March 9, 2006, 08:51 |
Hi!
I have installed OpenFO
Rep Power: 17 |
Hi!
I have installed OpenFOAM on a Suse linux 10.0 machine and it works fine, but paraFoam fails to start due to a segmentation fault: /home/gaffu/OpenFOAM/OpenFOAM-1.2/bin/paraFoam: line 57: 1638 Segmentation fault paraview paraFoam.pvs The installation test script gives no error: Executing ./foamInstallationTest: ************************************************** ****** Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: linux OS: Linux version 2.6.13-15-default User: gaffu User_config: /home/gaffu/.bashrc Foam_config: /home/gaffu/.OpenFOAM-1.2/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/gaffu/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/gaffu/OpenFOAM/gaffu-1.2 yes no $FOAM_JOB_DIR /home/gaffu/OpenFOAM/jobControl no yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/gaffu/OpenFOAM/OpenFOAM-1.2 yes yes yes $FOAM_USER_APPBIN ...fu-1.2/applications/bin/linuxGcc4Opt yes yes no $FOAM_APPBIN ...AM-1.2/applications/bin/linuxGcc4Opt yes yes yes $WM_DIR /home/gaffu/OpenFOAM/OpenFOAM-1.2/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /home/gaffu/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH ...c/mico-2.3.11/platforms/linuxGcc4Opt yes yes yes $LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...enFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt yes yes yes $FOAM_USER_LIBBIN .../OpenFOAM/gaffu-1.2/lib/linuxGcc4Opt yes yes no $LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.0.1 /home/gaffu/OpenFOAM/linux/gcc-4.0.1/bin/gcc java 1.4.2_05 /home/gaffu/OpenFOAM/linux/j2sdk1.4.2_05/bin/java gzip 1.3.5 /usr/bin/gzip tar 1.3.5 /bin/tar icoFoam ...OAM/OpenFOAM-1.2/applications/bin/linuxGcc4Opt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_linux Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. ************************************************** ******* I have paraview 2.4.2 installed in /usr/local/, can this create a conflict with paraview 2.2.0 installed in $HOME/Openfoam/linux/ ? Any suggestions are welcomed! |
March 9, 2006, 09:14 |
You should check the LD_LIBRAR
You should check the LD_LIBRARY_PATH and make sure it is not conflicting with you paraview-2.4.2 version. Look into $WM_PROJECT_DIR/.OpenFOAM-1.2/apps/paraview/cshrc (bashrc).
For your information it is possible to compile OpenFOAM-1.2 with your own paraview-2.4.2, by making adequat modifications in the previous cshrc (bashrc) files and in $WM_PROJECT_DIR/applications/utilities/postProcessing/graphics/PVFoamReader/ You have to recompile the libvtkFoam and libPVFoamReader specifying a CMake-2.2.* installation. I have successfully done it with paraview-2.4.2 and the current CVS paraview-2.5, on a Suse 10 box (both paraview and openfoam compiled with gcc-2.0.4). HTH Theophane |
March 9, 2006, 09:25 |
Propably. If the parafoam-exec
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Propably. If the parafoam-executable of 2.4.2 is found before the OpenFOAM-paraview (check with 'which paraview') you have this problem. Reorganize the PATH-variable in this case (the same is true for the LD_LIBRARY_PATH-variable for the dynamically-linked libraries)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
March 9, 2006, 10:03 |
I modified the path in $WM_PRO
Rep Power: 17 |
I modified the path in $WM_PROJECT_DIR/.OpenFOAM-1.2/apps/paraview/bashrc
Now it works fine Thank you! |
November 11, 2008, 09:44 |
Help please! I ahve the same p
Zhizhong Li
Rep Power: 17 |
Help please! I ahve the same problems. How did you modify the path?
March 31, 2010, 09:38 |
yannH
Rep Power: 16 |
Hi everybody !
