[OpenFOAM.org] Unable to Install OpenFOAM11 on M3 MacBook Pro With Docker |
January 7, 2024, 12:45 |
Richard Fox
Hi
I have been been trying to install OpenFOAM 11 on my M3 MacBook Pro but without success. I have been following the instructions on the OpenFOAM installation page and have followed steps: 1. Downloaded Paraview and checked that sudo is working. 2. Installed Docker (can open Docker Desktop - but little to no understanding) 3. Attempted to install openfoam 11 with the following 2 commands: sudo curl --create-dirs -o /usr/local/bin/openfoam11-macos http://dl.openfoam.org/docker/openfoam11-macos sudo chmod 755 /usr/local/bin/openfoam11-macos 4. Downloaded Quartz - checked the boxes: 'Allow connections from network clients' and 'Authenticate connections'. And then restarted XQuartz. 5. Omitted this section as I had read that this was not necessary. (Taken on trust because I don't know). Step 6 . Attempted to run OpenFOAM with the following text input: cd OpenFOAM-Docker openfoam11-macos I then get the following: richardfox@Richards-MacBook-Pro OpenFOAM-Docker % ls openfoam11-macos openfoam11-macos.txt richardfox@Richards-MacBook-Pro OpenFOAM-Docker % openfoam11-macos No directory exists: Usage: openfoam11-macos [OPTIONS] options: -d | -dir host directory mounted (defaults to current directory) -h | -help help -p | -paraview [vers] include paraview, with version 56 | 510 (default) -u | -upgrade install latest upgrades to the Docker image -x | -xhost use custom X authority and give container host network Launches the OpenFOAM-11 Docker image. - Requires installation of docker-engine. - Runs a "containerized" bash shell environment where the user can run OpenFOAM and, optionally, ParaView (see below). - The container mounts the user's file system so that case files are stored permanently. The container mounts the current directory by default, but the user can also specify a particular directory using the "-d" option. - Mounting the user's HOME directory is disallowed. - The '-xhost' option is useful when accessing the host via 'ssh -X'. This option should only be used when strictly necessary, as it relies on the option '--net=host' when launching the container in Docker, which will give to the container full access to the Docker host network stack and potentially the host's system services that rely on network communication, making it potentially insecure. ParaView: Graphical applications from the Docker container require installation of the Xquartz X server to display on the host machine. While applications such as Gedit, Emacs and GnuPlot will run effectively using Xquartz, more intensive OpenGL applications, in particular ParaView, can be prohibitively slow. Therefore, the default Docker image does not contain ParaView and users can instead install ParaView directly from the vendor and use the built-in reader module for OpenFOAM: https://www.paraview.org/download However, if the user wishes to include ParaView with the official OpenFOAM reader module in their Docker container, they can do so with the "-p" option. Example: To store data in /Users/richardfox/OpenFOAM/richardfox-11, the user can launch openfoam11-macos either by: cd /Users/richardfox/OpenFOAM/richardfox-11 && openfoam11-macos or openfoam11-macos -d /Users/richardfox/OpenFOAM/richardfox-11 Further Information: https://openfoam.org/download/11-macos Note: The container user name appears as "openfoam" but it is just an alias. richardfox@Richards-MacBook-Pro OpenFOAM-Docker % openfoam11-macos I have tried this many times and have tried some other ways which escape me now but I am stumped. Please can someone help? Thanks in advance. Richard (p.s. apologies if any pertinent detail is missing - I am really not experienced in this). |
January 13, 2024, 13:26 |
faris
I have the exact same error and I couldn't find any solution. I am using an Intel Macbook with macOS 13.4.
Hopefully someone can help. |
January 16, 2024, 01:21 |
Peter Wallhead
Followed same steps as the OP and hit the same issue here, macOS 13.6.
