[blockMesh] Aerofoil blockMesh
Like Tree10Likes
  • 1 Post By wyldckat
  • 2 Post By colinB
  • 6 Post By MadsR
  • 1 Post By elmo555
Old   February 10, 2013, 06:17
Default Aerofoil blockMesh
AndreiCFD
andrei.cimpoeru is on a distinguished road
Can anyone tell me how an ideal block topology of an aerofoil mesh looks like. There are various types of grids like O, C and H and I am struggling to get an good aerofoil mesh.
I had a go on the C mesh but i am getting a lot of non orthogonal faces combined with big skew number. Anyone any idea ?
andrei.cimpoeru is offline   Reply With Quote
Old   February 21, 2013, 13:43
Exclamation blockMesh geometry
AndreiCFD
Hi
I am trying to create an aerofoil mesh using blockMesh but I am getting bad distribution around my leading edge. I am struggling to get orthogonality on the
leading edge.......
Any ideas about how the geometry should look like?
Old   February 22, 2013, 06:20
Post BlockMesh
AndreiCFD
Has anyone an idea how a blockmesh structure for an aerofoil looks like.......I tried different blocking strategies but I am getting high skew number.
I appreciate any suggestions.
Thanks
Old   February 24, 2013, 13:20
Question NonOrtho faces blockMesh
AndreiCFD
hi there
i want to know if in openfoam is possible to get rid of the nonorthogonal faces .... below i have my mesh which failed to checkMesh
i'll appreciate your help
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
internal points: 0
faces: 16028
internal faces: 7780
cells: 3968
boundary patches: 5
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 3968
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
inlet 32 66 ok (non-closed singly connected)
outlet 124 250 ok (non-closed singly connected)
topAndBottom 124 250 ok (non-closed singly connected)
Airfoil 32 66 ok (non-closed singly connected)
frontAndBack 7936 8250 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-10 -10.0078 0) (0.30998 0 0.1)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-7.55518e-19 8.54205e-19 -2.26297e-16) OK.
Max cell openness = 2.19942e-16 OK.
Max aspect ratio = 65.8488 OK.
Minumum face area = 1.94491e-05. Maximum face area = 0.386396. Face area magnitudes OK.
Min volume = 1.94491e-06. Max volume = 0.0386396. Total volume = 8.19545. Cell volumes OK.
Mesh non-orthogonality Max: 73.7915 average: 7.97915
*Number of severely non-orthogonal faces: 3.
Non-orthogonality check OK.
<<Writing 3 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 2.56447 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Old   March 2, 2013, 09:56
Retired Super Moderator
Bruno Santos
Greetings Andrei,
I'm a bit late on this, but I've merged your questions into a single thread.
AFAIK, doing an aerofoil directly in blockMesh is a very complicated work of art! I'm not familiar with any tutorial that does this, but I do know the following:
As for the last error you were getting, it would be easier to help you if you shared a simple example on how to recreate this problem.
Best regards,
Bruno
AnthonyP likes this.
Old   March 4, 2013, 07:04
colinB is on a distinguished road
Hi Andrei, Hi Bruno,
art!
According to my experience this is not true Bruno.
I managed to create a NACA0012 in blockMesh which was actually rather
simple.
Here is a link to a thread, which also contains the answer to your last question:
- http://www.cfd-online.com/Forums/ope...-naca0012.html
post #5 has an example blockMeshDict which gives you a basic idea.
In a nut shell:
- use c-type mesh
- use any offset calculator which is around on the internet for calculating
an offset of your airfoil
- use polyLine in your blockMeshDict to introduce your foil into the mesh
I hope I could contribute
regards
wyldckat and andrei.cimpoeru like this.
colinB is offline   Reply With Quote
Old   April 2, 2013, 11:39
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
Would my airfoilmesher help you?
http://hvirvel.dk/airfoilmesher/
/Mads
wyldckat, Sethu, arvindpj and 3 others like this.
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   March 15, 2018, 12:16
Lennart
elmo555 is on a distinguished road
This website provides a small Octave script that directly generates a blockMeshDict for a C-type mesh for any NACA airfoil:
https://www.hpc.ntnu.no/display/hpc/...l+Calculations
I find it to be quite useful. I'll upload it here, in case the URL changes (GNU General Public License).
onofrio likes this.
elmo555 is offline   Reply With Quote
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 20:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
[Other] Meshing Layers over Aerofoil poloding-along OpenFOAM Meshing & Mesh Conversion 5 April 4, 2014 11:41
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 09:37
2D Aerofoil with rotating cylinders - Help & Advice! Bluejay OpenFOAM 1 December 31, 2012 05:40
