[Commercial meshers] how can convert a blockMeshDict file into a mesh for Fluent? |
April 15, 2013, 14:33 |
Ehsan
Rep Power: 27 |
i have run a case in OpenFOAM and want to test it also in fluent.i have not acess to gambit now.
How can i convert simple geometry and mesh i created in fluent withot need to install gambit? I know there is a vice versa tool but i need it reciprocally. Is it possible? |
April 16, 2013, 04:58 |
Emanuele Leggio
Rep Power: 17 |
Try foamMeshToFluent
April 16, 2013, 05:53 |
Ehsan
Rep Power: 27 |
thanks.but flent execute it only in 3d mode while my case is 2d.how can delete third dimension?
April 16, 2013, 06:16 |
#4 | |
Emanuele Leggio
Rep Power: 17 |
OpenFOAM cases are only 3d, 2d openfoam case is fake because the mesh has one cell in the third dimension. The first tutorial of OpenFOAM (cavity) has the mesh in this way. For these reasons, if you want to use a mesh of OpenFOAM with Fluent you must use fluent 3d. Fluent has 3d and 2d versions but the 2d version read "real" 2d mesh and is not compatible with the OpenFOAM meshes. |
April 16, 2013, 17:32 |
Ehsan
Rep Power: 27 |
my case is 2d in real(3d in of) but 2d fluent doesn't accept it.
Isn't a way to modify the file obtained from foammeshtofluent? |
April 17, 2013, 05:27 |
Emanuele Leggio
Rep Power: 17 |
I do not know a method for changing a 3d mesh to get a 2d mesh, but I suggest you to use the 3d mesh in fluent with appropriate BC, for example I think you can use symmetry BC in Fluent to "emulate" empty BC in OpenFOAM.
April 17, 2013, 07:16 |
Ehsan
Rep Power: 27 |
thank you for your helpful answer.
Then i think dimension in z direction should be small or no matter? |
April 17, 2013, 07:30 |
Emanuele Leggio
Rep Power: 17 |
The important thing is to have one cell in z direction, the size does not matter.
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
