[Other] Create a user defined folder to access like $FOAM_RUN
Like Tree1Likes
  • 1 Post By 2538sukham
Old   February 28, 2024, 11:48
Default Create a user defined folder to access like $FOAM_RUN
Michael Sukham
2538sukham is on a distinguished road
I want to create different folders with alias like that of $FOAM_RUN which we can access by typing run. Example folders PHD, WORK etc which we can access using alias. Can someone help me with this? With ~/.bashrc I am not sure how to achieve this and I don't want to break my OpenFOAM installation.
Any help is appreciated.
2538sukham is offline   Reply With Quote
Old   February 29, 2024, 15:12
Shravan
Severus is on a distinguished road
If you want to change directory in terminal using alias, open your bashrc and add the following lines at the end
Case 1: You want to change directory to a folder not in the /home/ path
Lets say you want to change directory to a folder openfoam8 located in /opt/, then use
alias OF8_DIR='cd /opt/openfoam8/'
Case 2: You want to change directory to a folder that is in the /home/ path
Lets say you want to change directory to a folder called PHD_folder that is located in /home/Michael/, then use
alias PHD='cd ~/PHD_folder '
Case 3: You want to open a folder in the file manager and view it (for a GNOME desktop environment)
Lets say you want to a folder openfoam8 located in /opt/, then use
alias openfoam='nautilus /opt/openfoam8/'
Once you paste it in the end of bashrc, then open a new terminal and do this
source .bashrc
Now you should be able change directories
Note
In order to avoid making mistakes take a backup of your current bashrc, it will be useful and restore it just in case you mess up something
You can also check this thread for restoring the default bashrc: https://unix.stackexchange.com/quest...hrc-file-again
Thanks
Severus is offline   Reply With Quote
Old   March 1, 2024, 04:09
Michael Sukham
source .bashrc
Note
Thanks
Works like a charm!! I went for case2 which I added at the end of bashrc file: alias phd='cd /home/mikeyfluids/OpenFOAM/PhD' then sourced it : source ~/.bashrc
Now I get how the alias work. I can even alias paraFoam installed in windows using the same procedure since I am using wsl2 .
I consider the thread solved and closed !!
Thank you Shravan!
Severus likes this.
Create connectors with user defined distribution Nguyen Le Hai Pointwise & Gridgen 0 February 20, 2021 09:02
"decomposePar" not decomposing volumeVectorField located inside user defined folder kavatar OpenFOAM Running, Solving & CFD 0 December 11, 2020 02:32
[waves2Foam] Add user defined gauges in waveFoam Lewis Liang OpenFOAM Community Contributions 3 October 18, 2020 11:32
User defined time step - Possible to put variable time stepping in it? maccheese Fluent UDF and Scheme Programming 19 June 4, 2018 10:49
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