Instructions used were from https://openfoam.org/download/11-macos/ |
January 29, 2024, 15:51 |
I also have same problem and not able to solve it yet
February 9, 2024, 22:14 |
my workaround
Maetee Lor
Rep Power: 2 |
You have to edit the openfoam11-macos that you downloaded using your favorite text editor following:
1. change the line no. 92 from docker_image='openfoam/openfoam$ver-graphical-apps' to docker_image="openfoam/openfoam$ver-graphical-apps" 2. remove the line no. 143-144 [ -d "$MOUNT_DIR" ] || usage "No directory exists: $MOUNT_DIR" MOUNT_DIR=$(cd "$MOUNT_DIR" && pwd -P) 3. Save and rerun the openfoam11-mac the following is the content of the file that I can run normally. #!/bin/sh #------------------------------------------------------------------------------ # ========= | # \\ / F ield | OpenFOAM: The Open Source CFD Toolbox # \\ / O peration | # \\ / A nd | Copyright (C) 2017-2023 OpenFOAM Foundation # \\/ M anipulation | #------------------------------------------------------------------------------- # License # This program is free software: you can redistribute it and/or modify it # under the terms of the GNU General Public License as published by # the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # This program is distributed in the hope that it will be useful, but # WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY # or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License # for more details. # # You should have received a copy of the GNU General Public License # along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. # # Script # openfoam11-macos # # Description # Run script for an OpenFOAM 11 Docker image at: # https://hub.docker.com/r/openfoam # #------------------------------------------------------------------------------ Script=${0##*/} ver=11 usage () { exec 1>&2 while [ "$#" -ge 1 ]; do echo "$1"; shift; done cat <<USAGE Usage: ${0##*/} [OPTIONS] options: -d | -dir host directory mounted (defaults to current directory) -h | -help help -p | -paraview [vers] include paraview, with version 56 | 510 (default) -u | -upgrade install latest upgrades to the Docker image -x | -xhost use custom X authority and give container host network Launches the OpenFOAM-$ver Docker image. - Requires installation of docker-engine. - Runs a "containerized" bash shell environment where the user can run OpenFOAM and, optionally, ParaView (see below). - The container mounts the user's file system so that case files are stored permanently. The container mounts the current directory by default, but the user can also specify a particular directory using the "-d" option. - Mounting the user's HOME directory is disallowed. - The '-xhost' option is useful when accessing the host via 'ssh -X'. This option should only be used when strictly necessary, as it relies on the option '--net=host' when launching the container in Docker, which will give to the container full access to the Docker host network stack and potentially the host's system services that rely on network communication, making it potentially insecure. ParaView: Graphical applications from the Docker container require installation of the Xquartz X server to display on the host machine. While applications such as Gedit, Emacs and GnuPlot will run effectively using Xquartz, more intensive OpenGL applications, in particular ParaView, can be prohibitively slow. Therefore, the default Docker image does not contain ParaView and users can instead install ParaView directly from the vendor and use the built-in reader module for OpenFOAM: https://www.paraview.org/download However, if the user wishes to include ParaView with the official OpenFOAM reader module in their Docker container, they can do so with the "-p" option. Example: To store data in $HOME/OpenFOAM/$USER-$ver, the user can launch $Script either by: cd $HOME/OpenFOAM/$USER-$ver && $Script or $Script -d $HOME/OpenFOAM/$USER-$ver Further Information: https://openfoam.org/download/$ver-macos Note: The container user name appears as "openfoam" but it is just an alias. USAGE exit 1 } docker_image="openfoam/openfoam$ver-graphical-apps" #docker_image="$HOME/.openfoam.dmg.sparseimage" paraview_vers="" mount_dir=$(pwd) custom_xauth="" docker_options="" while [ "$#" -gt 0 ] do case "$1" in -d | -dir) [ "$#" -ge 2 ] || usage "'$1' option requires an argument" mount_dir=$2 shift 2 ;; -h | -help) usage ;; -p | -paraview) # No version