[OpenFOAM.com] OF1806+ compiles, but fails in parallel with INTEL MPI
Like Tree1Likes
  • 1 Post By bestucan
Old   June 17, 2020, 18:51
Default OF1806+ compiles, but fails in parallel with INTEL MPI
Lisandro Maders
Lisandro Maders is on a distinguished road
I am trying to compile OpenFOAM 1806+ with the following setup:
  • INTEL MPI - Intel(R) MPI Library for Linux* OS, Version 2019 Update 7 Build 20200312 (id: 5dc2dd3e9)
  • Gcc 8.4
  • scotch 6.0.3
  • Linux distro - Ubuntu 18.04 LTS
I will attach the output log from Allwmake - a few Paraview libraries didn't compile but I am fine with that.
After compilation apparently successfull, I try to run any tutorial in parallel and it fails. I attached a failed snappyHexMesh.log as example as well.
The step-by-step I have done to compile INTEL MPI was:
  1. Download INTEL MPI libraries and install it
  2. change WM_MPLIB=INTELMPI at .../OpenFOAM-v1806/etc/bashrc
  3. checked if the following paths were correct in etc/config.sh/mpi (they are):
    _foamAddPath $MPI_ARCH_PATH/intel64/bin
    _foamAddLib $MPI_ARCH_PATH/intel64/lib
  4. checked the files at wmake/rules/*/mplibINTELMPI to see if they were pointing to the correct paths (they are)
  5. source ~/intel/impi/2019.7.217/intel64/bin/mpivars.sh
  6. source .../OpenFOAM-v1806/etc/bashrc
After sourcing it, I checked the output of which mpirun --version, and it was pointing to the INTEL MPI (good).
I checked the output of which mpicc --version, and it was pointing to gcc-8.4.0 (good).
I run some tutorials in parallel - all of them crashed.
Some important info: the output of ldd $(which snappyHexMesh) shows to me that there are 2 mpi libraries set:
libmpi.so.20 => /usr/lib/x86_64-linux-gnu/libmpi.so.20 (0x00007f2ef5dfc000)
libmpi.so.12 => /home/lmaders/intel/compilers_and_libraries_2020.1.217/linux/mpi/intel64/lib/release/libmpi.so.12 (0x00007f2ef4c79000)
I think it should be only setting the intel one here. If this is probably the issue, how can I ensure the OF solvers are sourcing/setting only the INTEL MPI?
Hopefully I have been clear enough. Thanks in advance
Lisandro
Lisandro Maders is offline   Reply With Quote
Old   June 18, 2020, 18:43
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
- I would either go for an older IntelMPI version down to OF1806, or a newer OpenFOAM version up to IMPI-2019. Is there any chance for that?
HPE is offline   Reply With Quote
Old   June 19, 2020, 02:34
bestucan's Avatar
Tu Can
bestucan is on a distinguished road
compare with
Just a guess. Is _foamAddPath add path recursively?
the libmpi.so.12 is under "lib/release" and you add "lib". Seems likes OpenFOAM missing some .so.
Lisandro Maders likes this.
bestucan is offline   Reply With Quote
Old   June 19, 2020, 17:59
Lisandro Maders
That was it! I thought it would look for it recursivelly inside "lib" (shouldn't it be recursive?)
I explicitly set the release path and worked..
Thanks!
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
MPI parallel meet problems jiaojiao OpenFOAM 1 May 10, 2016 03:30
Parallel Problem of CFX 14.5.7 on a Intel Xeon 2690V2 computer with Win7 x64 OS BruceWen Hardware 0 April 30, 2014 00:48
PROBLEM IN PARALLEL PROGRAMMING WITH MPI Niavarani Main CFD Forum 1 April 20, 2004 07:51
MPI and parallel computation Wang Main CFD Forum 7 April 15, 2004 12:25
