[OpenFOAM.org] FOAM v-11 Fatal error using blockMesh, Ubuntu 22.04 |
November 7, 2023, 09:09 |
John
Rep Power: 12 |
I'm using a new installation of OpenFOAM (Foundation) version 11 on Ubuntu 22.04: the latest release. Got the following error trying to run blockMesh for a copy of tutorial 2.1: Backwards-Facing Step. john@Caligula:~/OpenFOAM/john-11/run/back_step_tut/pitzDailySteady/system$ blockMesh /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 11 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 11-d5b4d966c3c5 Exec : blockMesh Date : Nov 06 2023 Time : 15:09:09 Host : "Caligula" PID : 75870 I/O : uncollated Case : /home/john/OpenFOAM/john-11/run/back_step_tut/pitzDailySteady/system nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL ERROR: cannot find file "/home/john/OpenFOAM/john-11/run/back_step_tut/pitzDailySteady/system/system/controlDict" From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 539. FOAM exiting As you can see the blockMeshDict file is where it should be with okay permissions. Here is my directory listing and path: ~/OpenFOAM/john-11/run/back_step_tut/pitzDailySteady total 24 drwxr-xr-x 2 john john 4096 Oct 14 18:12 ./ drwxr-xr-x 5 john john 4096 Oct 16 09:11 ../ -rw-r--rw- 1 john john 2642 Oct 14 18:12 blockMeshDict -rw-rw-rw- 1 john john 1353 Oct 14 18:12 controlDict -rw-r--rw- 1 john john 1367 Oct 14 18:12 fvSchemes -rw-r--rw- 1 john john 1563 Oct 14 18:12 fvSolution I should have adequate permissions for executing blockMesh. Is it a compiler error? I did not compile my OF from source but installed a pre-compiled version which seemed to install sucessfully. Any help would be appreciated. Last edited by Gallienus; November 7, 2023 at 09:12. Reason: clarification |
November 7, 2023, 09:13 |
Yann
Rep Power: 27 |
November 7, 2023, 09:24 |
John
Rep Power: 12 |
Wow it worked!
Thanks very much Yann. |
blockmesh, fatal error, tutorial 21, ubuntu |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[OpenFOAM] Take derivative of mean velocity in paraFoam | hiuluom | ParaView | 13 | April 26, 2016 06:44 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 04:14 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
