[OpenFOAM.org] OpenFOAM 5 installation on Ubuntu 20.04
Like Tree2Likes
  • 1 Post By vitor.geraldes@ist.utl.pt
  • 1 Post By olesen
Old   May 15, 2020, 07:22
Default OpenFOAM 5 installation on Ubuntu 20.04
Azamat Salamat
azamat is on a distinguished road
Hello!
I am trying to install OpenFOAM 5 to use it with CFDEM-coupling on my laptop that is running Ubuntu 20.04.
I have copied the github repo, added the following line to the .bashrc:
source $HOME/OpenFOAM/OpenFOAM-5.x/etc/bashrc
Followed the instructions from https://www.cfdem.com/media/CFDEM/do...ng_Manual.html. Compiled using Allwmake and then I am receiving the error in the attached file. (I believe this is an error, as I am not able to run the tutorial cases in OpenFOAM folder)
I am wondering is it even possible to install OpenFOAM 5 on latest Ubuntu since it is not available as apt package anymore.
Thank you,
Azamat
azamat is offline   Reply With Quote
Old   July 23, 2020, 00:50
Default I have the same problem...
Vitor Geraldes
vitor.geraldes@ist.utl.pt is on a distinguished road
I had the same problem. I solved it by installing OpenFOAM5.x instead of the version 5.0. Then in the thirdParty-5.x folder I replaced scotch_6.0.3 by the newer version scotch_6.0.9 (it is available on the more recent versions of OF). On the file scotch in the directory OpenFOAM-5.x/etc/config.sh/, the new version of scotch must be added (export SCOTCH_VERSION=scotch_6.0.9). Now both the thirdParty-5.x and the openFoam5.x compile well.
Biku likes this.
vitor.geraldes@ist.utl.pt is offline   Reply With Quote
Old   September 24, 2020, 02:52
Ashutosh
as13031996@ is on a distinguished road
Hello friend
I also installed 3 party of 6 on Ubuntu 20 allbthings run well but it's not running parallel and showing environment variable key_buffer_size please help
as13031996@ is offline   Reply With Quote
Old   October 29, 2020, 16:08
Benico
benico is on a distinguished road
I want Helyx and Sim-Flow working on Xubuntu 20.04. This means that OF 4.1 has to be installed (which are not in the bionic or the focal repositories)
so although my distro is "focal" I enabled the following repositories - and I got OF 4.1 working.
Using synaptic I added:
deb http://dl.openfoam.org/ubuntu xenial main
(in order to install OF4.1) as well as
deb http://archive.ubuntu.com/ubuntu xenial main
(in order to satisfy the dependencies)
After installing OF4.1 I disabled the xenial repositories again.
Paraview did not work due to a 2011 intel integrated GPU on a hp 8440 laptop.
I enabled the oibaf repositories and got Paraview 5.4.1 going with :
/opt/ParaView-541/bin/paraview --mesa-llvm
hths
benico is offline   Reply With Quote
Old   October 31, 2020, 04:02
Post
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
You will need to read the error messages quite exactly. Some of the errors are indeed code errors in OpenFOAM (eg returning a value from a void method).
They didn't get noticed originally, but the newer compilers (like you have on ubuntu 20.04) do find them and flag them as an error.
So you will need to fix these manually.
Another possibility is to get the software working with a newer version of OpenFOAM. If you use the openfoam.com version, it always provides a version macro that you can use while updating your code. For example,
#if OPENFOAM > 1906
...updated code
#else
... old code
#endif
Can than create an upstream merge request with your changes.
If you want to try OpenFOAM-v1912 or v2006 on Ubuntu 20.04 see these instructions :
https://develop.openfoam.com/Develop...ompiled/debian
benico likes this.
olesen is offline   Reply With Quote
Old   November 24, 2021, 06:33
Biku
Biku is on a distinguished road
Thank you this worked!
Biku is offline   Reply With Quote
Old   November 28, 2022, 08:04
Altaf lone
altaf is on a distinguished road
Dear Tobias Holzmann,
Will this work as a rule of thumb for any other lower versions like v4. kindly suggest how to make lower versions like v4 work on ubuntu 22.04 or so
altaf is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
[OpenFOAM.org] OpenFOAM 3.0.1 installation on Ubuntu 14.04 Hrushi OpenFOAM Installation 6 July 8, 2017 19:47
[OpenFOAM.org] OpenFoam 3.0 installation on Ubuntu 14.04.3 tab2001ng OpenFOAM Installation 3 March 8, 2016 02:38
[OpenFOAM.org] installation of openfoam version of 2.3.0 and 2.0.0 together in ubuntu 14.0.4 Hamzeh_Mirab OpenFOAM Installation 1 November 21, 2014 06:16
openFOAM installation in ubuntu 11.10 kirubhakaran OpenFOAM Installation 5 February 17, 2012 03:16
