March 24, 2021, 13:25 |
Installation Problems
Juan
Rep Power: 5 |
Hi everyone,
I'm trying to learn OpenFoam and i'm having some troubles trying to install the software. Here is what the terminal is giving me back after i run the command "sudo apt-get install openfoam7" Here is the message: "Err:1 https://jztkft.dl.sourceforge.net/pr...am/foam/ubuntu focal/main amd64 openfoam7 amd64 20200508 Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 45.67.159.245 443] Err:2 https://altushost-swe.dl.sourceforge...am/foam/ubuntu focal/main amd64 paraviewopenfoam56 amd64 0-20200505 Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 79.142.76.130 443] W: https://jztkft.dl.sourceforge.net/pr...508_amd64.deb: No system certificates available. Try installing ca-certificates. W: https://altushost-swe.dl.sourceforge...505_amd64.deb: No system certificates available. Try installing ca-certificates. E: Failed to fetch https://jztkft.dl.sourceforge.net/pr...0508_amd64.deb Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 45.67.159.245 443] E: Failed to fetch https://altushost-swe.dl.sourceforge...0505_amd64.deb Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 79.142.76.130 443] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?" I'm really interested in learning the software so I really appreciate if anyone could help me around this problem. |
March 27, 2021, 11:53 |
Mark Olesen
Rep Power: 40 |
Could try following these instructions and see if you have better luck
https://develop.openfoam.com/Develop...ompiled/debian |
March 27, 2021, 12:35 |
Not much luck
Juan
Rep Power: 5 |
Thanks for the reply!
Unfortunately, I've been trying with that and many other basic and simple installation guides but nothing seem to be working, this is the last mistake i got when i try to run the "add-debian-repo.sh" script. "(base) juan@juan-Satellite-P55-A:~/Downloads$ bash add-debian-repo.sh Detected distribution code-name: focal add-debian-repo.sh: line 115: /etc/apt/sources.list.d/openfoam.list: Permission denied Overwrote /etc/apt/sources.list.d/openfoam.list Importing openfoam gpg key... add-debian-repo.sh: line 131: /etc/apt/trusted.gpg.d/openfoam.gpg: Permission denied Error" |
March 28, 2021, 05:21 |
#4 | |
Mark Olesen
Rep Power: 40 |
March 28, 2021, 05:40 |
Juan
Rep Power: 5 |
Not quite, that was the latest error that i got after applying all the other commands, if i follow the normal installation procedure this is what i get.
(base) juan@juan-Satellite-P55-A:~$ wget -q -O - https://dl.openfoam.com/add-debian-repo.sh | sudo bash (base) juan@juan-Satellite-P55-A:~$ sudo apt-get install openfoam2012-default Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package openfoam2012-default (base) juan@juan-Satellite-P55-A:~$ sudo apt-get update Hit:1 http://fr.archive.ubuntu.com/ubuntu focal InRelease Hit:2 http://fr.archive.ubuntu.com/ubuntu focal-updates InRelease Hit:3 http://fr.archive.ubuntu.com/ubuntu focal-backports InRelease Hit:4 http://dl.openfoam.org/ubuntu focal InRelease Hit:5 http://dl.google.com/linux/chrome/deb stable InRelease Ign:6 https://dl.openfoam.com/repos/deb focal InRelease Err:7 https://dl.openfoam.com/repos/deb focal Release Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 82.71.205.33 443] Get:8 http://security.ubuntu.com/ubuntu focal-security InRelease [109 kB] Reading package lists... Done W: https://dl.openfoam.com/repos/deb/di...cal/InRelease: No system certificates available. Try installing ca-certificates. W: https://dl.openfoam.com/repos/deb/dists/focal/Release: No system certificates available. Try installing ca-certificates. E: The repository 'https://dl.openfoam.com/repos/deb focal Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. (base) juan@juan-Satellite-P55-A:~$ |
March 30, 2021, 06:23 |
Mark Olesen
Rep Power: 40 |
I've tagged one of our guys, not sure if it is http vs https issue or what.
October 16, 2021, 15:31 |
GS
Rep Power: 8 |
October 24, 2021, 23:37 |
Somehow similar problems with certificates and installation of OpenFOAM
Jesus
I typed following command at terminal prompt
(my installation is for Ubuntu 20 on Windows 10 subsytem for Linux sudo apt install ca-certificates my problem was with supposedly expired certificates of sourceforge.net so I was not able to create repository so system could not be installed Hope it helps |
January 29, 2022, 19:03 |
#9 | |
MI
Rep Power: 8 |
openfoam |
[OpenFOAM.com] v1606+ Problems of installation on iMac | Intercooled | OpenFOAM Installation | 4 | November 15, 2016 21:22 |
[Other] Installation problems with OpenFOAM 2.3.x for Windows from cfdsupport.com | Nkl | OpenFOAM Installation | 7 | March 31, 2015 11:59 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 08:18 |
Problems with installation | batta31 | OpenFOAM Installation | 2 | September 4, 2012 08:01 |
installation problems on upgrade from win 3.26 to | mic | Siemens | 5 | June 20, 2007 10:40 |
