[OpenFOAM.com] Error installing with Docker on Linux
Like Tree1Likes
  • 1 Post By rmc
Old   May 6, 2020, 13:22
Default Error installing with Docker on Linux
rmc
rmc is on a distinguished road
I'm trying to install OpenFOAM on my Raspberry Pi 4 (yes I know...) and I've gone for the Docker method for Linux, here: https://www.openfoam.com/download/in...nary-linux.php
the Docker image downloads fine and running ./installOpenFOAM for the first time downloads everything correct. When I run it again, it creates the container wihtout error.
However, when I run ./startOpenFOAM, I get the following error:
Error response from daemon: Container <long_container_id> is not running
This happens both when I'm ssh'd into my Pi, and when I'm directly on the Pi.
I understand a Pi isn't the best for CFD but as it runs Linux, I don't see why it wouldn't work?
Thanks for the help.
rmc is offline   Reply With Quote
Old   May 6, 2020, 17:33
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
which OS does it use? rasperry pi isn't just the hardware name (sorry for my ignorance)?
HPE is offline   Reply With Quote
Old   May 6, 2020, 17:43
rmc
It's using Raspian which is an OS based on Debian.
Old   May 6, 2020, 17:52
HPE
HPE's Avatar
I have never used Docker, so be cautious please.
I found this: "When the application terminates, so does the container."
"By default, docker container will exit immediately if you do not have any task running on the container."
Do you know what `./startOpenFOAM` script actually does? Does it open something specific, or perform some tutorial?
EDIT: Isn't it possible to compile OpenFOAM directly in Debian instead of using Docker which is only for Windows I suppose?
Old   May 6, 2020, 19:16
rmc
Docker is hugely popular on both Linux and Mac OS, not just Windows.
The official OpenFOAM website even suggests it be installed this way on a Linux OS:
I suspect my issue is to do with X11 or some sort of display issue and how it works with Docker but I'm out my depth.
HPE likes this.
docker, error, install, linux, raspberry
OpenFoam in docker (gcc 6) vs. OpenFoam natively compiled (gcc 8.1.1) Anouk OpenFOAM Running, Solving & CFD 0 September 17, 2018 09:02
[OpenFOAM.com] Docker vs Not Docker v2 AND installing editors into Docker u2berggeist OpenFOAM Installation 1 July 10, 2018 03:58
[OpenFOAM.com] v1606+ Install pb with Docker on OSX El Capitan BPich OpenFOAM Installation 3 October 10, 2016 19:52
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
