[OpenFOAM.com] v1906 for Windows 10- how to modify the source code |
January 3, 2020, 12:04 |
giovanni
Rep Power: 9 |
I just downloaded OpenFoam v1906 for Windows 10. I've installed it successfully on my WLS. I can run tutorials and other simple cases. What I would really like to do is to be able to modify the source code, add boundary condition and so on. Is this possible using WSL and of OpenFoam v1906 for Windows 10 ? The first problem that I've encountered is that rootfs foleder , where is built OpenFOAM, is not accessible via WSL (permission denied).
Please give me an help to manage to access and modify the source code. thanks in advance |
January 3, 2020, 23:57 |
Rep Power: 10 |
Hi, Giovanni,
I don't really know the answer to your question. But I also once installed OpenFOAM on Windows 10 through WSL, but dealing with text files was not straightforward, so I switched to Ubuntu 18.04. Anything is much more convenient in it. Best regards, Tonnykz |
January 4, 2020, 10:07 |
giovanni
Rep Power: 9 |
I cannot change OS and install openFoam natively on ubuntu. The only thing i can do is install it through WSL. Anyone can help?
January 5, 2020, 20:36 |
Rep Power: 10 |
Giovanni,
I would suggest to learn how to install dualboot Ubuntu alongside yours already installed windows. Apart from that you will have to learn a lot yourself (user guides, tutorials, internet, etc.). Good luck, Best regards, Tonnykz |
January 30, 2020, 04:59 |
giovanni
Rep Power: 9 |
problem solved: simply follow the instruction for of7 (ubuntu 1804) on openFoam wiki page.Standard source code works also on windows WSL.
I hope it will help for someone. |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 04:50 |
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? | Sorabh | OpenFOAM Meshing & Mesh Conversion | 1 | August 3, 2021 07:35 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 17:18 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 14:14 |
