[mesh manipulation] stitchMesh perfect vs partial
Like Tree4Likes
  • 4 Post By Eloise
Old   February 22, 2013, 11:14
Default stitchMesh perfect vs partial
Eloïse
Eloise is on a distinguished road
Dear all,
I am trying to join two meshes: a cylinder in a box. Both meshes are generated in blockMesh. The goal is not to have a sliding interface but to have an easy way to rotate a geometry inside the domain.
Here is the procedure I use in order to join them:
  1. Generate the inner cylindrical domain with blockMesh
  2. Generate the outer domain with blockMesh
  3. Merge the domains using mergeMeshes
  4. Stitch the domains using stitchMesh
  5. Remove manually the empty boundaries (0 faces) from constant/boundaries file
  6. Run solver on the final mesh
If I use the same number of faces on the internal patches and the -perfect flag for stitchMesh, this procedure works fine. (see perfect.jpg)
If I use different number of faces on the internal patches and the -partial flag for stitchMesh, some faces remain on one of the internal patch which leads to some "incorrectly oriented faces" (from checkMesh). (see partial.jpg)
I've been looking a lot around the forum and the many threads about stitchMesh but I haven't found a way to stitch internal patches which have different number of faces. Can anyone help me?
Thanks for your help,
Eloïse
Eloise is offline   Reply With Quote
Old   February 22, 2013, 12:25
Smile
Eloïse
Hi again,
I actually found the answer right after posting...
I added the -toleranceDict flag to stitchMesh, referring to a tolerance file located in the constant directory (see attachment, remove ".txt").
 stitchMesh -partial -toleranceDict toleranceDict patch1 patch2
I hope this will help someone!
Have a nice weekend,
Eloïse
elvis, nanavati, aow and 1 others like this.
Old   October 25, 2017, 11:47
Adri
Adri_12 is on a distinguished road
Thanks a lot it has solved my problem !
Adri_12 is offline   Reply With Quote
[mesh manipulation] more than two regions to join using stitchMesh partial or perfect option Lada OpenFOAM Meshing & Mesh Conversion 5 June 17, 2018 17:29
Some confusions about SST-DES (code and formulas) Alisa_W OpenFOAM 2 April 24, 2018 10:30
Low Reynolds K Epsilon Launder Sharma Model Functions Doubt... Ruonin Main CFD Forum 17 February 17, 2014 10:52
[mesh manipulation] stitchMesh -perfect - tolerance error of 2 identical faces Hanno OpenFOAM Meshing & Mesh Conversion 1 November 21, 2013 06:41
stitchMesh -partial AMI1 AMI2 reza1980 OpenFOAM 1 July 14, 2013 09:32