specified { [ "$#" -eq 1 ] || [ "$(echo "$2" | cut -c1)" = "-" ] ; } && \ paraview_vers=510 && \ shift 1 && \ continue # Version specified paraview_vers=$2 case "$paraview_vers" in 56|510) ;; *) usage "'$2' is not a valid ParaView version." \ "Valid versions are 56 | 510." ;; esac shift 2 ;; -u | -upgrade) upgrade=yes shift ;; -x | -xhost) custom_xauth=yes shift ;; *) usage "Invalid option '$1'" ;; esac done [ "$paraview_vers" ] && \ echo "Including ParaView $paraview_vers" && \ docker_image="openfoam/openfoam$ver-paraview$paraview_vers" [ -d "$mount_dir" ] || usage "No directory exists -: $mount_dir" mount_dir=$(cd "$mount_dir" && pwd -P) [ "$mount_dir" = "$(cd "$HOME" && pwd -P)" ] && \ usage "Mount directory cannot be the user's home directory" \ "Make a subdirectory and run from there, e.g." \ " mkdir -p $HOME/OpenFOAM/$(whoami)-$ver" \ " $Script -d $HOME/OpenFOAM/$(whoami)-$ver" if [ -n "$custom_xauth" ] then xauth_path="$mount_dir/.docker.xauth.$$" touch "$xauth_path" # Generate a custom X-authority file that allows any hostname xauth nlist "$DISPLAY" | sed -e 's/^..../ffff/' | \ xauth -f "$xauth_path" nmerge - docker_options="-e XAUTHORITY=$xauth_path -v $xauth_path:$xauth_path --net=host" fi user_id=$(id -u 2> /dev/null) [ -n "$user_id" ] || usage "Cannot determine current user ID" group_id=$(id -g) home_dir='/home/openfoam' echo "Launching $0" echo "User: "$(id -un)" (ID $user_id, group ID $group_id)" ifaces=$(ifconfig | grep ^en | cut -d: -f1) [ "$ifaces" ] || \ usage "Cannot find a network interface for DISPLAY with ifconfig" \ "Please report an issue at http://bugs.openfoam.org" \ " providing the output of the command: ifconfig" for i in $ifaces do ip=$(ifconfig "$i" | grep inet | awk '$1=="inet" {print $2}') [ "$ip" ] && break done [ "$ip" ] || \ usage "Cannot find a network IP for DISPLAY with ifconfig" \ "Please report an issue at https://bugs.openfoam.org" \ " providing the output of the command: ifconfig" xhost + "$ip" [ "$upgrade" ] && docker pull "$docker_image" # shellcheck disable=SC2086 echo "docker_image = $docker_image" docker run -it \ --rm \ -e DISPLAY=$IP:0 \ -u "$user_id":"$group_id" \ -v /tmp/.X11-unix:/tmp/.X11-unix \ -v "$mount_dir":$home_dir \ $docker_options \ "$docker_image" [ -n "$custom_xauth" ] && [ -e "$xauth_path" ] && rm "$xauth_path" |
February 10, 2024, 10:17 |
Rep Power: 6 |
has not someone solved it yet?
February 11, 2024, 20:15 |
Maetee Lor
Rep Power: 2 |
February 11, 2024, 20:29 |
The modify code for openfoam11-macos
Maetee Lor
Rep Power: 2 |
copy the following modified code and save as /usr/local/bin/openfoam11-macos
and run openfoam-macos-file-system create and then you should be able to run openfoam11-macos #!/bin/sh #------------------------------------------------------------------------------ # ========= | # \\ / F ield | OpenFOAM: The Open Source CFD Toolbox # \\ / O peration | # \\ / A nd | Copyright (C) 2017-2023 OpenFOAM Foundation # \\/ M anipulation | #------------------------------------------------------------------------------- # License # This program is free software: you can redistribute it and/or modify it # under the terms of the GNU General Public License as published by # the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # This program is distributed in the hope that it will be useful, but # WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY # or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License # for more details. # # You should have received a copy of the GNU General Public License # along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. # # Script # openfoam11-macos # # Description # Run script for an OpenFOAM 11 Docker image at: # https://hub.docker.com/r/openfoam # #------------------------------------------------------------------------------ Script=${0##*/} ver=11 usage () { exec 1>&2 while [ "$#" -ge 1 ]; do echo "$1"; shift; done cat <<USAGE Usage: ${0##*/} [OPTIONS] options: -d | -dir host directory mounted (defaults to current directory) -h | -help help -p | -paraview [vers] include paraview, with version 56 | 510 (default) -u | -upgrade install latest upgrades to the Docker image -x | -xhost use custom X authority and give container host network Launches the OpenFOAM-$ver Docker image. - Requires installation of docker-engine. - Runs a "containerized" bash shell environment where the user can run OpenFOAM and, optionally, ParaView (see below). - The