[foam-extend.org] FE-4.0 and FE-4.1 : missing libmpi.so.40
Like Tree1Likes
  • 1 Post By lcliu
Old   November 25, 2020, 05:05
Default FE-4.0 and FE-4.1 : missing libmpi.so.40
LC Liu
lcliu is on a distinguished road
I am installing FE-4.0 and 4.1 on my CENTOS 7.5, the process looks ok but it shows “error while loading shared libraries: libmpi.so.40: cannot open shared object files: No such file or directory” when I try to run tutorial case (for blockMesh and steadyCompressibleFoam).
I have openFoam v.2006 successfully installed on the same machine with openmpi 4.0.3, could any one share some experience upon this? Thanks in advance.
lcliu is offline   Reply With Quote
Old   November 26, 2020, 04:51
Antimony is on a distinguished road
What is the variable $WM_MPLIB set to? Is it the same for both the FE and OF-v2006?
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   November 26, 2020, 05:54
LC Liu
Thank you for the reply, the issue was resolved by adding the following line into my .bashrc:
export LD_LIBRARY_PATH=/PATH_TO_openmpi-version/lib:$LD_LIBRARY_PATH
Antimony likes this.
Old   February 15, 2024, 12:51
Vahid
vahidrabbani is on a distinguished road
where did you add the line please I have the same problem.
vahidrabbani is offline   Reply With Quote