I got a segmentation fault when running paraview. When I installed it last week, everything works, but since I use groovyBC, it doesn't work any more, even for (tutorial cases). I recompile but no changes, and I try to debug it, (but I'm not a debugger at all !) : -------------- Program received signal SIGSEGV, Segmentation fault. [Switching to Thread 0xb18f26f0 (LWP 14008)] 0x00018810 in ?? () (gdb) bt #0 0x00018810 in ?? () #1 0xafc7498c in ?? () from /home/yhh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libdecompositionMethods.so #2 0xb7f1e9d0 in ?? () from /lib/ld-linux.so.2 #3 0xb7f1eb03 in ?? () from /lib/ld-linux.so.2 #4 0xb7f227b4 in ?? () from /lib/ld-linux.so.2 #5 0xb7f1e606 in ?? () from /lib/ld-linux.so.2 #6 0xb7f21f8e in ?? () from /lib/ld-linux.so.2 #7 0xb6b61c19 in ?? () from /lib/tls/i686/cmov/libdl.so.2 #8 0xb7f1e606 in ?? () from /lib/ld-linux.so.2 #9 0xb6b622bc in ?? () from /lib/tls/i686/cmov/libdl.so.2 #10 0xb6b61b51 in dlopen () from /lib/tls/i686/cmov/libdl.so.2 #11 0xb2f45765 in vtksys:ynamicLoader::OpenLibrary () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libvtksys.so.pv3.6 #12 0xb30f607d in vtkDynamicLoader::OpenLibrary () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libvtkCommon.so.pv3.6 #13 0xb62524a8 in vtkPVPluginLoader::SetFileName () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libvtkPVServerCommon.so #14 0xb7a132a8 in pqPluginManager::loadServerExtension () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libpqCore.so #15 0xb7a14e6b in pqPluginManager::loadExtension () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libpqCore.so #16 0xb7a15361 in pqPluginManager::loadExtensions () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libpqCore.so #17 0xb7a15bc9 in pqPluginManager::loadExtensions () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libpqCore.so #18 0xb7a16a0e in pqProcessModuleGUIHelper:reAppExec () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libpqCore.so #19 0xb6222b04 in vtkProcessModule::StartClient () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libvtkPVServerCommon.so #20 0xb6224625 in vtkProcessModule::Start () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libvtkPVServerCommon.so #21 0xb622b054 in vtkProcessModuleGUIHelper::Run () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libvtkPVServerCommon.so #22 0xb79e6329 in pqMain::Run () from /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/libpqCore.so #23 0x0804ad5e in main () (gdb) at A program is being debugged already. Kill it? (y or n) y Argument required (process-id to attach). (gdb) run Starting program: /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/paraview-real /home/yhh/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/paraview-real: error while loading shared libraries: libpqComponents.so: cannot open shared object file: No such file or directory Program exited with code 0177. (gdb) ---------------------- The curious thing is that it says libpqComponents.so cannot open, but I check and it's present in /platforms/linuxGcc/bin and /platforms/linuxGcc/lib ! Is it a problem of path ? |
November 4, 2011, 21:55 |
Robin Gilbert
Rep Power: 16 |
November 5, 2011, 04:15 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greeting Robin...
