[mesh manipulation] how to set layerAdditionRemoval |
July 2, 2013, 06:52 |
Yu CAO
Rep Power: 13 |
Hi
Does anyone know how to set layerAdditionRemoval. Like right { type layerAdditionRemoval; faceZoneName rightExtFaces; minLayerThickness 0.0002; maxLayerThickness 0.0005; active on; } where to write this? how to? are there any tutorail examples in openfoam? Thanks. |
July 15, 2013, 08:16 |
Rep Power: 16 |
Hi, have a look at http://openfoamwiki.net/index.php/Ho...mic_mesh_cases!
July 15, 2013, 11:13 |
#3 | |
Yu CAO
Rep Power: 13 |
Regards |
November 13, 2014, 17:55 |
yaqing
Rep Power: 11 |
Hi, did you solve that problem? I am also confusing about that. I guess whether we can put that in the boundary file. I tried to put that in dynamicfvmesh file and it does't work. Or if we need to create a dict file and then use it...
March 23, 2015, 12:44 |
Rep Power: 12 |
Hi All
Has anyone made progress with the layerAdditionRemoval? All I get on the internet is the same that cctv get. What should the input dictionary look like? How should the dynamicMesh solver be called? via mesh.update()? How do you couple a solver to this utility? I have seen output examples of this utility (http://www.cimec.org.ar/ojs/index.ph...File/4404/4334), but have not found any examples of how to implement it. Another site stating basically the same thing but are only slides: http://www.academia.edu/4060722/Deve...ine_simulation Any help or guidance will be greatly appriciated. Thank you |
April 23, 2015, 03:01 |
ILYA SIVKOV
Rep Power: 12 |
I wrote a small example of layering usage: http://www.cfd-online.com/Forums/ope...oval-demo.html
does Hyperthreading affect the application of UDF? | SJSW | Fluent UDF and Scheme Programming | 11 | October 10, 2018 22:28 |
[mesh manipulation] mirrorMesh and undoing the joining of patches | chegdan | OpenFOAM Meshing & Mesh Conversion | 3 | October 21, 2015 08:09 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
Install problem in linux | navaladi | OpenFOAM Installation | 11 | July 17, 2008 02:24 |
Ibm java gcc | rrr | OpenFOAM Installation | 2 | December 30, 2005 04:18 |
