[Other] mesh scaling on openfoam
Like Tree4Likes
  • 1 Post By reza1980
  • 2 Post By sasanghomi
  • 1 Post By colinB
Old   May 14, 2013, 07:04
Default mesh scaling on openfoam
reza1980's Avatar
reza
reza1980 is on a distinguished road
Hi Foamers,
I simulate a ship propeller by using OpenFoam .I have case files for the propeller in real size and initially approach to the results .Now, I need to scale the propeller in model size with specified scale.
Would you please let me know how to scale the files to obtain case file for the model.
/Reza
sourav90 likes this.
reza1980 is offline   Reply With Quote
Old   May 14, 2013, 08:22
Sasan Ghomi
sasanghomi is on a distinguished road
Hi Reza,
If you have a mesh file and you want to scale the geometry you can use (-scale)
for example if you have a (.msh) file you can use :
fluentMeshToFoam filename.msh -scale 0.001
Actually this code scales the geometry.
hope this helps,
Sasan.
lth and Divyajit like this.
sasanghomi is offline   Reply With Quote
Old   May 14, 2013, 08:37
reza1980's Avatar
reza
Hi Sasan,
The mesh generated by pointwise and the exported file into Openfoam are as polymesh in constant .
Old   May 14, 2013, 08:42
colinB is on a distinguished road
Hi
the utility you are looking for is called:
transformPoints
type in the terminal
transformPoints -help
to get the correct usage and available options.
regards
colinB is offline   Reply With Quote
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) Combas SU2 45 October 16, 2024 18:26
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM nsf OpenFOAM Meshing & Mesh Conversion 86 February 8, 2023 11:30
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 03:54
