[OpenFOAM.org] Could not load paraFoam in docker
Like Tree1Likes
  • 1 Post By zx108s221
Old   November 9, 2022, 22:43
Default Could not load paraFoam in docker
Shaun
zx108s221 is on a distinguished road
When I tried to use paraFoam in docker, here is the output
e6e71bcce128: cavity>> paraFoam
Created temporary 'cavity.OpenFOAM'
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
Aborted (core dumped)
How should I fix it? It seems the problem comes with qt. But after I reinstall qt, it still happens.
Thanks in advance.
BTW, I am using Manjaro 5.15.60 with openFoam v10 docker.
zx108s221 is offline   Reply With Quote
Old   November 10, 2022, 22:29
Shaun
I guess using the native paraview is the only and better option here.
olesen likes this.
docker, parafoam
Ansys Installation on Docker Container mohsen.shiea ANSYS 11 March 14, 2024 12:18
[OpenFOAM] ParaFOAM for multiregion case only load one region? fxzf ParaView 1 October 22, 2018 07:50
[OpenFOAM] paraFoam: how to load a specific range of solution ? anon_q ParaView 1 August 8, 2018 11:15
[OpenFOAM.com] Docker vs Not Docker v2 AND installing editors into Docker u2berggeist OpenFOAM Installation 1 July 10, 2018 03:58
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
