August 23, 2012, 11:50 |
datToFoam
Rep Power: 16 |
hello!
it's my first time using openfoam and i can't even import my mesh my inputfile is a nastran bulkdata file (.dat) the syntax is really simple: BEGIN BULK (koordinate and number of the nodes) GRID,1,,588062.321633,253262.321633,1798.662318 GRID,2,,588062.321633,253392.110575,1760.908129 ... (number of the hexaedra nd the needed nodenumbers) CHEXA 140928 145776 145835 145836 145777 149257 149316+ + 149317 149258 i found the application dattofoam but theres no documentation what file exactly. is it for nastran datfiles? because i always get this error: Build : 2.1.1-221db2718bbb Exec : datToFoam -noFunctionObjects planner.dat Date : Aug 23 2012 Time : 07:25:57 Host : "ubuntu" PID : 5661 Case : /home/stefan/OpenFOAM/stefan-2.1.1/run/dattofoam nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: wrong token type - expected word, found on line 0 the punctuation token ';' file: IStringStream.sourceFile at line 0. From function operator>>(Istream&, word&) in file primitives/strings/word/wordIO.C at line 74. FOAM exiting i hope you can help me. |
August 23, 2012, 15:24 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings chaos,
Welcome to using OpenFOAM! Since it's open-source, you have to go straight to the source code: https://github.com/OpenFOAM/OpenFOAM...am/datToFoam.C Or go to the code documentation: http://www.openfoam.org/docs/cpp/ - search for datToFoam. Seems like datToFoam isn't for Nastran files, because it references explicitly in the code this: Code:
std::ifstream plot3dFile(args.args()[1].c_str()); Code:
surfaceConvert a.nas a.stl Bruno
August 27, 2012, 03:22 |
Rep Power: 16 |
thx for your help!
i also looked up the sourcecode but wasn't shure if it's compatible. ok than i'll have to code it on my own. thx again! |
