[OpenFOAM.org] surfaceFeatures: command not found on WSL2 install v2312 |
September 22, 2024, 15:38 |
Oliver Sedlacek
Rep Power: 3 |
I've googled this but as a newbie I'm none the wiser. I've installed OpenFoam 2312 and tried the pitzDaily tutorial as recommended and that ran fine. Next step was the motorBike tutorial and blockMesh ran fine, but when I type surfaceFeatures I get
surfaceFeatures: command not found Any suggestions? |
September 23, 2024, 04:21 |
Yann
Rep Power: 29 |
In the OpenCFD branch (openfoam.com), the utility you are looking for is surfaceFeatureExtract. In the OpenFOAM foundation branch (openfoam.org), surfaceFeatureExtract has been renamed surfaceFeatures since OpenFOAM-6. As general advice, be careful to use resources/documentation matching the OpenFOAM branch/version you are using. (or the other way around, install the version matching the resources you want to follow) Cheers, Yann |
September 23, 2024, 05:43 |
Thanks
Oliver Sedlacek
Rep Power: 3 |
I was unaware of any distinction between .org and .com software. I'll look out for it. When googling the tutorials I usually end up on Youtube because I'm not finding the official tutorials sufficiently helpful for a newbie.
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 22:45 |
Install problem in linux | navaladi | OpenFOAM Installation | 11 | July 17, 2008 03:24 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