container mounts the user's file system so that case files are stored permanently. The container mounts the current directory by default, but the user can also specify a particular directory using the "-d" option. - Mounting the user's HOME directory is disallowed. - The '-xhost' option is useful when accessing the host via 'ssh -X'. This option should only be used when strictly necessary, as it relies on the option '--net=host' when launching the container in Docker, which will give to the container full access to the Docker host network stack and potentially the host's system services that rely on network communication, making it potentially insecure. ParaView: Graphical applications from the Docker container require installation of the Xquartz X server to display on the host machine. While applications such as Gedit, Emacs and GnuPlot will run effectively using Xquartz, more intensive OpenGL applications, in particular ParaView, can be prohibitively slow. Therefore, the default Docker image does not contain ParaView and users can instead install ParaView directly from the vendor and use the built-in reader module for OpenFOAM: https://www.paraview.org/download However, if the user wishes to include ParaView with the official OpenFOAM reader module in their Docker container, they can do so with the "-p" option. Example: To store data in $HOME/OpenFOAM/$USER-$ver, the user can launch $Script either by: cd $HOME/OpenFOAM/$USER-$ver && $Script or $Script -d $HOME/OpenFOAM/$USER-$ver Further Information: https://openfoam.org/download/$ver-macos Note: The container user name appears as "openfoam" but it is just an alias. USAGE exit 1 } docker_image="openfoam/openfoam$ver-graphical-apps" #docker_image="$HOME/.openfoam.dmg.sparseimage" paraview_vers="" mount_dir=$(pwd) custom_xauth="" docker_options="" while [ "$#" -gt 0 ] do case "$1" in -d | -dir) [ "$#" -ge 2 ] || usage "'$1' option requires an argument" mount_dir=$2 shift 2 ;; -h | -help) usage ;; -p | -paraview) # No version specified { [ "$#" -eq 1 ] || [ "$(echo "$2" | cut -c1)" = "-" ] ; } && \ paraview_vers=510 && \ shift 1 && \ continue # Version specified paraview_vers=$2 case "$paraview_vers" in 56|510) ;; *) usage "'$2' is not a valid ParaView version." \ "Valid versions are 56 | 510." ;; esac shift 2 ;; -u | -upgrade) upgrade=yes shift ;; -x | -xhost) custom_xauth=yes shift ;; *) usage "Invalid option '$1'" ;; esac done [ "$paraview_vers" ] && \ echo "Including ParaView $paraview_vers" && \ docker_image="openfoam/openfoam$ver-paraview$paraview_vers" [ -d "$mount_dir" ] || usage "No directory exists -: $mount_dir" mount_dir=$(cd "$mount_dir" && pwd -P) [ "$mount_dir" = "$(cd "$HOME" && pwd -P)" ] && \ usage "Mount directory cannot be the user's home directory" \ "Make a subdirectory and run from there, e.g." \ " mkdir -p $HOME/OpenFOAM/$(whoami)-$ver" \ " $Script -d $HOME/OpenFOAM/$(whoami)-$ver" if [ -n "$custom_xauth" ] then xauth_path="$mount_dir/.docker.xauth.$$" touch "$xauth_path" # Generate a custom X-authority file that allows any hostname xauth nlist "$DISPLAY" | sed -e 's/^..../ffff/' | \ xauth -f "$xauth_path" nmerge - docker_options="-e XAUTHORITY=$xauth_path -v $xauth_path:$xauth_path --net=host" fi user_id=$(id -u 2> /dev/null) [ -n "$user_id" ] || usage "Cannot determine current user ID" group_id=$(id -g) home_dir='/home/openfoam' echo "Launching $0" echo "User: "$(id -un)" (ID $user_id, group ID $group_id)" ifaces=$(ifconfig | grep ^en | cut -d: -f1) [ "$ifaces" ] || \ usage "Cannot find a network interface for DISPLAY with ifconfig" \ "Please report an issue at http://bugs.openfoam.org" \ " providing the output of the command: ifconfig" for i in $ifaces do ip=$(ifconfig "$i" | grep inet | awk '$1=="inet" {print $2}') [ "$ip" ] && break done [ "$ip" ] || \ usage "Cannot find a network IP for DISPLAY with ifconfig" \ "Please report an issue at https://bugs.openfoam.org" \ " providing the output of the command: ifconfig" xhost + "$ip" [ "$upgrade" ] && docker pull "$docker_image" # shellcheck disable=SC2086 echo "docker_image = $docker_image" docker run -it \ --rm \ -e DISPLAY=$IP:0 \ -u "$user_id":"$group_id" \ -v /tmp/.X11-unix:/tmp/.X11-unix \ -v "$mount_dir":$home_dir \ $docker_options \ "$docker_image" [ -n "$custom_xauth" ] && [ -e "$xauth_path" ] && rm "$xauth_path" |
February 12, 2024, 13:04 |
#9 | |
Richard Fox
February 13, 2024, 12:19 |
Where and how do I implement this change?
