OpenFOAM 14 Parallel build
Like Tree2Likes
  • 2 Post By mbeaudoin
Old   May 8, 2007, 12:09
Default Hi all... I've been using Open
Mike Long
mplongjr is on a distinguished road
Hi all... I've been using OpenFOAM 1.3 for several months now and I've been very impressed with it's capabilities. In the 1.4 release notes, there is mention of a parallel build process with wmake, but I can't find any mention of how to initiate it.
I naively tried ./Allwmake -j 2 .. but it didn't seem to use more than one process..
Is there something I'm missing?
mplongjr is offline   Reply With Quote
Old   May 8, 2007, 22:48
Default Mike, There is a new enviro
Martin Beaudoin
mbeaudoin will become famous soon enough
Mike,
There is a new environment variable called $WM_NCOMPPROCS.
Check out the file $WM_DIR/wmake for the details.
The funny thing is: that variable is not initialized under OpenFOAM 1.4.
Just add the following line to your $WM_PROJECT_DIR/$FOAM_DOT_DIR/bashrc
export WM_NCOMPPROCS=2
Adjust the number to the number of processors you want to use for compiling.
(For csh, adjust your file $WM_PROJECT_DIR/$FOAM_DOT_DIR/cshrc
setenv WM_NCOMPPROCS 2
Enjoy,
Martin
lakeat and serles like this.
mbeaudoin is offline   Reply With Quote
Old   May 9, 2007, 12:28
Default Thanks Martin... that worked p
Mike Long
Thanks Martin... that worked perfectly. I've been trying out some different optimizations with the pre-release GCC 4.2 and it really helps cutting the compile time down.
Mike
Old   May 15, 2007, 04:32
Default You can also distribute parall
Mattijs Janssens
mattijs is on a distinguished road
You can also distribute parallel builds. Works great on clusters. See the Wiki page about wmake.
mattijs is offline   Reply With Quote
OpenFOAM 15 icc build mschoenberg OpenFOAM Installation 4 October 2, 2008 01:09
How can I build OpenFOAM in cygwin joywe OpenFOAM Installation 10 September 12, 2008 10:39
Build OpenFOAM on MacOSX Mauro Augelli (Augelli) OpenFOAM Installation 101 July 21, 2008 07:42
OpenFOAM build from source instructions tj22 OpenFOAM Installation 7 April 6, 2006 17:15
Build OpenFOAM on Tru64 francois OpenFOAM Installation 18 April 4, 2006 06:45
