1 1 1)
It worked fine. after running snappyHexMesh, it saw and used the patches which can therefore be used for BCs.
The boundaries files looks like :
9
    defaultFaces
        type            empty;
        inGroups        1(empty);
        nFaces          3011;
        startFace       2475746;
    patch0
        type            wall;
        nFaces          288000;
        startFace       2478757;
    patch1
        type            wall;
        nFaces          3600;
        startFace       2766757;
    patch2
        type            wall;
        nFaces          129600;
        startFace       2770357;
    patch3
        type            wall;
        nFaces          2400;
        startFace       2899957;
    patch4
        type            wall;
        nFaces          32400;
        startFace       2902357;
    patch5
        type            wall;
        nFaces          1600;
        startFace       2934757;
    patch6
        type            wall;
        nFaces          8603;
        startFace       2936357;
    patch7
        type            wall;
        nFaces          0;
        startFace       2944960;
If you use a bigger bounding box, one empty wall will disappear.
Enjoy,
Florian
sasanghomi likes this.
Old   August 13, 2013, 07:18
Sasan Ghomi
Dear Hiroshiman
Thank you very very very much....
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 12:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
