March 22, 2013, 12:37 |
Multi-region with layers
David Haces
Rep Power: 13 |
Hi!!
i've been building a multi-region case with snappyHexMesh. After all the difficulties I am trying to add layers. I've trying to add layers to the tutorial "snappyMultiRegionHeater" in the surfaces between the bodies but it seems impossible to me. Do you know how if it is possible to add layers to a multi-region case using snappyHexMesh?? Thanks! |
April 22, 2013, 03:34 |
Samo
You need to copy every region's mesh (one at a time) to constant/polyMesh and then run snappyHexMesh with only layer addition set to true in snappyHexMeshDict and then copy the resulting mesh back to its folder in the constant/regionName/polyMesh.
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
decomposePar does not include particles in multi region case | oswald | OpenFOAM Pre-Processing | 0 | September 3, 2018 09:47 |
[Other] mesh interface for multi region | Mohammad Jam | OpenFOAM Meshing & Mesh Conversion | 3 | December 5, 2016 08:23 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
[snappyHexMesh] Multi Region Meshing | bruce | OpenFOAM Meshing & Mesh Conversion | 12 | July 31, 2013 11:09 |
