[foam-extend.org] simpleFoam examples crush in foam-extend-5.0 |
February 21, 2023, 14:07 |
Rep Power: 12 |
Hi all,
I have installed foam-extend-5.0 on ubuntu 22.04 either with the .deb file, or compiled from sources (git branch 73c2a3d539c20e6b97cd625d5d79fb7f78149f5b) The simpleFoam tutorials crush - I have tested motorbike, and pitzDaily. The simpleFoam of the pimpleDynMFoam in the wingMotion tutorial also crushes. I have attached below the output of the pitzDaily. To run it: >> blockMesh >> simpleFoam It crushes very fast. Any ideas? /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 5.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 5.0-73c2a3d539c2 Exec : simpleFoam Date : Feb 21 2023 Time : 19:58:56 Host : "lt-yehudaa" PID : 658991 CtrlDict : "/home/yehudaa/Projects/2023/foamExtendTutorials/simpleFoam/pitzDaily/system/controlDict" Case : /home/yehudaa/Projects/2023/foamExtendTutorials/simpleFoam/pitzDaily nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.0001 field U tolerance 0.0001 field "(k|epsilon)" tolerance 0.0001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; alphaEps 0.76923; sigmaEps 1.3; } Starting time loop Time = 1 BiCGStab: Solving for Ux, Initial residual = 1, Final residual = 0.00464911, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00960309, No Iterations 163 time step continuity errors : sum local = 0.475961, global = -0.00434833, cumulative = -0.00434833 BiCGStab: Solving for epsilon, Initial residual = 0.594985, Final residual = 0.00495, No Iterations 1 BiCGStab: Solving for k, Initial residual = 1, Final residual = 0.0031536, No Iterations 1 ExecutionTime = 0.07 s ClockTime = 0 s Time = 2 BiCGStab: Solving for Ux, Initial residual = 0.561136, Final residual = 0.00840767, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 0.980401, Final residual = 0.0158018, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.905008, Final residual = 0.00863013, No Iterations 57 time step continuity errors : sum local = 27.5255, global = 2.94505, cumulative = 2.9407 BiCGStab: Solving for epsilon, Initial residual = 0.999276, Final residual = 0.00800445, No Iterations 1 BiCGStab: Solving for k, Initial residual = 0.996406, Final residual = 0.000380816, No Iterations 1 ExecutionTime = 0.09 s ClockTime = 0 s Time = 3 BiCGStab: Solving for Ux, Initial residual = 0.516662, Final residual = 0.00621829, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 0.998397, Final residual = 0.0176732, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.999941, Final residual = 0.0089741, No Iterations 19 time step continuity errors : sum local = 53029.6, global = -41.905, cumulative = -38.9643 BiCGStab: Solving for epsilon, Initial residual = 1, Final residual = 0.00122703, No Iterations 1 BiCGStab: Solving for k, Initial residual = 0.999998, Final residual = 0.00573344, No Iterations 1 ExecutionTime = 0.09 s ClockTime = 0 s Time = 4 BiCGStab: Solving for Ux, Initial residual = 0.550045, Final residual = 0.0056509, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 0.999997, Final residual = 0.0160376, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00862799, No Iterations 58 time step continuity errors : sum local = 5.33155e+10, global = -1.23755e+08, cumulative = -1.23755e+08 BiCGStab: Solving for epsilon, Initial residual = 0.999972, Final residual = 0.00643736, No Iterations 1 BiCGStab: Solving for k, Initial residual = 0.999955, Final residual = 0.002415, No Iterations 1 ExecutionTime = 0.11 s ClockTime = 0 s Time = 5 BiCGStab: Solving for Ux, Initial residual = 0.421288, Final residual = 0.00214245, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 1, Final residual = 0.00222639, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00733539, No Iterations 133 time step continuity errors : sum local = 1.12466e+19, global = 1.96772e+15, cumulative = 1.96772e+15 BiCGStab: Solving for epsilon, Initial residual = 0.999994, Final residual = 0.000797934, No Iterations 1 BiCGStab: Solving for k, Initial residual = 0.999988, Final residual = 0.0591909, No Iterations 1 ExecutionTime = 0.13 s ClockTime = 0 s Time = 6 BiCGStab: Solving for Ux, Initial residual = 0.525405, Final residual = 0.00822925, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 1, Final residual = 0.059309, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00503789, No Iterations 5 time step continuity errors : sum local = 3.055e+39, global = 3.65535e+27, cumulative = 3.65535e+27 BiCGStab: Solving for epsilon, Initial residual = 1, Final residual = 0.000516864, No Iterations 1 BiCGStab: Solving for k, Initial residual = 1, Final residual = 2.5594e-09, No Iterations 1 ExecutionTime = 0.14 s ClockTime = 0 s Time = 7 BiCGStab: Solving for Ux, Initial residual = 0.699943, Final residual = 4.29177e-11, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 1, Final residual = 0.0335931, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 2.86737e-09, No Iterations 2 time step continuity errors : sum local = 1.02702e+68, global = -2.47902e+51, cumulative = -2.47902e+51 Floating point exception (core dumped) |
June 5, 2023, 06:33 |
Rep Power: 3 |
I also am experiencing this. Were you able to solve it?
August 17, 2023, 18:55 |
Amirhossein Taran
Rep Power: 10 |
Did you follow the instructions in Allrun file ? especially for motorbike case, you need to use snappyHexMesh in order to create your geometry. Make sure to execute Allrun file by ./Allrun Bests, Amirhossein. |
August 28, 2023, 17:57 |
Petar T
I experience same problem, the pitzDaily crashes at 7th iteration, other solvers also fave similar problems. I noticed that all solvers have poor convergence it may be that there is a problem with numerical schemes. Does anyone has answer to this?
Update: running with openfoam2306 it converges successfully. It seems that the solver itself is broken. |
October 30, 2023, 12:46 |
José Ángel
Rep Power: 10 |
I have found out the same issue with all turbulence tutorials. Only the tutorials with laminar flow work correctly. Any help would be appreciated. |
June 5, 2024, 21:44 |
#6 | ||
Rep Power: 2 |
June 17, 2024, 01:51 |
Any updates?
Daniel
Rep Power: 16 |
Has anyone been able to find a solution to these crashes, or to identify if the errors were produced by the solver or by something going wrong at compilation? Thank you ******* Full edit here ******* I gave some time to investigate and it seems the release 5.0 (main branch) is incompatible with GCC 13, the one that comes with Ubuntu 24.04. To solve, use instead the nextRelease branch. The solvers were updated and should work normally without any different configuration. To do that, use this on your "foam" folder: Code:
git clone --branch nextRelease https://git.code.sf.net/p/foam-extend/foam-extend-5.0 foam-extend-5.1 Code:
# foam-extend 5.1 alias fe51='source $HOME/foam/foam-extend-5.1/etc/bashrc' Proceed normally with compilation and test your tutorials. They should work normally. Last edited by DVSoares; June 17, 2024 at 16:24. |
[blockMesh] mergePatchPairs problem when using two master and slave combination | Ali_Sh | OpenFOAM Meshing & Mesh Conversion | 0 | September 22, 2021 10:35 |
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? | Sorabh | OpenFOAM Meshing & Mesh Conversion | 1 | August 3, 2021 07:35 |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 12:59 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
