[foam-extend.org] Docker Container for Foam Extend 4.1
Like Tree2Likes
  • 1 Post By illuminati5288
  • 1 Post By gschaider
Old   January 26, 2020, 13:35
Default Docker Container for Foam Extend 4.1
Vignesh Suresh
illuminati5288 is on a distinguished road
I recently got interested in OpenFOAM after using starccm+ for a while. I was able to install OpenFOAM using the docker container on my Mac OS using this link. https://openfoam.com/download/install-binary-mac.php
It works very well. However I came across some tutorials that required FOAM-EXTEND. I tried creating an ubuntu container and copied over the deb file. However it fails while trying to install in the docker container.
Does anyone know how to create a container or a similar installation like the open foam.com website for Mac OS?
Thanks
sourav90 likes this.
illuminati5288 is offline   Reply With Quote
Old   May 30, 2020, 10:18
Assistant Moderator
Bernhard Gschaider
Originally Posted by illuminati5288 View Post
Thanks
I recently created a Docker container with foam-extend 4.1 (compiled from the git) https://hub.docker.com/r/bgschaid/openfoam_by_ansible
Haven't tested it thoroughly and the container is without ParaView. Also: only tested it on a Linux-host
illuminati5288 likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 30, 2020, 10:42
Vignesh Suresh
Thank you. I’ll try this out. Did you you some tutorials or website to make the docker image?
Update: that ansible link is pretty cool. Thanks for sharing
[swak4Foam] undefined symbols in .so libraries when compiling swak4foam 0.4.2 on foam extend 4.1 mAlletto OpenFOAM Community Contributions 3 August 29, 2018 07:02
[OpenFOAM.com] Docker vs Not Docker v2 AND installing editors into Docker u2berggeist OpenFOAM Installation 1 July 10, 2018 03:58
[OpenFOAM.com] How to install a text editor in the Docker container? CFDOnlineyangdaxia OpenFOAM Installation 2 April 10, 2017 08:31
[OpenFOAM.com] v1606+ Install pb with Docker on OSX El Capitan BPich OpenFOAM Installation 3 October 10, 2016 19:52
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