this is a really old thread... Robin, can you please describe the following details:
Best regards, Bruno
November 10, 2011, 19:35 |
#9 | |
Robin Gilbert
Rep Power: 16 |
Greetings wyldckat,
Thank you for your reply. I am using ubuntu 10.04 gcc version 4.3.3 (OpenFOAM) OpenFOAM 1.6.x Quote:
It used to work properly but stopped working after i installed swak4Foam But recently i found a work around. I go to this location in my computer : /home/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin and open paraview directly. only thing is i have to convert all files to VTK before postprocessing. Any ideas on how i can rectify the problem?? Sorry for the late reply Last edited by robingilbert; November 11, 2011 at 19:12. |
November 12, 2011, 04:51 |
#10 |
Bruno Santos
Rep Power: 128 |
Hi Robin,
OK, a quick and dirty way to fix this is to edit the file "OpenFOAM-1.6.x/bin/paraFoam" and add the following line (the one in bold) right after the first block of comments: Code:
# Description # start paraview with the OpenFOAM libraries # #------------------------------------------------------------------------------ export LD_LIBRARY_PATH=$ParaView_DIR:$LD_LIBRARY_PATH usage() { while [ "$#" -ge 1 ]; do echo "$1"; shift; done The odd thing is that it stopped working after swak4foam was built... maybe this is one of those bugs that has already been fixed in more recent versions of swak4foam and OpenFOAM Best regards, Bruno
November 14, 2011, 14:33 |
#11 |
Robin Gilbert
Rep Power: 16 |
Hi Bruno,
What you said did not work. What is LD_LIBRARY_PATH ? which directory does it point to? i cd-ed it and it said this: Code:
bash: cd: /home/bluesim/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/openmpi-1.3.3:/home/bluesim/OpenFOAM/ThirdParty-1.6.x/openmpi-1.3.3/platforms/linux64GccDPOpt/lib:/home/bluesim/OpenFOAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux64/lib64:/home/bluesim/OpenFOAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux64/lib:/home/bluesim/OpenFOAM/ThirdParty-1.6.x/gmp-4.2.4/platforms/linux64/lib:/home/bluesim/OpenFOAM/ThirdParty-1.6.x/mpfr-2.4.1/platforms/linux64/lib:/home/bluesim/OpenFOAM/bluesim-1.6.x/lib/linux64GccDPOpt:/home/bluesim/OpenFOAM/site/1.6.x/lib/linux64GccDPOpt:/home/bluesim/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt:/home/bluesim/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/dummy: No such file or directory |
November 14, 2011, 16:09 |
#12 | ||
Bruno Santos
Rep Power: 128 |
Hi Robin,
If the modification I wrote about in the previous post didn't work, then could you please check if:
Bruno
November 16, 2011, 16:05 |
#13 | |
Robin Gilbert
Rep Power: 16 |
Greetings Bruno,
/home/bluesim/OpenFOAM/ThirdParty-1.6.x/paraview-3.6.1/platforms/linux64Gcc Code:
ls: cannot access /home/bluesim/OpenFOAM/ThirdParty-1.6.x/paraview-3.6.1/platforms/linux64Gcc/libpqComponents*: No such file or directory Robin |
November 16, 2011, 17:30 |
#14 |
Bruno Santos
Rep Power: 128 |
Hi Robin,
You didn't post what the following command displays: Code:
ls -l $ParaView_DIR Code:
ls -l $ParaView_DIR/bin/libpqComponents* Code:
# Description # start paraview with the OpenFOAM libraries # #------------------------------------------------------------------------------ export LD_LIBRARY_PATH=$ParaView_DIR/bin:$LD_LIBRARY_PATH usage() { while [ "$#" -ge 1 ]; do echo "$1"; shift; done Bruno
November 17, 2011, 18:50 |
#15 |
Robin Gilbert
Rep Power: 16 |
Hi Bruno,
