[OpenFOAM.org] OpenFOAM v9 Installation problem - gedit ~/.bashrc |
November 3, 2021, 08:10 |
Mary
Rep Power: 5 |
I have tried to install OpenFOAM v9 in Ubuntu 20.04 LTS under WSL (windows 11). I have followed the process: https://openfoam.org/download/9-ubuntu/ Everything went ok. However, when I typed: Code:
gedit ~/.bashrc Code:
Unable to init server: Could not connect: Connection refused (gedit:22): Gtk-WARNING **: 12:09:05.965: cannot open display: Please help. |
November 4, 2021, 12:28 |
Yann
Rep Power: 29 |
Hi Mary,
Your installation is complete. This last step is just meant to load the OpenFOAM environment each time you start a new session, so you don't have to do it manually. Now if your just type the command below in your terminal, it should load the OpenFOAM environment and you will be good to go: Code:
source /opt/openfoam9/etc/bashrc You get an error because gedit is a text editor with a GUI and you don't have a graphical environment in WSL. There are 2 solutions: doing this last step without opening an editor needing a graphical environment or enabling graphical applications in WSL. This link explains how to do both: https://openfoam.org/download/windows/ Cheers, Yann |
November 6, 2021, 11:42 |
Mary
Rep Power: 5 |
Thanks a lot, Yann! I will try it!!!
[OpenFOAM.com] OpenFoam Installation v1806 on W7, 64bit Problem | Joerg2007 | OpenFOAM Installation | 6 | November 6, 2018 20:09 |
compiler problem with OpenFOAM installation | belkadi | OpenFOAM Installation | 4 | May 22, 2013 11:26 |
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox | Stubby | OpenFOAM Installation | 8 | March 5, 2012 16:12 |
Problem: Openfoam 2.1 installation from git repo | fertinaz | OpenFOAM Installation | 10 | March 2, 2012 12:26 |
OpenFOAM 1.7.0 installation problem | stevek | OpenFOAM | 14 | December 1, 2010 16:30 |