#10 | |
Delight Wellington
February 15, 2024, 04:26 |
#11 |
Mark Olesen
Rep Power: 40 |
Have you tried with the www.openfoam.com versions? There are both x64 and arm64 docker images, or you can compile natively on MacOS too.
https://develop.openfoam.com/Develop...is/precompiled https://develop.openfoam.com/Develop...#darwin-mac-os |
May 14, 2024, 02:21 |
Solved!
#12 |
Sark
I solved this problem and uploaded the script.
https://github.com/skyiwalker/openfo...enfoam11-macos Hope you solve it #!/bin/sh #------------------------------------------------------------------------------ # ========= | # \\ / F ield | OpenFOAM: The Open Source CFD Toolbox # \\ / O peration | # \\ / A nd | Copyright (C) 2017-2023 OpenFOAM Foundation # \\/ M anipulation | #------------------------------------------------------------------------------- # License # This program is free software: you can redistribute it and/or modify it # under the terms of the GNU General Public License as published by # the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # This program is distributed in the hope that it will be useful, but # WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY # or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License # for more details. # # You should have received a copy of the GNU General Public License # along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. # # Script # openfoam11-macos # # Description # Run script for an OpenFOAM 11 Docker image at: # https://hub.docker.com/r/openfoam # #------------------------------------------------------------------------------ Script=${0##*/} ver=11 usage () { exec 1>&2 while [ "$#" -ge 1 ]; do echo "$1"; shift; done cat <<USAGE Usage: ${0##*/} [OPTIONS] options: -d | -dir host directory mounted (defaults to current directory) -h | -help help -p | -paraview [vers] include paraview, with version 56 | 510 (default) -u | -upgrade install latest upgrades to the Docker image -x | -xhost use custom X authority and give container host network Launches the OpenFOAM-$ver Docker image. - Requires installation of docker-engine. - Runs a "containerized" bash shell environment where the user can run OpenFOAM and, optionally, ParaView (see below). - The container mounts the user's file system so that case files are stored permanently. The container mounts the current directory by default, but the user can also specify a particular directory using the "-d" option. - Mounting the user's HOME directory is disallowed. - The '-xhost' option is useful when accessing the host via 'ssh -X'. This option should only be used when strictly necessary, as it relies on the option '--net=host' when launching the container in Docker, which will give to the container full access to the Docker host network stack and potentially the host's system services that rely on network communication, making it potentially insecure. ParaView: Graphical applications from the Docker container require installation of the Xquartz X server to display on the host machine. While applications such as Gedit, Emacs and GnuPlot will run effectively using Xquartz, more intensive OpenGL applications, in particular ParaView, can be prohibitively slow. Therefore, the default Docker image does not contain ParaView and users can instead install ParaView directly from the vendor and use the built-in reader module for OpenFOAM: https://www.paraview.org/download However, if the user wishes to include ParaView with the official OpenFOAM reader module in their Docker container, they can do so with the "-p" option. Example: To store data in $HOME/OpenFOAM/$USER-$ver, the user can launch $Script either by: cd $HOME/OpenFOAM/$USER-$ver && $Script or $Script -d $HOME/OpenFOAM/$USER-$ver Further Information: https://openfoam.org/download/$ver-macos Note: The container user name appears as "openfoam" but it is just an alias. USAGE