[foam-extend.org] OpenFOAM-extend 4.1 installation
Like Tree13Likes
  • 5 Post By JETZ
  • 1 Post By sadsid
  • 1 Post By JETZ
  • 1 Post By sadsid
  • 1 Post By JETZ
  • 1 Post By sadsid
  • 1 Post By sadsid
  • 2 Post By sadsid
Old   April 11, 2020, 09:39
Default OpenFOAM-extend 4.1 installation
Jitish
JETZ is on a distinguished road
Hi everyone
I have followed the instrucations on this page https://openfoamwiki.net/index.php/I...oam-extend-4.1 for the installation , but whenever I get to the source etc/bashrc line the terminal throws the errors listed below
bash: /opt/foam-extend-4.1/bin/foamGetSystemInfo: No such file or directory
bash: /opt/foam-extend-4.1/bin/foamCleanPath: No such file or directory
bash: /opt/foam-extend-4.1/etc/settings.sh: No such file or directory
bash: /opt/foam-extend-4.1/etc/aliases.sh: No such file or directory
I have even tried looking on this forum How to install foam-extend 4.0 in UBUNTU 18.04, but still have no luck.
I then found this page https://pingpong.chalmers.se/public/...ml?language=en
followed those instrucations and I still get the same errors.
Can anyone please help me, and any other individual who is struggling with this. If it makes a difference I already have openFOAM v7 installed. I am fairly new to ubuntu and openfoam, so maybe I am misunderstanding something.
Thanks in advance
JETZ is offline   Reply With Quote
Old   April 13, 2020, 16:27
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Depends on what you want. foam-extend and OpenFOAM-Foundation are not the same.
Might look at the links below for the foam-extend issue link, may be asking the installation question there might help?
HPE is offline   Reply With Quote
Old   April 13, 2020, 17:16
Jitish
Thanks, tried looking around at the forums you recommended. I've had no luck so far.
The thing is I can even install Foam-extend 4.0 but even that was giving me the same error.
I am busy doing a Udemy course and its focussed on materials as well as structure https://www.udemy.com/course/the-com...chanics/learn/
The instructor here uses Foam-extend 4.0, and I have even tried using his installation process(same as instructed on the site) but still got those errors.
I will try installing 4.0 via the .deb package and see if anything differs.
Thanks for the help.
Old   April 18, 2020, 18:02
Jitish
The solution was to basically move my foam-extend folder from ~\foam\foam-extend-4.1 to opt\foam-extend-4.1.
Basically use sudo mkdir foam-extend-4.1 in the opt folder,
Then sudo chown (username)/opt/foam-extend-4.1
followed by mv ~/foam/foam-extend-4.1/* /opt/foam-extend-4.1/
This was suggested to me by someone on the openfoam discord server, it worked first time. Pity the installation instructions on the foam-extend page lead to something incorrect.
cryabroad, lpz456, IFX21 and 2 others like this.
Old   June 15, 2020, 18:38
sadsid is on a distinguished road
So you have two folders for extend 4.1? One in opt\ and one in ~/foam/foam-extend-4.1/ ?
lpz456 likes this.
sadsid is offline   Reply With Quote
Old   June 15, 2020, 18:46
Jitish
Hi no it's only the one folder in the opt\ directory. From then on you can basically use the alias "fe41" to access the foam-extend environment through the terminal.
lpz456 likes this.
Old   June 15, 2020, 18:58
If I keep folder in opt and delete the other folder then still I get some error. Once I keep both then I do not see any error. It is a little confusing. Can you post all the steps that you followed?
lpz456 likes this.
Old   June 15, 2020, 19:06
Jitish
What does the error say?
I will get back to you with the steps, it'd quite late where I am and don't have my PC on me. But I'll respond once I wake in the morning with regards to the steps. For the most part though I executed the EXACT steps I typed above.