total 432 -rw-r----- 1 bluesim bluesim 1087 2011-11-04 17:51 about.html drwxr-xr-x 4 bluesim bluesim 4096 2011-11-04 18:17 Applications drwxr-xr-x 2 bluesim bluesim 12288 2011-11-04 19:13 bin drwxr-xr-x 3 bluesim bluesim 4096 2011-11-04 17:51 CMake -rw-r--r-- 1 bluesim bluesim 127257 2011-11-04 18:17 CMakeCache.txt drwxr-xr-x 34 bluesim bluesim 4096 2011-11-04 18:17 CMakeFiles -rw-r--r-- 1 bluesim bluesim 6021 2011-11-04 18:17 cmake_install.cmake -rw-r--r-- 1 bluesim bluesim 1547 2011-11-04 18:17 CMakeOutput.log drwxr-xr-x 2 bluesim bluesim 4096 2011-11-04 17:51 CMakeTmp drwxr-xr-x 4 bluesim bluesim 4096 2011-11-04 18:17 Common -rw-r----- 1 bluesim bluesim 4350 2011-11-04 18:17 CPackConfig.cmake -rw-r----- 1 bluesim bluesim 4622 2011-11-04 18:17 CPackSourceConfig.cmake -rw-r----- 1 bluesim bluesim 3940 2011-11-04 17:51 CTestCustom.ctest -rw-r--r-- 1 bluesim bluesim 570 2011-11-04 18:17 CTestTestfile.cmake -rw-r----- 1 bluesim bluesim 1798 2011-11-04 17:51 DartConfiguration.tcl drwxr-xr-x 3 bluesim bluesim 20480 2011-11-04 18:17 Documentation drwxr-xr-x 2 bluesim bluesim 4096 2011-11-04 18:17 lib -rw-r--r-- 1 bluesim bluesim 88984 2011-11-04 17:51 Makefile -rw-r--r-- 1 bluesim bluesim 9840 2011-11-04 18:17 ParaView3CompileToolsConfig.cmake -rw-r----- 1 bluesim bluesim 1000 2011-11-04 18:17 ParaView3CPackOptions.cmake -rw-r----- 1 bluesim bluesim 3370 2011-11-04 18:17 ParaViewConfig.cmake -rw-r--r-- 1 bluesim bluesim 28445 2011-11-04 17:51 ParaViewLibraryDepends.cmake -rw-r--r-- 1 bluesim bluesim 550 2011-11-04 17:51 PluginList.txt drwxr-xr-x 6 bluesim bluesim 4096 2011-11-04 18:17 Plugins -rw-r--r-- 1 bluesim bluesim 31814 2011-11-04 18:17 pqClient.adp drwxr-xr-x 8 bluesim bluesim 4096 2011-11-04 18:17 Qt drwxr-xr-x 8 bluesim bluesim 4096 2011-11-04 18:17 Servers drwxr-xr-x 3 bluesim bluesim 4096 2011-11-04 17:51 Testing drwxr-xr-x 5 bluesim bluesim 4096 2011-11-04 17:51 Utilities drwxr-xr-x 24 bluesim bluesim 4096 2011-11-04 18:17 VTK -rw-r----- 1 bluesim bluesim 1763 2011-11-04 17:51 vtkPQConfig.h -rw-r----- 1 bluesim bluesim 1645 2011-11-04 17:51 vtkPVConfig.h Code:
-rwxr-xr-x 1 bluesim bluesim 4834428 2011-11-04 18:16 /home/bluesim/OpenFOAM/ThirdParty-1.6.x/paraview-3.6.1/platforms/linux64Gcc/bin/libpqComponents.so Robin. |
November 18, 2011, 17:42 |
#16 |
Bruno Santos
Rep Power: 128 |
Hi Robin,
OK, I guess that we'll have to try and to isolate the problem on the other side. You wrote before that things stopped working when you compiled/installed swak4foam, correct? Then try renaming the folder "/home/bluesim/OpenFOAM/bluesim-1.6.x/" to something else. For example, run: Code:
cd /home/bluesim/OpenFOAM mv bluesim-1.6.x bluesim-1.6.x_tmp If it still complains about the same problem, then it should be because you changed something else as well, when you built swak4foam. Best regards and good luck! Bruno
November 18, 2011, 20:05 |
#17 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
- Does paraview fail for all cases or only those where groovyBC is used? Try adding "libOpenFOAM.so" to the libs-list in the controlDict BEFORE libgroovyBC.so. Funnily enough this is only needed on Linux (not on the other OS with X in the end) - Is it possible that some libraries ended up in $PV_PLUGIN_PATH (possibly because $FOAM_USER_LIBBIN is there)? Because then paraview will try to load them as plugins and fail miserably Bernhard |
Segmentation fault. | Nari | Siemens | 3 | November 8, 2007 06:04 |
segmentation fault | Suman | Siemens | 2 | June 26, 2007 04:14 |
segmentation fault | Sheila | Siemens | 8 | October 9, 2005 06:40 |
segmentation fault | natesan | Siemens | 4 | January 12, 2004 09:51 |
Segmentation fault | Veebs | Siemens | 3 | June 4, 2002 23:17 |