exit 1 } docker_image="openfoam/openfoam${ver}-graphical-apps" paraview_vers="" mount_dir=$(pwd) custom_xauth="" docker_options="" echo "Script started" # DEBUG while [ "$#" -gt 0 ] do case "$1" in -d | -dir) [ "$#" -ge 2 ] || usage "'$1' option requires an argument" mount_dir=$2 shift 2 ;; -h | -help) usage ;; -p | -paraview) # No version specified { [ "$#" -eq 1 ] || [ "$(echo "$2" | cut -c1)" = "-" ] ; } && \ paraview_vers=510 && \ shift 1 && \ continue # Version specified paraview_vers=$2 case "$paraview_vers" in 56|510) ;; *) usage "'$2' is not a valid ParaView version." \ "Valid versions are 56 | 510." ;; esac shift 2 ;; -u | -upgrade) upgrade=yes shift ;; -x | -xhost) custom_xauth=yes shift ;; *) usage "Invalid option '$1'" ;; esac done # 디렉토리 설정 및 확인 부분 echo "Initial mount_dir: $mount_dir" # DEBUG [ -d "$mount_dir" ] || usage "No directory exists: $mount_dir" mount_dir=$(cd "$mount_dir" && pwd -P) echo "Resolved mount_dir: $mount_dir" # DEBUG [ "$mount_dir" = "$(cd "$HOME" && pwd -P)" ] && \ usage "Mount directory cannot be the user's home directory" \ "Make a subdirectory and run from there, e.g." \ " mkdir -p $HOME/OpenFOAM/$(whoami)-$ver" \ " $Script -d $HOME/OpenFOAM/$(whoami)-$ver" echo "Mount directory is valid" # DEBUG [ "$paraview_vers" ] && \ echo "Including ParaView $paraview_vers" && \ docker_image="openfoam/openfoam$ver-paraview$paraview_vers" [ -d "$mount_dir" ] || usage "No directory exists: $mount_dir" mount_dir=$(cd "$mount_dir" && pwd -P) [ "$mount_dir" = "$(cd "$HOME" && pwd -P)" ] && \ usage "Mount directory cannot be the user's home directory" \ "Make a subdirectory and run from there, e.g." \ " mkdir -p $HOME/OpenFOAM/$(whoami)-$ver" \ " $Script -d $HOME/OpenFOAM/$(whoami)-$ver" if [ -n "$custom_xauth" ] then xauth_path="$mount_dir/.docker.xauth.$$" touch "$xauth_path" echo "Xauth path: $xauth_path" # DEBUG # Generate a custom X-authority file that allows any hostname xauth nlist "$DISPLAY" | sed -e 's/^..../ffff/' | \ xauth -f "$xauth_path" nmerge - docker_options="-e XAUTHORITY=$xauth_path -v $xauth_path:$xauth_path --net=host" fi user_id=$(id -u 2> /dev/null) echo "User ID: $user_id" # DEBUG [ -n "$user_id" ] || usage "Cannot determine current user ID" group_id=$(id -g) echo "Group ID: $group_id" # DEBUG home_dir='/home/openfoam' echo "Launching $0" echo "User: "$(id -un)" (ID $user_id, group ID $group_id)" ifaces=$(ifconfig | grep ^en | cut -d: -f1) echo "Interfaces: $ifaces" # DEBUG [ "$ifaces" ] || \ usage "Cannot find a network interface for DISPLAY with ifconfig" \ "Please report an issue at http://bugs.openfoam.org" \ " providing the output of the command: ifconfig" for i in $ifaces do ip=$(ifconfig "$i" | grep inet | awk '$1=="inet" {print $2}') echo "IP for $i: $ip" # DEBUG [ "$ip" ] && break done [ "$ip" ] || \ usage "Cannot find a network IP for DISPLAY with ifconfig" \ "Please report an issue at https://bugs.openfoam.org" \ " providing the output of the command: ifconfig" xhost + "$ip" [ "$upgrade" ] && docker pull "$docker_image" # DEBUG echo "Docker image: $docker_image" echo "Mount directory: $mount_dir" echo "User ID: $user_id" echo "Group ID: $group_id" echo "Docker options: $docker_options" # shellcheck disable=SC2086 docker run -it \ --rm \ -e DISPLAY=$IP:0 \ -u "$user_id":"$group_id" \ -v /tmp/.X11-unix:/tmp/.X11-unix \ -v "$mount_dir":$home_dir \ $docker_options \ "$docker_image" [ -n "$custom_xauth" ] && [ -e "$xauth_path" ] && rm "$xauth_path" |
installation mac |
Ansys Installation on Docker Container | mohsen.shiea | ANSYS | 11 | March 14, 2024 11:18 |
[OpenFOAM.com] v1606+ Install pb with Docker on OSX El Capitan | BPich | OpenFOAM Installation | 3 | October 10, 2016 18:52 |
[OpenFOAM.com] Docker OpenFOAM install error on Mac OS X | dersh | OpenFOAM Installation | 10 | May 6, 2016 12:49 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
