[snappyHexMesh] How to define to right point for locationInMesh |
July 10, 2013, 02:13 |
Amin
Rep Power: 13 |
Hello everybody
I am new OpenFOAM user and i would like to know, how to mesh external geometry using snappyHexMesh. I took a simple Geometry #cylinder# as a first case. I read the OpenFOAM tutorial, but i tried to follow the same instructions, but unlikely i did not know to specify correctly the point of the locationInMesh in snappyHexMeshDict. I took the point inside the block but outside the cylinder, but it is not working... Here is my snappyHexMeshDict : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers false; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { cylinder.stl { type triSurfaceMesh; name cylinder; } box { type searchableBox; min (-2 -2 -12); max (2 2 12); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 2000000; // The surface refinement loop might spend lots of iterations // refining just a few cells. This setting will cause refinement // to stop if <= minimumRefine are selected for refinement. Note: // it will at least do one iteration (unless the number of cells // to refine is 0) minRefinementCells 0; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 1; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { cylinder { // Surface-wise min and max refinement level level (2 2); } } resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { //cylinder //{ // mode inside; // levels ((6 6)); //} } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (-1 -1 -10); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 4.0; //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Per final patch (so not geometry!) the layer information layers { cylinder { nSurfaceLayers 1; } } // Expansion factor for layer mesh expansionRatio 1.0; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // See relativeSizes parameter. finalLayerThickness 0.3; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // See relativeSizes parameter. minThickness 0.25; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 60; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 16x! 90 degrees corresponds to 130 in 16x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; // Max number of iterations after which relaxed meshQuality controls // get used. Up to nRelaxIter it uses the settings in meshQualityControls, // after nRelaxIter it uses the values in meshQualityControls::relaxed. nRelaxedIter 20; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 65; //- Max skewness allowed. Set to <0 to disable. maxBoundarySkewness 20; maxInternalSkewness 4; //- Max concaveness allowed. Is angle (in degrees) below which concavity // is allowed. 0 is straight face, <0 would be convex face. // Set to 180 to disable. maxConcave 80; //- Minimum pyramid volume. Is absolute volume of cell pyramid. // Set to a sensible fraction of the smallest cell volume expected. // Set to very negative number (e.g. -1E30) to disable. minVol 1e-13; //- Minimum quality of the tet formed by the face-centre // and variable base point minimum decomposition triangles and // the cell centre. Set to very negative number (e.g. -1E30) to // disable. // <0 = inside out tet, // 0 = flat tet // 1 = regular tet minTetQuality 1e-30; //- Minimum face area. Set to <0 to disable. minArea -1; //- Minimum face twist. Set to <-1 to disable. dot product of face normal //- and face centre triangles normal minTwist 0.05; //- minimum normalised cell determinant //- 1 = hex, <= 0 = folded or flattened illegal cell minDeterminant 0.001; //- minFaceWeight (0 -> 0.5) minFaceWeight 0.05; //- minVolRatio (0 -> 1) minVolRatio 0.01; //must be >0 for Fluent compatibility minTriangleTwist -1; //- if >0 : preserve single cells with all points on the surface if the // resulting volume after snapping (by approximation) is larger than // minVolCollapseRatio times old volume (i.e. not collapsed to flat cell). // If <0 : delete always. //minVolCollapseRatio 0.5; // Advanced //- Number of error distribution iterations nSmoothScale 4; //- amount to scale back displacement at error points errorReduction 0.75; // Optional : some meshing phases allow usage of relaxed rules. // See e.g. addLayersControls::nRelaxedIter. relaxed { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 75; } } // Advanced // Flags for optional output // 0 : only write final meshes // 1 : write intermediate meshes // 2 : write volScalarField with cellLevel for postprocessing // 4 : write current intersections as .obj files debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-60 -50 -20) (60 -50 -20) (-60 -50 20) (60 -50 20) (-60 50 20) (60 50 20) (60 50 -20) (-60 50 -20) ); blocks ( hex (0 1 3 2 7 6 5 4) (30 30 20) simpleGrading (1 1 1) ); edges ( ); boundary ( ); mergePatchPairs ( ); // ************************************************************************* // Could you please help to solve the problem ?? I need your support Thanks |
July 10, 2013, 02:17 |
Amin
Rep Power: 13 |
here is a part of the output of snappyHexMesh :
