[snappyHexMesh] How to get a snapped mesh with SnappyHexMesh?
Like Tree20Likes
  • 12 Post By niklas
  • 8 Post By niklas
Old   June 6, 2013, 13:52
Default How to get a snapped mesh with SnappyHexMesh?
Jackie Chou
jackeyhust is on a distinguished road
Hi, Foamers,
I am new in OpenFoam and study it now. I just start it from a simple model.
Though it is small model, I still met some problems. Hopefully I can get your support.
The model consists of three parts : Extr1, Poro, Extr2. Each of them consists of inlet, outlet, and wall. I am now doing the multiregions meshing for these three parts together with snappyhexmesh. But I cannot get a perfectly snapped mesh. The edges and somewhere in the faces look not very smooth. I have struggled with this for a week.
Could someone help me a little bit? I attached the case folder and the pictures which indicate the results I have obtained. I have written the commands I ran the case in command.txt. I am now using OpenFOAM 2.2.0
I have tried to add the featureEdges for all of them and increase the surface refine mesh level, it is better now, but the surface is still not so flat. Could anybody tell me why?
Really thank you for your kind support!
Jackie
case.zip
jackeyhust is offline   Reply With Quote
Old   June 7, 2013, 10:30
cutter is on a distinguished road
Try to align your blockMesh with your geometry (start with its real bounding box). This should give you much better results.
cutter
cutter is offline   Reply With Quote
Old   June 9, 2013, 08:49
Retired Super Moderator
Bruno Santos
Greetings to all!
@Jackie: Sorry, I don't enough time to go through testing this. Please check the tutorials at the following link for more ideas: http://openfoamwiki.net/index.php/Sn...als_and_Guides
Best regards,
Bruno
Old   June 10, 2013, 05:13
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Conforming a hexmesh to a general geometry implies a few things.
If you want to have a 'perfect' mesh with only orthogonal cells you can not expect it to fit the surface of
the geometry.
And vice versa,
if you want the mesh to fit your geometry perfectly you can not
expect it to consist of only perfectly shaped hex cells.
So it is up to the user to decide what you want the most, good conformity or good quality, usually you can not have both.
Therefore it is a good thing if you can align the mesh with the geometry, since this will allow the mesh to conform to the geometry with less modifications, and not do what you have done here...
You can play with these parameters and see how they affect the mesh.
maxNonOrtho 80;
maxBoundarySkewness 20;
maxInternalSkewness 5;
maxConcave 80;
Start by setting everything to 90, which should make the mesh fit as good as possible given the resolution.
If this looks good you can start reducing the numbers and see what happens.
Below I've made a few such tests just to illustrate how the mesh is unable to conform to the surface when you
start reducing the maxNonOrtho value.
Watch how the surface starts to look 'wavy' as the maxNonOrtho is lowered.
here's a new version of snappyHexMeshDict
|       o          |                                                          |
|    o     o       | HelyxOS                                                  |
|   o   O   o      | Version: 1.0.0                                           |
|    o     o       | Web:     http://www.engys.com                            |
|       o          |                                                          |
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers false;
geometry
    "Extr1.stl"
        type triSurfaceMesh;
        name Extr1;
    "Extr2.stl"
        name Extr2;
    "Poro.stl"
        name Poro;
castellatedMeshControls
features
        file "Poro.eMesh";
        level 5;
        file "Extr2.eMesh";
        level 5;
refinementSurfaces
    Extr1
        level ( 3 4 );
        regions
        faceZone Extr1;
        cellZone Extr1;
        cellZoneInside inside;
    Extr2
        level ( 3 4 );
        regions
        faceZone Extr2;
        cellZone Extr2;
    Poro
        level ( 3 4 );
        regions
        faceZone Poro;
        cellZone Poro;
resolveFeatureAngle 30;
refinementRegions
   locationInMesh ( 0.4 -0.03  0.6 );
    // The surface refinement loop might spend lots of iterations
    // refining just a few cells. This setting will cause refinement
    // to stop if <= minimumRefine are selected for refinement. Note:
    // it will at least do one iteration (unless the number of cells
    // to refine is 0)
    minRefinementCells 10;
    maxLocalCells  1000000;                        //original 100 000
    maxGlobalCells 10000000;                       //original 2 000 000
    minRefinementCells 0;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 1;                        //original 1,  others 5
    //  allowFreeStandingZoneFaces true;
	allowFreeStandingZoneFaces false;
    // Settings for the snapping.
    snapControls
        //- Number of patch smoothing iterations before finding correspondence
        //  to surface
        nSmoothPatch 10;                         //original 3            others 10
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
        tolerance 1;
    //- Number of mesh displacement relaxation iterations.
        nSolveIter 10;                                            //others 300           original 30
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
        nRelaxIter 10;
    // Feature snapping
        //- Number of feature edge snapping iterations.
