[snappyHexMesh] Extracting a subset of features
Like Tree1Likes
  • 1 Post By vkrastev
Old   December 20, 2012, 14:36
Default Extracting a subset of features
Vesselin Krastev
vkrastev is on a distinguished road
Hi all,
I am using snappyHexMesh for a quite simple external aerodynamics case (a simplified side mirror mounted on the floor of a wind tunnel) and my problem is about extracting a particular subset of feature edges. More in details, I was able to extract all the edges from the .stl geometry (the box edges as well as the mirror edges), by using:
surfaceFeatureExtract -includedAngle .....
However, actually I'm not interested in special refinement for the box edges, but only for the mirror edges, so I would like to extract only the mirror edges subset or to directly create only this set of edges. The issue is that with the includedAngle option I cannot reach the goal because it seems that always all the edges are extracted. I noticed that there is a -subsetBox option for surfaceFeatureExtract, but till now I wasn't able to let it work.
Any help about this would be greatly appreciated
Thank you in advance
V.
vkrastev is offline   Reply With Quote
Old   December 20, 2012, 18:46
Thumbs up
Vesselin Krastev
Problem solved, finally I got the proper usage of the -subsetBox and -deleteBox options. It is something like:
surfaceFeatureExtract -includedAngle 150 -subsetBox "(-0.1 -0.1 -0.3)(0.3 0.4 0.3)" ...
with the dotted part same as for the -includedAngle option alone.
V.
Ariane likes this.
Multi subset mesh motion hchen OpenFOAM Running, Solving & CFD 3 March 6, 2022 00:41
[surface handling] surfaceFeatureExtract generated features in .eMesh.gz format in triSurface file jiaodanuma OpenFOAM Meshing & Mesh Conversion 1 July 26, 2016 10:22
[Other] no snapping to features Duncan_vdH OpenFOAM Meshing & Mesh Conversion 0 October 26, 2015 10:12
beta hidden features Bogdan CFX 1 April 20, 2007 09:51
ICEMCFD: subset "smooth_show_map" Andy CFX 2 October 31, 2006 08:57
