[snappyHexMesh] eMesh file meaning in SnappyHexMesh
Like Tree9Likes
  • 2 Post By Eloise
  • 1 Post By elvis
  • 2 Post By Artur
  • 1 Post By Artur
  • 2 Post By l_r_mcglashan
  • 1 Post By Artur
Old   June 13, 2013, 03:08
Default eMesh file meaning in SnappyHexMesh
woodwick's Avatar
Alessandro
woodwick is on a distinguished road
I was running the motorBike tutorial and I noticed that in the directory:
/tutorials/incompressible/simpleFoam/motorBike/constant/triSurface
there is a file: motorBike.eMesh
What is the role and content of an eMesh file?
I understood (correct me if I'am wrong) that the motorBike.obj.gz gives the STL geometry, the triangular surface mesh that Snappy uses to put and cut his hexa elements around. But eMesh what does it do? What is its content? I am not even able to open it with gedit
woodwick is offline   Reply With Quote
Old   June 13, 2013, 04:15
woodwick's Avatar
Alessandro
additional observation:
opening snappyHexMeshDict you can find :
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
            file "motorBike.eMesh";
            level 0;
so explicit feature edge refinement...
does it mean eMesh = edgeMesh , that is: motorBike.eMesh is the file containing the list of edges of the geometry? maybe coming from surfaceFeatureExtract? mumble mumble
Old   June 13, 2013, 04:36
Eloïse
Eloise is on a distinguished road
you are right It is the file that contains the feature edges of your geometry and that is created by the surfaceFeatureExtract utility. In the snappyHexMeshDict, you specify the level of refinement needed on those edges.
Regards,
Eloïse
woodwick and Liangyuan like this.
Eloise is offline   Reply With Quote
Old   July 2, 2013, 13:32
Elvis
elvis will become famous soon enough
i tried to visulize which values would make sense via slider
http://www.cfd-online.com/Forums/ope...reextract.html
woodwick likes this.
elvis is offline   Reply With Quote
Old   July 10, 2013, 05:53
Artur's Avatar
Artur
Artur will become famous soon enough
You can also visualise it in paraview by using:
 surfaceFeatureConvert constant/triSurface/file_name.eMesh other_file_name.obj
and then simply opening it paraview.
s.m and libindaniel2000 like this.
Artur is offline   Reply With Quote
Old   August 19, 2013, 10:24
Default includedAngle ?
s.m
saeideh mohamadi
s.m is on a distinguished road
Dear Artur,
when we want convert the *.stl file to *.eMesh one, we execute
"surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/foil2D.stl airfoil"
my question is about "includedAngle 150" ?
what is it? and what is the difference between the *eMesh file that is gained from "includedAngle 150" and the one that is gained by "includedAngle 180" ?
Thank you very much
s.m is offline   Reply With Quote
Old   August 19, 2013, 10:32
Artur's Avatar
Artur
Depends on the version you run, I think from 2.0 or something like that it is governed by a dictionary instead of being passed options from the command line.
Include angle tells the function what angle between the faces has to be in order to constitute an edge, so 0 would mean there are no edges at all and 180 would be that a flat surface is an edge as far as I understand it.
Old   August 19, 2013, 10:46
s.m
saeideh mohamadi
i excute the surfaceFeatureExtract with includedAngle 180 & includeAngle 150 & includedAngle 50
here is the results.
Old   August 19, 2013, 11:12
Artur's Avatar
Artur
Yup, that's what I get for airfoil sections as well. You can see that in the first case it picks up pretty much every edge of the .stl triangles and the smaller the include angle gets the more defined the edge has to be in order to be picked up by the algorithm.
s.m likes this.
Old   August 19, 2013, 12:56
s.m
saeideh mohamadi
As i understand the includedAngle 180 is better for this case,because it involve more edge that the other includedAngle e.g 150
do i get it right?
Old   August 19, 2013, 13:06
Artur's Avatar
Artur
I think there is no definite answer to your question. It's not certain that including all the possible features will yield a "good" mesh in the end.
Looking at your screenshots I'd probably go with the intermediate value because it represents the trailing edge and the section profiles at either end well but will not mess around with your mesh anywhere else. However, this is just my personal opinion and may not be correct.
Old   August 19, 2013, 13:09
s.m
saeideh mohamadi
"intermediate value" mean includedAngle 150?
Old   August 19, 2013, 13:32
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
FYI, you can also use the "FeatureEdge" filter in paraview to help you choose an appropriate includedAngle.
toolpost and s.m like this.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   August 20, 2013, 05:01
Artur's Avatar
Artur
Good to know that, thanks for sharing!
@ s.m. : Yes, by intermediate I mean the middle one from the 3 you've shown, i.e. 150.
s.m likes this.
Old   August 20, 2013, 07:35
s.m
saeideh mohamadi
Dear Laurence,Thank you for your suggestion
i don't know how to use this filter, and how should we know the proper includedAngle by using it.
could you please explain it more,
Thank you again.
Old   May 12, 2016, 02:07
LD
libindaniel2000 is on a distinguished road
What is your opinion on obtaining a leading edge once surfaceFeatureExtract is used. Using an angle of 150, I can get the root and tip of the wing and the trailing edge of the wing, but not the leading edge. Should this be a concern?
libindaniel2000 is offline   Reply With Quote
Old   May 12, 2016, 04:42
Artur's Avatar
Artur
Depends on whether you can get a good enough mesh resolution at the LE without feature refinement. This is probably best controlled using resolveFeatureAngle if you are using graded refinement on the body (i.e. refinement levels between 3 and 5, say). Otherwise, you can divide your wing geometry into two before exporting stl, that way surfaceFeatureExtract will pick up the LE as a separate feature line.
A
emesh, snappyhexmesh
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