        //  Leave out altogether to disable.
        nFeatureSnapIter 10;             //original 10
        //- Detect (geometric) features by sampling the surface
        implicitFeatureSnap true;
        //- Use castellatedMeshControls::features
        explicitFeatureSnap false;
        //- Detect features between multiple surfaces
        //  (only for explicitFeatureSnap, default = false)
        multiRegionFeatureSnap true;
    addLayersControls
        layers
        relativeSizes true;
        expansionRatio 1.0;
        finalLayerThickness 0.3;
        minThickness 0.2;
        nGrow 0;
        featureAngle 60;
        nRelaxIter 5;
        nSmoothSurfaceNormals 1;
        nSmoothNormals 3;
        nSmoothThickness 10;
        maxFaceThicknessRatio 0.5;
        maxThicknessToMedialRatio 0.3;
        minMedianAxisAngle 130;
        nBufferCellsNoExtrude 0;
        nLayerIter 50;
        nRelaxedIter 20;
    meshQualityControls
        maxNonOrtho         80;
        maxConcave          80;
        minFlatness         0.5;
        minVol              1.00E-13;
        minTetQuality       -1e30;
        //1e-30 ;
        minArea             -1;
        minTwist            0.05;
        minDeterminant      0.01;
        minFaceWeight       0.01;
        minVolRatio         0.001;            //0.01
        minTriangleTwist    -1;
        nSmoothScale        4;
        errorReduction      0.75;
    debug 0;
    mergeTolerance 1E-6;
wyldckat, nisha, olivier78 and 9 others like this.
niklas is offline   Reply With Quote
Old   June 10, 2013, 05:16
niklas's Avatar
Niklas Nordin
just some more pics
Old   August 8, 2013, 09:08
Default Mesh Quality in Nikla's Experimnent
Aditya
kingmaker is on a distinguished road
Hello Niklas...
It would be very very nice if you can also the mesh quality for the above experimental cases. like the results form checkMesh. I am also now experimenting with these parameters. As far as I can understand in the above experiments of yours the mesh quality should be relatively bad for the case with all 90(good surface fit). But my question is if we have a lot of non-orthogonal and skewed faces then the simulation may not converge .. am I correct ... ??
That exactly is my problem now. I am trying to get a good mesh of a blower. But I cannot get the number of skewed faces low. I am getting about 300 skewed faces (total number of faces ~18Millon ) and my solver(MRFSimpleFoam) is not converging. I think these 300 skewed cells are causing it to diverge. Any suggestion on this issue ?? Any one ?? ..
Thank you
kingmaker is offline   Reply With Quote
Old   August 8, 2013, 13:18
niklas's Avatar
Niklas Nordin
my first question is obvious.
Are you 100% sure that it is the mesh quality that is the cause of the divergence?
I have found that usually the cause lies in the choice of the initial values of k and epsilon.
What is the initial turbulent viscosity (or length scale)?
Old   August 9, 2013, 04:27
Aditya
Hello Niklas
Thank you for the reply. I think the turbulence settings are good because, the same parameters gave me ok solution previously. I mean the solution converged. But as I wanted to get good solution I started to look at the mesh and make improvements and experiments with mesh quality parameters. And am caught in this problem I mentioned
Old   August 9, 2013, 04:37
niklas's Avatar
Niklas Nordin
ok
..still havent answered my question though
Old   August 9, 2013, 05:09
Default @Niklas
Aditya
Sorry I was away from the data so could not post it. I am using a k-omega model for turbulence and my turbulence values are :
inital K = 0.0015
initial Omega = 5
Both are uniform on the inlet which is a 140x140(mm) square
I have an inlet flow rate of 0.0011 m3/s
Thank you in advance.
Old   August 12, 2013, 08:48
niklas's Avatar
Niklas Nordin
ok, those values are pretty acceptable, so thats not it then.
dont know then.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] very bad quality snapped mesh federicabi OpenFOAM Meshing & Mesh Conversion 18 September 26, 2018 11:33
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 20:54
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 08:08