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : snappyHexMesh Date : Jul 10 2013 Time : 10:38:21 Host : "BMH301562" PID : 5572 Case : /home/abm5kor/snappy nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 0.13 s Overall mesh bounding box : (-60 -50 -20) (60 50 20) Relative tolerance : 1e-06 Absolute matching distance : 0.000161245 Reading refinement surfaces. Read refinement surfaces in = 0 s Reading refinement shells. Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0 s Reading features. Read features in = 0 s Determining initial surface intersections ----------------------------------------- Edge intersection testing: Number of edges : 56100 Number of edges to retest : 56100 Number of intersected edges : 0 Calculated surface intersections in = 0.14 s Initial mesh : cells:18000 faces:56100 points:20181 Cells per refinement level: 0 18000 Adding patches for surface regions ---------------------------------- Patch Type Region ----- ---- ------ cylinder: 1 wall cylinder_CYLINDER Added patches in = 0.01 s Selecting decompositionMethod none Refinement phase ---------------- --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 24425, 4(8881 8912 9873 9842), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 24426, 4(8911 9872 9873 8912), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 24427, 4(9841 9842 9873 9872), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 21787, 4(8880 8881 8912 8911), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 54420, 4(4 35 36 5), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 9, 4(4 35 996 965), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 15, 4(6 37 998 967), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 16, 4(36 997 998 37), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 20, 4(967 968 999 998), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 53220, 4(6 7 968 967), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 54480, 4(6 37 38 7), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 15, 4(6 37 998 967), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 37, 4(43 1004 1005 44), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 38, 4(973 974 1005 1004), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 53340, 4(12 13 974 973), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 54660, 4(12 43 44 13), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 33, 4(12 43 1004 973), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 39, 4(14 45 1006 975), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 40, 4(44 1005 1006 45), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 41, 4(974 975 1006 1005), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 53360, 4(13 14 975 974), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 54690, 4(13 44 45 14), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 36, 4(13 44 1005 974), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 42, 4(15 46 1007 976), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 43, 4(45 1006 1007 46), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 44, 4(975 976 1007 1006), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 53380, 4(14 15 976 975), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 54720, 4(14 45 46 15), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 39, 4(14 45 1006 975), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 45, 4(16 47 1008 977), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 46, 4(46 1007 1008 47), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 47, 4(976 977 1008 1007), produces a valid tet decomposition. --> FOAM Warning : From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label) in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570 No base point for face 53400, 4(15 16 977 976), produces a valid tet decomposition. --> FOAM Warning : Suppressing any further warnings. --> FOAM FATAL ERROR: Point (-1 -1 -10) is not inside the mesh or on a face or edge. Bounding box of the mesh:(-60 -50 -20) (60 50 20) From function refinementParameters::findCells(const polyMesh&) const in file autoHexMesh/autoHexMeshDriver/refinementParameters/refinementParameters.C at line 110. FOAM exiting |
July 10, 2013, 07:21 |
Amin
Rep Power: 13 |
any idea ?
July 21, 2013, 05:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Amin,
You could have posted the complete case ready for testing, instead of just attaching the STL file In case you don't know, the following command: Code:
foamCleanTutorials OK, first the "blockMeshDict": The order of the vertices was incorrect. You can run: Code:
paraFoam -block Then... then are a few problems:
Best regards, Bruno
April 10, 2014, 11:12 |
Cheng Jie
Rep Power: 15 |
the Hex(in blockMeshDict) must starts with the face at minX then the face at maxX
http://www.cfd-online.com/Forums/ope...-mesh-but.html I have tried and succeed! Good Luck |
March 8, 2016, 08:53 |
locationInMesh insnappyHexMesh
Subhasree
Rep Power: 12 |
Hi Everyone,
I am using a basic rectangular box .stl file in snappyHexMesh but I am having some problem regarding the locationInMesh. I am attaching the case file. Can anyone tell me how do I proceed to find locationInMesh and also whats wrong with my case file? Thanks in advance Last edited by Subhasree; March 8, 2016 at 08:54. Reason: missing attachment |
March 8, 2016, 09:21 |
Subhasree
Rep Power: 12 |
Hi Everyone!
There was some error in the snappyHexMesh file..I have corrected it and its working fine now. But I would still like to know how do we usually choose the locationInMesh... |
March 13, 2016, 15:07 |
#8 | |
Bruno Santos
Rep Power: 128 |
metal hydride reactor simulation | srj007 | Fluent UDF and Scheme Programming | 0 | August 28, 2017 03:28 |
Define rotating point | MichelD | FLUENT | 0 | October 1, 2014 06:39 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
UDF carbon conversion | papteo | Fluent UDF and Scheme Programming | 1 | August 18, 2011 08:32 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
