how to install openfoam on ubuntu 1.4 ?
Like Tree3Likes
  • 1 Post By wyldckat
Old   August 5, 2011, 16:12
Question how to install openfoam on ubuntu 1.4 ?
seyedashraf's Avatar
Omid Seyedashraf
seyedashraf is on a distinguished road
Send a message via AIM to seyedashraf Send a message via Yahoo to seyedashraf
It's highly appreciated if you can illustrate, step by step, how to install openfoam on ubuntu 1.4 to an armature Ubuntu users (its just a couple of days that I have installed ubuntu )
I have downloaded these two files from openfoam website
gcc-4.2.1.linux.tgz
ThirdParty-2.0.0.gtgz
seyedashraf is offline   Reply With Quote
Old   August 10, 2011, 06:08
Elvis
elvis will become famous soon enough
take a look at http://www.openfoam.com/download/ubuntu.php
alternative way to install http://www.openfoam.com/download/source.php
or git install http://www.openfoam.com/download/git.php
you may also have a look at OFwiki
http://openfoamwiki.net/index.php/Installation
http://openfoamwiki.net/index.php/Ho...sitory_version)
The blogs and posts from Bruno Santos http://www.cfd-online.com/Forums/members/wyldckat.html
are of great value
elvis is offline   Reply With Quote
Old   August 10, 2011, 08:28
Omid Seyedashraf
thanks for the reply
the problem is, its just a couple of days I have installed ubuntu
and dont know how to install applications in it
for example in the second link
it says:
After the installation directory is chosen (and, if necessary, created), simply copy the 2 source pack files into the directory and unpack using tar xzf <filename>, e.g. from the installation directory:
tar xzf OpenFOAM-2.0.1.gtgz
tar xzf ThirdParty-2.0.1.gtgz
I dont know what it means by " unpack using tar xzf <filename>,"
for this I created this topic looking for simpler way or maybe an illustration with some screenshots, video tutorials etc for a novice ubuntu user
Old   August 11, 2011, 07:32
Retired Super Moderator
Bruno Santos
Greetings to both!
@seyedashraf:
I've seen this thread a few times and felt unwilling to reply, because OpenFOAM still requires people to pull back their sleeves and start searching for answers... specially since OpenFOAM is almost 100% command line oriented
Anyway, for people who are new to Ubuntu, they should start looking for tutorials about using Ubuntu! In this case, the door to what you seek is this tutorial: Ubuntu Linux Tutorial Chapt12. Introduction to the Terminal 1
This video tutorial explains how to use the Ubuntu terminal and where it is accessible. From there, you can then follow the instructions written on the official pages at www.openfoam.com.
This will be sort-of like taking a drivers license, because with OpenFOAM (and most CFD software), one must train their eyes and their perception capabilities to be very focused on what one is doing. One wrong command, one wrong character, or even one wrong space, could lead to disaster...
OK, maybe it's not this dangerous, but if one puts the decimal point one digit to the left or right, one will have either 10x or 0.1 times the gravity acceleration; or even happen what happened with me a few years ago, where my geometry was defined in mm, instead of m... which meant that I was trying to simulate about 1/10th of the Earth's atmosphere, instead of one single living room
But I digress... basically installing OpenFOAM is like when butterflies are born: it's necessary tons of patience during gestation and then a lot of effort to get out of the cocoon. Any help during that process could lead to a reduced life expectancy for the butterfly In this case, newbies might give up on OpenFOAM a lot sooner, even after having installed OpenFOAM... although if they can't even install it, they give up without really starting...
Either way, fear not because a lot of video instructions are already available for using OpenFOAM! Many of them are on this thread: http://www.cfd-online.com/Forums/ope...-openfoam.html
Last but not least: after you've finally managed to install OpenFOAM, consider if you want to make a video about how to install it in Ubuntu
Best regards,
Bruno
romant likes this.
Old   August 12, 2011, 17:31
Omid Seyedashraf
thanks
there must be some great tips in Thouelfaqar's rapidshare videos
BTW
for those who come across this thread having the same questions like me
this blog could also be handy
http://code-saturne.blogspot.com/201...on-ubuntu.html
Old   August 23, 2011, 05:56
Default hiiiiiiiiiii
Jignesh
jignesh_thaker2007 is on a distinguished road
Send a message via Yahoo to jignesh_thaker2007
thanks
BTW
i install openfoam ubuntu pack then its necessary to intall source pack & git repository pack?
plz give me reply
jignesh_thaker2007 is offline   Reply With Quote
Old   August 23, 2011, 06:38
Bruno Santos
Already answered jignesh_thaker2007 here: OpenFoam 2.0.0 installation - post #60
drrbradford likes this.
Old   August 23, 2011, 06:47
Jignesh
thanks sir
Sir, i will take some time in future because i m new user of openfoam sir plz tel me how to convert the data file of openfoam in to .dat or .plt format
because i convert the file foam to tecplot so what is the procedure for that?
Old   August 23, 2011, 06:50
Bruno Santos
Already answered here: foamToTecplot360 post #17
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 16:15
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 09:33
How to install the OpenFoam in the cluster. Please help me! flying OpenFOAM Installation 6 November 27, 2009 04:00
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 01:48
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
