[Gmsh] .stl from GMSH in SnappyHexMesh
Like Tree1Likes
  • 1 Post By mturcios777
Old   November 27, 2012, 12:56
Default .stl from GMSH in SnappyHexMesh
Robert
vainilreb is on a distinguished road
is it possible to use a 2D-Mesh from GMSH which is saved in the .stl-format as stl-input for snappyHexMesh?
Or is there any other way to extract an stl-File from a geometry which was modelled in GMSH?
Thank you very much!
Robert
vainilreb is offline   Reply With Quote
Old   November 27, 2012, 13:27
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hi Robert,
Do you mean a 2D geometry to make a 2D case in snappyHexMesh? I've never heard of doing a 2D case in snappy, but I guess you could do it.
As long as you have an STL file, snappyHexMesh will read it. As to what happens after that, there is only one way to find out...
mturcios777 is offline   Reply With Quote
Old   November 27, 2012, 13:41
Robert
No, I mean a 3D-geometry created in gmsh. I want to save it as .stl to mesh it with snappyHexMesh. But I don't know how to get an .stl from a .geo! :/
I tried simply 2D-meshing the 3D-geometry and then saving the mesh in the stl format, but so far that does not work at all.
Old   November 27, 2012, 14:11
Marco A. Turcios
Ah, I see now. You should be able to mesh as long as you get the STL. Have you checked that the STL is watertight? You can inspect the STL in paraview, have a look and see if there are any serious problems, maybe post a picture somewhere.
Old   November 29, 2012, 04:42
Robert
Well, the stl looks good. Unfortunately gmsh did not save the physical groups to the file? The stl is a simple desk with an inlet patch where I want ammonia to be added to the system.
Could it be a problem that the stl contains surfaces which intersect the walls of the blockMesh geometry? I'm talking about the lower surfaces of the desk's legs. Maybe I should leave them away?
Old   November 29, 2012, 06:52
Robert
Snappy finally did it! Once I have figured out how to divide the surfaces into different physical groups I will be happy.
Old   November 29, 2012, 15:12
Marco A. Turcios
Glad to hear it worked well; please be sure to post your solution so that future users can benefit from it. There are many threads on splitting geometry up into patches. I personally prefer splitting the surface into multiple files, as it makes it easier to isolate a problem patch.
I use blender for when I need to see the geometry to manipulate it, or write an octave/matlab script to separate out the triangles based on certain criteria.
Nicole likes this.
Old   March 19, 2020, 09:54
Default geo to stl
muhammet çevik
muhmt.cvk is on a distinguished road
hi
I write matlab code to generate 3d geo file . I am trying to change to format to stl to run snappyhexmesh. I am using GMSH to convert geo file to stl file but snapp seems doesnt recognize the file. what I understand you also tried samething. Could you help me about it if its work for you
muhmt.cvk is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh fails to create patches of .stl files WernerW OpenFOAM Meshing & Mesh Conversion 4 September 26, 2017 01:59
[Gmsh] gMsh instead of blockMesh for base mesh, then snappyHexMesh sazabi2001 OpenFOAM Meshing & Mesh Conversion 0 February 23, 2017 13:00
[snappyHexMesh] SnappyHexMesh .stl Jochem OpenFOAM Meshing & Mesh Conversion 10 September 23, 2016 05:26
[snappyHexMesh] snappyHexMesh does not create boundary patches from .stl files bug_or_feature OpenFOAM Meshing & Mesh Conversion 7 August 30, 2016 20:18
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