The other thing you could do is access your bashrc file in your home directory and using a text editor of your choice create the bash alias in that file. Note this is a hidden text file so select the option to see hidden files and folders and look for the bashrc file. Then create the alias there.
Else I will reply in about 12-14 hours with guided steps.
lpz456 likes this.
Old   June 15, 2020, 19:17
Thank you for your concern. I am trying again and will post the error if encounter in this attempt.
lpz456 likes this.
Old   June 15, 2020, 19:37
If I copy only in opt folder then I get the following error:
bash: /home/sad/foam/foam-extend-4.0/bin/foamGetSystemInfo: No such file or directory
bash: /home/sad/foam/foam-extend-4.0/bin/foamCleanPath: No such file or directory
bash: /home/sad/foam/foam-extend-4.0/etc/settings.sh: No such file or directory
bash: /home/sad/foam/foam-extend-4.0/etc/aliases.sh: No such file or directory
And if I save the folder in /home/sad then I get the following:
bash: /opt/foam-extend-4.0/bin/foamGetSystemInfo: No such file or directory
bash: /opt/foam-extend-4.0/bin/foamCleanPath: No such file or directory
bash: /opt/foam-extend-4.0/etc/settings.sh: No such file or directory
bash: /opt/foam-extend-4.0/etc/aliases.sh: No such file or directory
If I save copy in each folder and try to compile then my compilation works. I already added alias fe40='source /opt/foam-extend-4.0/etc/bashrc ' in my bashrc file.
IFX21 likes this.
Old   June 15, 2020, 22:49
HI, I resolved the issue. I deleted both copies, restarted my system and downloaded the fresh copy in /opt folder. Now compilation is completed and alias--->fe40 is working perfectly.
I will now test some tutorials..
Thank you!!!
JETZ and IFX21 like this.
Old   April 19, 2024, 14:07
Milad Bagheri
MiladBagheri is on a distinguished road
If you're still experiencing this issue with foam-extend-4.0 or foam-extend-5.0, it may be because the default installation directory is "~". Traditionally, students would compile in their home directory and run simulations on their desktop. 😄
For instance, the default installation directory for ESI is now in the /lib/ directory, while for Foundation, it's in /opt/. Apparently, they can't even agree on directories! 😄
Regarding the solution, if you install it in your home directory, there should be no issues. Otherwise, open the file foam-extend-5.0/etc/bashrc and either comment out or replace the line WM_PROJECT_DIR=$WM_PROJECT_INST_DIR/$WM_PROJECT-$WM_FORK-$WM_PROJECT_VERSION with WM_PROJECT_DIR=/opt/foam-extend-5.0 if you're installing it in /opt/. If it's another directory, just replace it with your chosen directory where you cloned it.
MiladBagheri is offline   Reply With Quote
Old   April 29, 2024, 18:51
esma is on a distinguished road
I'm having difficulties to install Foam-Extend (any version) no matter what. I have tried the home directory as well as /opt/ as recommended above and keep receiving the same error message as highlighted below. by home directory, I mean (cd ~) This is very strange. I'm following step-by-step from installation page
please note I have OF2206 & OF9 on my machine too and incorporated alias in ~/.bashrc to switch between them. Wondering if there is anything to do with that? i.e. having other versions of OF creates the problem?
Also, I need the extend version to be able to use its FSI features. Wondering if there is any other OF package that handles that?
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are not consistent with the installation.
Please source configuration files.
Examples:
bash: . etc/bashrc
tcsh: source etc/cshrc
If you sourced the configuration files, please check the 'foamInstall' entry.
esma is offline   Reply With Quote
openfoam installation, openfoam-extend-4.0
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 ad2eb OpenFOAM Installation 12 May 28, 2017 15:30
[Other] Installation of OpenFOAM: Docker or not Docker? zt49 OpenFOAM Installation 2 December 22, 2016 11:38
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFoam 2.0.0 installation Jan_Peters OpenFOAM Installation 86 April 27, 2012 06:32
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
